Old 09-12-2014, 11:07 AM   #1
lookchris
lookchris's Avatar
Ignition Problems
I have a 2013 BRZ limited, and I've been having some starting issues. I have to push the button a number of times before my car turns on. Anyone else having the same issue?
lookchris is offline   Reply With Quote
Old 09-12-2014, 11:42 AM   #2
Does it turn over and not start or turns over but doesn't fire up ..... ??
Old 09-12-2014, 11:58 AM   #3
Muskokan
Drives: white Sport-tech
Manual or auto?
Muskokan is offline   Reply With Quote
Old 09-12-2014, 12:21 PM   #4
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
This happened to me a few times recently [2013 LTD] Nothing when push start, had a flashing key symbol on instrument panel. Thought my battery was dead on key fob, so I grabbed my other fob and it started right away. It happened again with second key fob later on, push start and flashing key symbol on instrument panel. Anyhow, to make a long story short, both times push start failed, I had used keyless entry. Meaning I walked up to car and pulled handle to unlock. When I push unlock doors with key fob, I never have the issue. I'm sure there's a logical explanation, But I'm too lazy to investigate it further...
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 09-12-2014, 12:37 PM   #5
stugray
Drives: 2013 GBS BRZ Limited
I have never seen that.
Mine starts every single time on the first try.
Never more than 2 seconds of cranking even when below freezing.
22,000 miles.
If you are pushing the button and nothing happens, then maybe it is the clutch switch (assuming MT)
The Following User Says Thank You to stugray For This Useful Post:
Sportsguy83 (09-12-2014)
Old 09-12-2014, 08:05 PM   #6
lookchris
lookchris's Avatar
Originally Posted by Muskokan View Post
Manual or auto?
Manual
Old 09-12-2014, 08:06 PM   #7
lookchris
lookchris's Avatar
When I push, nothing but electric works.
Old 09-12-2014, 08:07 PM   #8
lookchris
lookchris's Avatar
22,000 miles.
I was considering the clutch, but my buddy had the same issue on his is250 and that was auto.
Old 09-12-2014, 08:30 PM   #9
That was one dumb post ......
Old 09-12-2014, 09:53 PM   #10
Burrcold
Drives: Subaru BRZ Limited
I've had it a happen twice before. All electrical came on and the gauge did the needle sweep, but didn't even try to turn the engine over. Nothing at all. Walked out if the car, locked it, came back in and it worked. No idea why and I know the dealer will never be able to recreate so meh.
The Following User Says Thank You to Burrcold For This Useful Post:
lookchris (09-13-2014)
Old 09-13-2014, 12:27 AM   #11
Poodles
Drives: 2015 Series.Blue
The steering wheel lock could be the issue as well.
Old 09-13-2014, 01:34 AM   #12
lookchris
lookchris's Avatar
Such a weird problem. I notice it happens more when I drive with the a/c on prior to me starting it again.
Old 09-13-2014, 10:48 AM   #13
Muskokan
When this happens id try pumping the clutch a couple times, and/or hitting it 2 without clutch to turn everything on first, then clutch and start from there. Sounds like a safety thing which I would assume would be the clutch sensor.
And hey if all else fails, bump that sucka your in a manual son
The Following User Says Thank You to Muskokan For This Useful Post:
Old 09-13-2014, 01:23 PM   #14
Would agree completely if a key but not sure how the wheel lock works with the button. My old lancer used to do that all the time. Just give the wheel a twist until the lock clicks and try again. Worth a shot.
FRS Ignition Key ft86Fan Scion FR-S / Toyota 86 GT86 General Forum 120 07-22-2014 10:23 PM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 05:01 PM
Remix to Ignition PEWPEW Member's Car Journals 23 06-03-2014 01:15 AM
Ignition vs Argento? Pacific Auto Scion FR-S / Toyota 86 GT86 General Forum 3 08-17-2013 05:24 PM
New test from Ignition. zoomzoomers Scion FR-S / Toyota 86 GT86 General Forum 9 05-01-2012 12:31 AM
