Old 09-15-2014, 10:31 PM   #15
fatoni
is this just for the spring/shock or is it including the install/alignment cost? kind of a big deal. imo, tires and an alignment will go farther than 1500 in a shiny spring wrapped around a low qc shock.
Drive upgrades. Don't buy them.
Old 09-15-2014, 11:06 PM   #16
Firestorm_86
Drives: FRS
http://www.ft86club.com/forums/showthread.php?t=72836
Bilstein B6 or B8 + Swift springs
Firestorm_86 is offline   Reply With Quote
Old 09-15-2014, 11:53 PM   #17
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Bilstein B8's ($838 Tire Rack) + Eibach sport line ($217 Tire Rack) + Whiteline roll correction ($179 Rally Sport Direct) + Perrin front end links ($146 FT86 Speedfactory) + Strano front sway bar ($189 Strano) = $1569.
Forget coilovers.
I'm in love with this suspension setup. If you really want comfort swap out the Pro Kit for the Sportline.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
The Following 2 Users Say Thank You to Superhatch For This Useful Post:
cdrazic93 (09-17-2014), shiro (09-17-2014)
Old 09-16-2014, 08:55 PM   #18
noob and expert
Drives: None :(
Springs, sway bars, tires, brake pads, brake fluid.... If u wanna go a little crazier I would say ksport entry level coilovers or any of the other good ones people r suggesting.
For me, there is no glide in pulse and glide :p
??? is offline   Reply With Quote
Old 09-16-2014, 08:56 PM   #19
noob and expert
Drives: None :(
Or pro kit with illuminas
Old 09-16-2014, 09:22 PM   #20
Model Citizen
Lacking brains
Drives: frz
Originally Posted by ??? View Post
ksport
no
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 09-16-2014, 09:23 PM   #21
noob and expert
Drives: None :(
Why I saw some guy with a miata track car last time I went. It was pretty heavily modified I asked him what he thought and he said they were pretty good
Old 09-16-2014, 10:05 PM   #22
Model Citizen
Lacking brains
Drives: frz
i bought ksports once,
i'd rather order a box of ebola with next day delivery than another set of those turds.
you really may want to look into what the general auto community consensus is on ksport, d2 and every other brand using the same garbage before offering advice.
The Following 2 Users Say Thank You to Model Citizen For This Useful Post:
cdrazic93 (09-17-2014), Racecomp Engineering (09-17-2014)
Old 09-16-2014, 10:24 PM   #23
Burrcold
Drives: Subaru BRZ Limited
Originally Posted by Calum View Post
Racecomp Engineering Yellows, and Whiteline 14mm camber bolts.
You loose a touch of compression travel, but the ride is actually better than stock with the included bump stops. The drop is 3/4 of an inch, not much but it looks good without sacrificing to much geometry.
You also get some camber adjustment in the front which should be included in any suspension.
With this drop do you need LCA's for any rear alignment correction?
Old 09-16-2014, 10:28 PM   #24
noob and expert
Drives: None :(
So then who's good? Fortune auto? St? Stance? Ohlins? Idk then
Old 09-16-2014, 10:30 PM   #25
noob and expert
Drives: None :(
I'm seeing a lot of new brands
Old 09-16-2014, 11:18 PM   #26
Calum
That Guy
Drives: 2013 asphalt FRS MT
From the factory, there is no provision for camber correction in the back. It doesn't matter if you're stock or slammed, to be able to correct the camber in the back you'll need either lower control arms, or one of a few other products.
That said with those springs you wont need it unless something is out from the factory. Even then, a decent technician should be able to find a few tenths of a degree in the slope of the fasteners.
Old 09-17-2014, 11:55 AM   #27
Originally Posted by JARE_ee View Post
Hello everybody,
What would be the best setup to get if you only had 1500 max to spend on suspension. This is my daily driver, and i won't be tracking my car. Cant justify spending 2-3 g's on coilovers.
I just would like maybe 1-1.5 MAX drop (probably 1" or so due to all the bumps in my area)
Main Goals:
Close a bit of the wheel gap
really really comfrontable ride.
Under $1500
Would coilovers be the best option, if so which one?
Thanks!
If you must go with more than a 1 inch drop, I recommend coilovers. ST, Bilstein PSS B14, KW V1, and then some rear lower control arms to dial in the alignment are good options.
If you're happy with an inch or slightly less and $1500 is your budget then you could also go with Koni yellow adjustable or Bilstein B6 shocks with a good quality spring (such as our RCE Yellow springs).
All of the above are good options. Personally I wouldn't use ST coilovers due to the finish...they'd get eaten up by rust where I live. For me it would come down to Bilstein PSS or Bilstein HD + RCE Yellows. I'd be happy with Koni Yellow too, but slightly prefer Bilstein.
- Andy
Old 09-17-2014, 11:56 AM   #28
D2 and K Sport are some of the only coilovers I will come out and say are completely terrible junk. There are many coilovers that I wouldn't use and would rather stock, but with those two I think I'd rather take the bus. Yes I've had first hand experience with them.
- Andy
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
CSG Mike (09-17-2014), Model Citizen (09-17-2014), mwjcyber (09-17-2014)
Eibach Multi PRO R2 Coilovers: $1500 FRSdrive Brakes, Suspension, Chassis 11 02-24-2014 08:00 PM
FS: Eibach Multi Pro R2 Suspension $1500.00 FRSdrive Exterior Parts (Aero, Lighting, Etc.) 1 12-24-2013 06:42 PM
$1500 budget coilover - what would you choose? smbstyle Tracking / Autocross / HPDE / Drifting 27 11-17-2013 10:35 PM
