#113 |
I'm almost positive it's a proprietary clutch for this setup.
#114 |
Junior
Drives: a car
Money buys car parts, and to car guys like us, that is close if not, the best happiness. Ergo; money buys happiness.
#116 |
I think you have to special order it over the phone. I believe it's built to order, it's a complex setup that I think requires you to send them the trans for mods
#117 |
Drives: frs
I wish these transmission where not so expensive. I am ok with the price of the conversion kit and everything but then the price of these transmissions IMO are outrageous. With the plan I have for my build It will ultimately look as if I have no choice but to do this conversion. In the grand scheme of things it will only be a drop in the bucket after the motor build, turbo kit, fuel upgrades, brakes, suspension etc.
One thing I am curious in though and some other people asked it but I did not see an answer. Do we know more much more the weight of this transmission is VS the stock one? Most guys doing this conversion will probably be making big power so some extra low weight may be beneficial. |
#118 | |
Drives: 2015 Series.Blue
It's because the transmission came in only one car (MKIV Supra Turbo) that wasn't exactly ultra high production (especially in the US), it's used for swaps in those cars as well as the other generations of that car, and it's known for being essentially bomb proof at ludicrous power so long as you don't miss a shift. As for the weight, it's supposedly 51kg (~112.5lbs) dry but I don't know if that includes the bellhousing. |
#119 | |
Drives: frs
Btw thank you for the weight specs. Any one have any ideas on stock trans weight? |
#120 |
I'd be curious to see a kit to put a Tremec Magnum in the car. $3K brand new double overdrive transmission that can take 700ft/lbs...
Though I think eventually there will be upgraded gear sets for the stock trans, we just have to give it more time for the demand to be high enough. |
#121 | |
#122 | |
Drives: Scion FRS
#123 | ||
The only high RPM issue I know of on Tremecs is on stock cars that use remote mount shifters (1st to 2nd grind because the engine/trans shifts out of alignment with the body mounted shifter). Mount the shifter to the trans and it's not an issue. Quote:
![]() By streetable I assume you mean no straight cut gears or switching to a dog box? |
#124 |
Drives: FRS 10 series (1964)
Y'all should create a 2jz swap kit ... since Weapons Grade has slacked on creating one....
#125 |
in orbe terrum non visi
Drives: violent
2jzs are not worth it anymore. And that's coming from a guy who loved the 2jz more than any other motor just a few years ago. LS1 is king.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#126 |
Drives: violent
@FullBlown I'm up for a set of straight cut gears to test out on the street. Seriously. I'll even turn it back up to 400 torques.
| BEST HID Conversion Kit out there?? | VADER | Cosmetic Modification (Interior/Exterior/Lighting) | 29 | 03-30-2017 07:50 AM |
| E85 conversion | ender2664 | Engine, Exhaust, Transmission | 6 | 09-15-2013 10:58 PM |
| Engine Speed vs Vehicle Speed for 6MT | DetroitJake | Engine, Exhaust, Transmission | 22 | 04-27-2013 06:56 PM |
| jdm conversion here it is | jdmboss86 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 06-28-2012 02:26 AM |
| LED Conversion | [M] | Cosmetic Modification (Interior/Exterior/Lighting) | 38 | 06-18-2012 08:44 PM |
