Old 07-16-2014, 08:39 AM   #659
FearBoy
Drives: 2013 BRZ Limited
Originally Posted by Boxer486 View Post
You drill out or shave the molded posts?
I pushed the letter pegs out from the inside (not much effort needed). I then placed the STI badge as best I could to cover all the holes, but it left the two on the right uncovered. Finally, I covered the right two holes with blue painter's tape and filled all the holes with black silicone from the inside.
FearBoy is offline   Reply With Quote
The Following User Says Thank You to FearBoy For This Useful Post:
Boxer486 (07-16-2014)
Old 07-16-2014, 07:36 PM   #660
CraftyObeseCrunchyKitty
Drives: Blue ZC6
Nice! I'm going to have to try this later. The TRD badge always bugged me.
CraftyObeseCrunchyKitty is offline   Reply With Quote
Old 07-16-2014, 09:55 PM   #661
FearBoy
Installed
Old 07-16-2014, 10:02 PM   #662
jamesm
Tuned a car with one of these yesterday. I've noticed on the last couple of these I've tuned that they really jack up the MAF a lot more than you'd expect a TRD product to do. With the stock rom it was pretty far off... causing power to be down considerably up top. After tuning we were able to get it all back and make some pretty nice gains.
Virtual dyno runs for comparison purposes only obviously (it was a street tune). They were made same day/conditions/road/etc though. Only difference was the rom:
The Following User Says Thank You to jamesm For This Useful Post:
FearBoy (07-16-2014)
Old 07-16-2014, 11:11 PM   #663
cslntuee
Drives: Subaru BRZ Limited
Does TRD intake has much lower HP and torque than stock <4000rpm range?
Thanks.
cslntuee is offline   Reply With Quote
Old 07-16-2014, 11:22 PM   #664
jamesm
Thanks.
This particular car was noticeably down on power across the board because it was running lean and pulling timing everywhere. Bear in mind those runs are generated by virtual dyno... the numbers don't really mean anything. It's just there for a relative comparison run-to-run, back-to-back. It would've likely made more power in both cases on an actual DynoJet, but the difference would still be the same.
I don't remember specifically how the other cars compared to this one on the stock rom.. but i've definitely noticed a trend towards leaning the cars out significantly. I do remember noting that the amount of timing being pulled was considerably more than what is typical on a couple of them.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
Chimera (12-25-2017), FearBoy (07-17-2014)
Old 08-04-2014, 11:34 AM   #665
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
is the TRD louder inside compared to OEM? I actually quite like the induction sound now, dont want it to go away... Or am I the only one that thinks that the sound tube actually works?
mokinbird87 is offline   Reply With Quote
Old 08-04-2014, 11:57 AM   #666
tomkozski
Drives: 2017 WRB BRZ w/ PP
Definitely not louder, as the intake tube is removed. You will lose some of that induction sound, but I like hearing the more natural engine noise.
tomkozski is offline   Reply With Quote
The Following User Says Thank You to tomkozski For This Useful Post:
mokinbird87 (08-04-2014)
Old 08-04-2014, 02:11 PM   #667
mokinbird87
BOXER FR
but you can still hear it right? as long as I make gains I guess losing the sound is a small penalty... I`m gonna go UEL header soon anyways
Old 08-05-2014, 09:00 PM   #668
tomkozski
I also have the TRD exhaust, but you can still hear the intake sound somewhat. There are videos on youtube comparing the two - this Motor Trend one is pretty good. http://wot.motortrend.com/2013-scion...re-351939.html
mokinbird87 (08-07-2014)
Old 08-05-2014, 09:03 PM   #669
Kostamojen
TRD is way quiter than stock, but you can modify the snorkel to get a lot of (real) noise back.
The Following User Says Thank You to Kostamojen For This Useful Post:
Old 09-30-2014, 02:18 PM   #670
Teo
Teo's Avatar
Someone painted or dipped this part?
I'd like "stealth" engine bay and I wonder if is it possible to dip it (and if resist the paint)
Teo is offline   Reply With Quote
The Following User Says Thank You to Teo For This Useful Post:
JOSI (11-17-2014)
Old 10-01-2014, 11:31 AM   #671
Thorpedo
The SquadWhisperer
Good luck painting silicone.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 11-12-2014, 08:54 PM   #672
babydriver
Hit the road and I'm gone
babydriver's Avatar
Originally Posted by xjohnx View Post
It will likely improve after the ECU has some miles on it to relearn. Also we might want to clean your MAF still if you haven't already done that. Mine looked clean to the naked eye, but after spraying the MAF cleaner on the electric contacts you could see it was removing some contamination/oil
MAF cleaner? Where do you get that?
Is this anything more than hexane/standard electronic parts cleaner?
Thanks for the reply.
Slip, slidin' away.
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
