Old 09-15-2014, 06:13 PM   #183
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
Originally Posted by Dezoris View Post
The straight answer is yes if you have a turbo and warm temps. You will want to monitor your oil temps now however and see where your oil temps are now before switching.
Well, now the engine os blown jajaja but when I fix it will check!
kombatlion is offline   Reply With Quote
Old 09-15-2014, 08:47 PM   #184
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Keep in mind we are not concerned with engine bearing life at 185 degrees it's when you're pushing the engine and seeing 230+ degrees. If you can't get your oil temperature up it's probably due to not running a thermostat in your oil sandwich adapter.
I do think though in colder climates and not during track season the demand for oil viscosity that keeps oil pressure high enough is less critical. So for sure drop down a little for winter but A) don't run an oil cooler without a thermostat and B) run an oil weight that is appropriate for the pressure you record during aggressive driving.
I'm all for 80-90 psi if you can get it and for a Subaru engine 140 psi at cold start just isn't abnormal but.........run only what you need. If you need to partially block your oil cooler in the winter then do it. We even see track cars that have to block their radiator during the colder months.
I've had to run 50w to handle the oil pressure we are loosing due to oil temperature and I doubt even in the winter I'll drop less than 10w30 for street use. I would never race a 400+ whp FA with less than 40w.
Element Tuning is offline   Reply With Quote
Old 09-16-2014, 01:29 AM   #185
Dezoris
Dezoris's Avatar
I talked with Mocal about their thermostatic plates used on most oil cooler setups because last year when temps went south of 50F oil temps would never come up properly. And when it got below 30F forget it.
Even the thermostatic plates allow for a small amount of oil to flow to the cooler at all times to prevent air lock. So what that means is even though its not full open below 185F the cooler is still getting oil circulating through. I tried blocking mine off but then of course coolant temps started to run higher. So I just disconnected it. I even replaced the Mocal plate as a test. Same story.
This weekend we finished our track video with the S2000 and honestly we just parked the FRS after 4 sessions. On 10w30 I got 9 flat out laps before temps hit 245F and oil pressure hit 45PSI at 7000RPMS. Just did two cool down laps to let oil temps recover, then got another 4 laps before it hit 245 again. Ambient temps were around 65F.
Now the answer I keep getting told to run a bigger cooler.
Well I already have issues on the street with over cooling as it is.
Its not a race car I get it. But there is no good in between.
High oil pressure can be just as bad as low. And I hate seeing 85PSI at 2000RPM for half my commute to work on 10w30.
So its just another thing to deal with if I want to track this car. Change oil at track to 30 or 40wt, and switch back to 0w20 for street duty.
Remove oil cooler during winter, put it back on in spring.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
carbonBLUE (09-16-2014), mkivsoopra (09-16-2014)
Old 09-16-2014, 02:55 AM   #186
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
What about one of those Laminova water/oil cooler setups? How effective would that be warming in the cold and cooling in the hot?
http://www.ft86club.com/forums/showthread.php?t=42511
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
The Following User Says Thank You to blackfireball5 For This Useful Post:
Calum (09-16-2014)
Old 09-16-2014, 03:19 AM   #187
Element Tuning
45 psi at 7k rpm is going to kill your motor and 85 psi at 2k rpm is not so just get that out of your head. Do I think you should fire your car up and blast away at 140 psi, no. Just wait until it's down to 120 or less until you drive if you are concerned but honestly from all the years we've been building and racing these boxer engines it's normal. We even strive for 90+ psi under normal driving conditions because it means well have 80+ hard driving and 75+ while racing.
If you're not racing in the colder months I would still strive for 60+ psi with a heavier oil and block your oil cooler temporarily if need be. Viscosity is a number based on oil temp so you have to account for that if operating at higher thsn the rated 100c.
The Following 3 Users Say Thank You to Element Tuning For This Useful Post:
Dezoris (09-16-2014), kombatlion (09-16-2014), Wayno (11-02-2014)
Old 09-16-2014, 10:32 AM   #188
Dezoris
Dezoris's Avatar
I dont think those will have the cooling power for forced induction cars on track like the liquid to air units. If you can hit 212F on the street fast that would not help. However it would be excellent for those running N/A cars and probably great for those running thicker oil in cooler climates. I Dont know how I feel running two oil coolers/warmers though its just too much crap on this car for a street setup.
I really value your opinion obviously, I would have never been testing this without your threads. In honesty I wont run the car in winter anymore because its already a rust bucket after two years. But I think after this discussion I'd just run two oils going forward. IN winter for sub zero starts stick with 0w20. In summer track months go to 40w. 10w30 redline is a thick oil and at 245F oil temps, pressures go terminal.
The bigger issue is I dont think people who track these cars with FI monitor this at all. My setup is ultra conservative compared to most.
Old 09-16-2014, 11:40 AM   #189
blackfireball5
I regret not logging or at least paying more attention to my oil pressure gauge when I was tracking this summer.
Wheelwell Profile
Old 09-16-2014, 12:47 PM   #190
Dezoris
Dezoris's Avatar
Its definitely worth doing next time you are out.
The Following User Says Thank You to Dezoris For This Useful Post:
blackfireball5 (09-16-2014)
Old 09-16-2014, 02:19 PM   #191
mkivsoopra
Like @Dezoris said, this setup is not enough for FI. On my PTuning turbo car, I hit 265F oil temps within 5 mins of spirited street driving on a hot day (100F) with that laminova.
mkivsoopra is offline   Reply With Quote
Old 09-16-2014, 02:45 PM   #192
stonenewt
Drives: BMW 120d
If your water temps are rising then you've not got enough base line cooling to start with. Go back to the drawing board & start again time. I went through several iterations on my Elise before I nailed it but once right it worked much better than other people using radiator type oil coolers.
EDIT: Also worth mentioning I found that with FI the laminova absolutely hammered the main radiator. For my application I used an 90mm aux oil cooler for the turbo oil feed (IIRC post-turbo), this seemed to have a dramatic impact on oil temp runaway with a lower load on the cooling system.
stonenewt is offline   Reply With Quote
The Following 2 Users Say Thank You to stonenewt For This Useful Post:
Dezoris (09-16-2014), mkivsoopra (09-16-2014)
Old 09-16-2014, 03:40 PM   #193
Calum
That Guy
Drives: 2013 asphalt FRS MT
Any thoughts on just running a 0w40 all year?
Old 09-16-2014, 04:55 PM   #194
Dezoris
Dezoris's Avatar
I think Phil wont agree here. Since he is building race setups. But personally if you drive in real cold 6 months out of the year, real world sub zero starts and dont see track time during those months running a 40wt oil is just too much. Cold starts are bad enough but cold starts on thick oil just not worth the increased wear. Not only that its highly inefficient. For not performance applications for efficiency sake you want the lowest oil pressure possible trying to target that 10psi per 1000rpm. On a 40wt in winter you be running over 90psi at 2000rpm for a majority of the time until you hit 200F oil temps. Which wont happen with an air oil cooler.
Old 09-16-2014, 08:44 PM   #195
Calum
That Guy
The number before the w indicates the lowest point that the oil can maintain a minimum pour point. The number after the w indicates the viscosity at a set higher temperature. A 0w40 will have a lower viscosity at cold temperatures and a 10w30. If you want an oil that gives relatively low viscosity when the engine is cold and relatively high viscosity when the engine is hot, a 0w40 should give you both of those.
The only caveat is that SAE allows oils that meet 0w30 standards to be labeled as 0w40 as well as oils that meet 0w40 standards.
The Following User Says Thank You to Calum For This Useful Post:
Dezoris (09-17-2014)
Old 09-16-2014, 09:19 PM   #196
Element Tuning
For sure I think people should be running two different oil viscosities based on temperatures/seasons. The two viscosity choices will be debated to death but trust your oil pressure gauge above all else if forced induction. I think NA guys have more leeway.
The Following User Says Thank You to Element Tuning For This Useful Post:
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 03:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 06:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 01:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-18-2013 12:24 AM
