Old 08-27-2014, 01:17 PM   #127
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by ecko04 View Post
Which tool did you get?
ATEQ Quickset
The Following User Says Thank You to Foobar For This Useful Post:
fika84 (10-02-2014)
Old 10-02-2014, 07:01 AM   #128
Clyde
Drives: Rav4 ACA30
Originally Posted by J_kennington View Post
where is the tis file you have to change? when I try to register using the code, it just keeps popping up the same box over and over. using the newest version that's posted on page 1
on the install instructions that come with it. it says "
Edit file c:\Program Files\Toyota Diagnostics\Techstream\bin\VerApp.ini
what do I edit in that file?
Hello,
i have exactly the Same problem.Have you fix it?
Can you help me please?
Clyde is offline   Reply With Quote
Old 10-02-2014, 10:29 AM   #129
fika84
fika84's Avatar
Originally Posted by Clyde View Post
Hello,
I didn't modify that file at all and it works perfectly. The only thing that I could see to modify in that file was the version number, and I tried it both ways with no difference at all.
Also running it on Win7 Pro X64 with the help of this thread http://www.toyota-4runner.org/genera...-8-64-bit.html
fika84 is offline   Reply With Quote
Old 10-02-2014, 12:07 PM   #130
J_kennington
Drives: 2013 asphalt scion FRS
Hello,
I honestly don't remember what I did. Let me get home tonight and I'll look back through it and see what I did. I believe Fika is correct in saying you don't actually edit the file. But the problem was elsewhere
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
The Following User Says Thank You to J_kennington For This Useful Post:
fika84 (10-02-2014)
Old 10-02-2014, 12:22 PM   #131
Clyde
Drives: Rav4 ACA30
Ok thanks for all guys.It works.
Ive forgot to change this:
CHANGE TISFunction-=1 to 0
And the best is it runs with an original Toyota Vim Interface.
The next step for me is an Win x64 System with an 25$ Mini VCI.
Old 10-02-2014, 02:10 PM   #132
fika84
fika84's Avatar
You're welcome! Glad you got it working. It's nice being able to modify the nit picky things without going to the dealership!
Old 10-16-2014, 01:02 AM   #133
SniperNavy88
Drives: Camry and FRS(GT86)
Here is the link for the TIS 9.30.002.
http://blog.uobd2.net/toyota-tis-tec...ware-download/
SniperNavy88 is offline   Reply With Quote
Old 10-20-2014, 03:19 AM   #134
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Sub'd! I'm gonna need this later for my TPMS.
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 12-02-2014, 02:08 PM   #135
pyro6314
Drives: Scooby
This is hopefully a generic enough question to go here.
I have a Toyota MRS EHPS wired up by itself. I have the CAN and K lines hooked up, and power/ground to an OBD plug. Will Techstream recognize it and talk to just it, or does it need to be on a CAN network with the car's ECU to get past the car selection screen and such?
Thanks.
pyro6314 is offline   Reply With Quote
Old 01-16-2015, 03:31 AM   #136
Liliflower
Drives: 2008 FT86 GTS
Thx, but the software still v9.10.029 version. The latest TIS software V9.30.002 download link
toyota-techstream-v9.30.002.zip
Liliflower is offline   Reply With Quote
Old 01-20-2015, 07:28 PM   #137
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
I have having problems. Has anyone tried to use techstream with an ecuteh tune installed. All the custom fields come up yellow unavailable.
Could it be that because I am using the tactrix op2 instead of the Chinese j2534?
Toyota John is offline   Reply With Quote
Old 01-20-2015, 10:44 PM   #138
Toyota John
Calle Atun
Never mind. Sometimes the tactrix op2 cable is just picky. I tried it again and it worked fine. I didn't have to update any drivers just plugged it in and connect.
Old 02-03-2015, 04:19 PM   #139
Tiz
Drives: Subaru BRZ
Is there a manual explaining how to use Techstream? Alternatively, can someone please tell me with you can reprogram the automatic transmission with Techstream? In particular, can you change shift points?
Thanks!
Tiz is offline   Reply With Quote
Old 02-04-2015, 01:22 AM   #140
kowasu.mono
kowasu.mono's Avatar
Drives: 2013 Subaru BRZ Limited (GBS)
Toyota TechStream is software used at a dealership. So it does not include performance features. It's mostly used to reprogram keys, disable key chimes, and monitoring the status of the vehicle.
kowasu.mono is offline   Reply With Quote
TPMS Tools developer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 10-04-2021 02:28 PM
anyone with a shop or tools Tylub Southern California 0 05-14-2013 12:03 PM
Tools? Gost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-03-2013 04:46 PM
Tools for DIY maintenance? F1point4 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-08-2012 08:47 PM
