Old 09-30-2014, 10:09 PM   #2059
Racecomp Engineering
Originally Posted by Readytoxplod View Post
I'm looking at Michelin Pilot Super Sports or Hankook v12, v12 is cheaper and supposedly is a great tire.
-Also a second question, would 8.5/9.5 be better or 8.0/9.5? I understand it causes understeer and is detrimental towards handling but I want the best handling option out of those two choices. (also plan to tune out understeer with more power, stiff rear swaybar, maybe stiff springs?)
You guys are a great contributor to this forum
Those are big wide wheels and both options really aren't going to be ideal. I would think about 9 inch wide all around.
- Andy
Old 09-30-2014, 10:16 PM   #2060
Originally Posted by yomny View Post
@CSG Mike @Racecomp Engineering
I wanted to know what a reasonable front and rear camber would be to accomodate 9" wheels with 255 tires. What's the max I could use without really causing an extreme wear situation for daily driving. I do occasional HPDE so I know camber would benefit me.
Part two of the question- When installing rear control arm to adjust camber at what point will i NEED toe arms? At what camber setting do the rear toe arms fall short.
Thanks!
-2 degrees camber is a good limit if you're worried about tire wear and still want sporty handling.
For toe arms off the top of my head you generally won't need them unless you're slammed or want a ton of camber for some reason.
- Andy
yomny (10-01-2014)
Old 09-30-2014, 10:18 PM   #2061
Originally Posted by BRZ-One View Post
Good Day!
I think I've decided on the Ohlin's Road & Track.
Had a few people mention to me that it's probably my best bet..
But before, I bite the bullet I'm looking for more validation in what I've decided.
I'm currently using a Swift spring kit, w/ stock shocks & the stock tower mount (unfortunately I had to remove the Whiteline tower mounts). I was happy with the setup until I had to put the stock mounts back in and lost the additional camber and castor..
I'm also interested in getting the car corner balanced & from what I'm reading that can only be accomplished with a coil over system, where you can adjust each shock independently.
Track/HPDE @ Sebring about 6 times/year...
So...bumps galore in T1 & T17
Some street driving, I drive it back and forth to the airport 3 times/mo.
Already installed:
Whiteline Sway bar kits F&R, Rear LCA's, Rear Adj. Toe Arms
Thanks...
Ohlins are an excellent choice, we have a lot of experience with them and ran them on our own shop car. Excellent valving that will eat up Sebring. Give us a call if you have any questions. That's one of Myles in the office favorite tracks and he podiumed there in the Panoz racing series.
- Andy
Old 10-01-2014, 06:08 AM   #2062
dp1
driving smoother faster
Drives: Sold
^ That, love Ohlins on street and track
dp1 is offline   Reply With Quote
Old 10-01-2014, 07:03 PM   #2063
enivid
enivid's Avatar
Drives: WRB JR BRZED
Anyone try ohlins with upgraded springs? Worth the upgrade?
enivid is offline   Reply With Quote
Old 10-01-2014, 10:02 PM   #2064
We ran 450 lbs/in hyperco springs. It worked well, but it's hard to lower the car much.
- Andy
Old 10-02-2014, 05:00 PM   #2065
enivid
enivid's Avatar
- Andy
Not even an inch drop?
Old 10-02-2014, 07:25 PM   #2066
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
CSG and RCE tag-team suspension Q&A thread! Ask us anything!
@CSG David @Racecomp Engineering
I'm a bit perplexed with coilover height adjustment. Do you adjust height measuring a fixed point in the coilover body and making sure both rears are the same as well as both front struts or do you go adjusting each side separately based on fender to ground measurements.
Must you remove end links into the front and on the rear along with rear lca or could the adjustment be made with suspension components fully installed.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 10-03-2014, 11:29 AM   #2067
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
I need a quick sanity check before dropping the car off for an alignment today. In my last 2 track days the car has been slower through the corners so I'm going back to my old settings but there are some other things that changed too so if you guys could take a look and recommend anything I'm all ears.
Last night I softened the compression and rebound on the fronts. It was at 2 clicks from full stiff on the compression (12 clicks available) and 1 turn from full stiff on the rebound (3 rotations available). Current settings are below. I also raised the car back up by 3/8" all around so hopefully the corner balance is still "mostly right".
Here is where things are set now and what I want to align it to:
Lowered 1 3/4" in the Front and 1 5/8" in the rear.
Front: Camber -3.00
Front Caster =+7 (Go for as much as they can get out of it)
Front Toe = 0
Rear Camber = -2.4
Rear Toe = 1/16" Total Toe In
Perrin Front Sway 22mm set on softest
Perrin Rear Sway 19mm set on medium
Koni 8611 Race Fronts set at 5 clicks back from firm on the compression (1-12 settings on the bottom of strut) and about 1/2 way between soft/firm on the rebound. Rears are Koni 30 series and they are set wherever GC set them when they sent them to me.
Tires are Michelin Pilot Super Sports
Thanks in advance for any tips on getting this setup to corner correctly.
digital_assassin is offline   Reply With Quote
Old 10-03-2014, 02:20 PM   #2068
rs999
rs999's Avatar
Drives: VW MK6 GTI | 13 Mustang GT
I have been reading up on Sam Strano's AutoX setup on this forum and he uses a relatively simple setup of summer tires, Strano front sway, and Koni Sport shocks.
What I want to know is how important are shocks in this setup? Are they necessary to control additional body roll or to tune out undesired body dive?
Would Bilstein B6's work better or would it be better to use RCE Tarmac Zero's?
I am looking for simple AutoX, Track, and spirited driving setups. I don't really care about lowering as well.
And Sam's setup looks to be the most simple and best bang for the buck.
SOLD FR-S Build | MK6 GTI Build | I might be getting another FR-S
rs999 is offline   Reply With Quote
Old 10-03-2014, 02:25 PM   #2069
gramicci101
Off Topic
What class does he run in? If it's CS, there's a reason his setup is that simple. If it's STX, there's no reason he couldn't do more.
What class are you looking to run in? Class requirements determine build limitations.
Bilstein's B6 is a strut; RCE Tarmac Zeros are coilovers. If you were to pair the B6 with RCE's Tarmac springs, you'd be similar to their Tarmac Zero, minus height adjustability.
The Following User Says Thank You to gramicci101 For This Useful Post:
Racecomp Engineering (10-03-2014)
Old 10-03-2014, 02:30 PM   #2070
I can't remember exactly where we ended up, but it may have been just a bit less than an inch.
- Andy
Old 10-03-2014, 02:33 PM   #2071
Best to measure from center of hub to fender for ride height measurements. Get one side right and measure threads or something so you can get the other side the same. Measure twice. Corner balance if necessary then align.
You should be able to adjust without removing endlinks.
- Andy
Old 10-03-2014, 02:34 PM   #2072
Front: Camber -3.00
Front Toe = 0
Rear Camber = -2.4
How does the car feel? Hard to make suggestions without knowing where you think you're slower. Alignment specs sound good.
- Andy
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
