Old 09-15-2014, 03:49 AM   #15
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by FlamingRectumSyndrome View Post
Hmmm... let's see. Driving clutch since 1973, rebuilt my first engine (a 200 cubic inch six cylinder that wound up in my dad's '66 Mustang) when I was 13, 4 decades of experience rebuilding and riding / driving motorcycles and cars... Nah, I'm pretty sure I'm not lugging it. That, and the fact that the Dealership Mechanics concluded that I need a new transmission, well, that tells me that it isn't just me.
A better defense would be a description of your driving characteristics and what 'low rpm' means to you, for some that's under 1,000, for a lot of us with this car it's 2,000 rpm...
wheelhaus (09-15-2014)
Old 09-15-2014, 03:52 AM   #16
Yoniyama
Drives: BRZ 2018
There goes my plan to install a lighter fly-wheel, lest the dealer claims any problem with the transmission/clutch is caused by an after-market fly-wheel. (Even though that should not be related.)
Yoniyama is offline   Reply With Quote
Old 09-15-2014, 07:24 AM   #17
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
My trans rattles in all gears especially when cold then it goes away then it comes back once in a while sometimes I hear a clicking sound when I step on the gas
Do I need new fluid or a new trans :/
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 09-15-2014, 09:59 AM   #18
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I only have this noise if I'm taking off in 2nd at a very low speed like 6mph. 47,000 miles so far
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 09-15-2014, 11:13 AM   #19
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
I find it some what amazing how quick everyone is to assume the OP is in some fashion or another ignorant. This is common on this forum when involving threads like this. I will give you that we all have different definitions of "Low RPM" vs "High RPM" and can tell you that to me, "Low RPM" is anything below 1000. This is because we have 6 gears and at around 45mph (Typical city speed limit) the vechile sits between 1-2k and is not higher than 2000. This range, to me, is "Light load" or "cruising" range.
I get these are entry level sports cars which have perks and quarks but assuming somone else is completely ignorant isn't effective at all. This is especially true since his 2nd paragraph starts with him announcing he's done research.
Now, like another user said, I have 17,8-- on my vehicle. No rattle, thank god. I've had other weird issue occur such as a radiator exploding which resulted in the dealership claiming to pull driving habits from ECU. Weather or not they actually can, I don't care. I knew I was not pushing the car and the vehicle was still just a babe so I wasn't even spirited with her yet.
Also, as was stated, the clutch housing is bolted to the flywheel, which sits on the back end of the motor. The clutch disk rides on a splined stub shaft that sticks out from the transmission, this stub shaft is inserted into the clutch assembly, specifically into the disk, and is (when properly installed) done most commonly using a special tool that simulates this shaft to ensure proper fitment and alignment, and in no way should the clutch disk ever be able to "rattle" on the input shaft. If the disk itself is rattling, it was poorly installed in the first place.
The Following User Says Thank You to Celadrielas For This Useful Post:
Tcoat (09-16-2014)
Old 09-15-2014, 12:36 PM   #20
extrashaky
Drives: 2014 BRZ Limited
I don't think he's ignorant. I'm just not convinced this sound is a problem, much less a problem that justifies replacing the transmission. Has anybody been able to tie this noise to an actual failure?
Mine has done it since day one, and I'm up to 22K miles. This was a common noise in the British sports cars I grew up with, so the car sounded normal to me. My Triumph made this sound, even after I had replaced the clutch once and had the engine and transmission out of it twice and had realigned the clutch both times with the proper alignment tool. To be honest, the sound is so normal to me that I didn't even realize the BRZ was making it until I saw people on here complaining about it. Then I listened and realized it had been there there whole time. And then I kept driving.
I really do want to know what the techs say is "wrong" with the transmission they're removing and whether the sound returns with the new transmission. If it doesn't come back, I suspect that's more a function of luck than anything to do with parts or installation.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
campy (09-16-2014), strat61caster (09-16-2014)
Old 09-16-2014, 04:09 PM   #21
radroach
Drives: car
So today I took my car in for its initial 7500 mile service. And I mentioned the rattling. An hour later I'm sitting in the very comfortable customer lounge at Livermore Toyota, sipping on a complimentary beverage, and watching my FR-S being repeatedly driven around the parking lot, returned to the service bay, and then taken for another spin around the parking lot. Some 2 1/2 hours later the service rep approaches me with the news that there is an issue with my transmission, they're opening a claim with Toyota, and can I come back Monday morning and drop my car off so they can install A NEW TRANSMISSION (!). She explains that they'll just uncrate a new unit, install it, and "Black box the original unit back to Japan".
Apparently the dealerships in livermore are very eager to work on these transmissions. When I was travelling to CA I called up the Livermore subaru dealership and wanted to see if they were interested in checking my clutch out, and they were absolutely cool with it. I never went in there for service however, kept travelling instead.
Old 09-16-2014, 04:26 PM   #22
Not only did he research he actually TOOK IT TO THE DEALER!
How many posts are there on this forum where somebody says "I have a noise, what is wrong?" instead of taking it someplace where they, (A) can actually hear it and (B) do something about it! Granted there are some common problems where if the poster actually gives enough info somebody here might guess right but I bet a whole lot more miss info goes out then any thing with true value.
On the other hand there are some truly ignorant posters that only want to reinforce what they already believe and won't listen to anybody else or are just looking to blame somebody else for something they screwed up themselves!
Old 09-16-2014, 04:47 PM   #23
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
I tried to take mine to the dealer for it but it stopped chattering when i got there. Epic fail.. They did nothing for me
TONYpepperon1 is offline   Reply With Quote
The Following User Says Thank You to TONYpepperon1 For This Useful Post:
Tcoat (09-16-2014)
Old 09-16-2014, 04:53 PM   #24
Mikem53
Drives: FR-S 6MT
I was right at home when I got my FRS in hearing the clutch "rattle".
The lack of insulation and the transmission being right there close
And personal like lets you hear things you don't in other cars..
Those coming from fwd cars with manuals are isolated from the trans noise
As well as cars that are muted with more insulation and more isolation
from the engine components.
There were threads on the corvette forum about this same sound. Some say the springs on the clutch disc are the culprit as they vibrate.. Other say it's the throw out bearing itself.. Some say gears.. Who knows..
I've had similar sounds under the same conditions in my other cars and never
Experienced a problem over years of use..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
Tcoat (09-16-2014)
Old 09-16-2014, 08:30 PM   #25
I am with you on that one! This is not a super soundproof Lexus or Audi luxury "sports" car. For anybody that doesn't believe the lack of sound proof just check under the little flap in the carpet right below the passenger seat front adjust lever. Bare metal (well painted bare metal) with the tranny an inch or so away!!!!!
Old 09-16-2014, 08:36 PM   #26
Good service when they can make it stop just by threatening it!
Ya it does suck when you know there is a problem and it won't do it when you try to show them. The only issue I have had at all (8000kms and still no crickets fingers crossed) was the window squeal when it was wet. Took it in the rain, hosed it down when I got there, poured water down the door seal and NOTHIN! Drive 2 blocks away put the window up SQUEEEEEEAL.
TONYpepperon1 (09-16-2014)
Old 09-16-2014, 09:16 PM   #27
eyedeez
eyedeez's Avatar
Drives: 2014 Firestorm FR-S 6MT
Interested to hear more. I too have the same rattling. I only notice it when starting from a stop and disengaging the clutch below 1K.
eyedeez is offline   Reply With Quote
Old 09-16-2014, 10:35 PM   #28
strat61caster
OP posted he heard a strange noise at low RPM
Poster asks OP to describe what is meant by 'low rpm' and offers his own experience
OP launches into a tirade about his 'experience'
I'll bet you every person on the planet has a story where somebody launches into "I know what I'm doing mode" only to be proven wrong at a later date. When you put a claim out there be prepared to answer questions about your claim otherwise you're going to have a bad time on the internet.
Nobody here meant to imply the OP is 'ignorant' we're all just trying to understand the car better.
Low RPM rattle when "lugging"? topazsparrow Issues | Warranty | Recalls / TSB 61 05-31-2018 03:10 PM
Intake "Hard" pipes and upgrades - performance difference? fl62 Engine, Exhaust, Transmission 13 08-12-2013 03:34 PM
Is there a collective "stock parts weight" thread? Bullnettles Scion FR-S / Toyota 86 GT86 General Forum 1 05-28-2013 02:46 PM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 05:52 AM
The "if you wanna kiss the backside of white musicians make a thread about it" Thread aliphian Off-Topic Lounge [WARNING: NO POLITICS] 8 12-19-2011 08:59 PM
