Old 09-29-2014, 05:11 PM   #1
FloridaBRZ
Drives: 2013 Subaru BRZ Limited 6sp DGM
amount of fluids needed?
I see everyone changing diff fluids and trans fluids. How much of each fluid do I need and what is best? Ice seen motul 300.
FloridaBRZ is offline   Reply With Quote
Old 09-29-2014, 05:20 PM   #2
gramicci101
Off Topic
2.2L in transmission and 1.3L in the diff.
I put Motul Gear 300 in both, purchased from @AZP Installs. You could get Motul Gear 300LS for the diff, but the regular 300 works just fine. The Motul bottles have a fill spout integrated into them; otherwise you'd need a fluid pump. Basically, fill both until fluid starts to weep out of the top hole, and then you're good.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
CSG Mike (09-30-2014), FloridaBRZ (09-29-2014)
Old 09-29-2014, 05:26 PM   #3
FloridaBRZ
Thank you. I'll just 8 or so liters so I have enough for two changes.
Old 09-29-2014, 05:34 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The fluids needed is in your Owner's Manual.
-alex
JohnJuan (09-30-2014)
The Highest Amount of Horsepower Ghost147 Scion FR-S / Toyota 86 GT86 General Forum 17 06-02-2014 07:55 PM
Re-fueling Timing and Amount Chad86 Scion FR-S / Toyota 86 GT86 General Forum 26 03-15-2014 03:03 PM
Ohlins R&T max amount of low (front)? OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-06-2013 07:28 PM
Lowest $ Amount Someone Has Thought You Paid For Your FR-S? DMDominator Scion FR-S / Toyota 86 GT86 General Forum 103 09-22-2013 09:57 PM
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-14-2013 12:46 AM
