View Poll Results: Motul gear 300 or Redline MT90 for transmission & Differential?
Motul gear 300 193 71.75%
Redline MT90 76 28.25%
Voters: 269. You may not vote on this poll
Old 12-28-2012, 05:44 PM   #57
fenixv8
fenixv8's Avatar
Drives: 1991 Acura NSX, 2013 Scion FRS
ok cool thanks I was just a little confused by the "API Standards: API GL-4/GL-5"
on the website.
fenixv8 is offline   Reply With Quote
Old 12-28-2012, 05:44 PM   #58
Hanakuso
Originally Posted by AZP Installs View Post
+1 That is correct.
-Mike Paisan
What would you recommend if budget wasn't a priority?
Hanakuso is offline   Reply With Quote
The Following User Says Thank You to Hanakuso For This Useful Post:
fenixv8 (12-30-2012)
Old 12-28-2012, 05:52 PM   #59
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Budget is always a priority in my book as that is part of the game
But in actuality we would and do use the Motul Gear 300 75w90 for both the trans and rear diffys in the Subarus and the BRZ/FRS. The LS we used in my CTS-V rear Diffy because it had a mechanical rear LS as well as in other applications where there is a mechanical LS Diffy.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following 3 Users Say Thank You to AZP Installs For This Useful Post:
fenixv8 (12-30-2012), Hanakuso (12-28-2012), hmong337 (03-28-2014)
Old 12-28-2012, 06:14 PM   #60
AZP Installs
As a followup, if they decide to put one of the mechanical rear diffys in the car next year, then the recommendation would change completely for obvious reasons.
-mike
Old 12-31-2012, 12:27 PM   #61
fenixv8
fenixv8's Avatar
Engine Tranny and Diff, Motul 300v 0w20 and Motul Gear 300 75w90 yesterday after break in period. Shifting much smoother in the cold now. Thanks for the advise Hanakuso and AZP Installs.
The Following User Says Thank You to fenixv8 For This Useful Post:
AZP Installs (12-31-2012)
Old 01-15-2013, 11:19 PM   #62
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
Originally Posted by SXE10
Just use a GL5 designed for an LSD & you'll be right.
Originally Posted by gmookher View Post
Whatever you do , do NOT use a GL5 in the transmission
It calls for a GL3 which has been superceded by GL4
however it does not work the same way b/w GL4 and GL5
GL5 is fine in the diff
forget SAE spec. consider the actual oil used and its viscosity
If you'd read the above posts you would have seen we were talking about the diff, not the transmission. Hence the mention of Limited Slip Differential
As you where.
SXE10 is offline   Reply With Quote
Old 01-16-2013, 03:12 PM   #63
flippy
flippy's Avatar
Drives: 2013 Firestorm Scion FRS
Originally Posted by SXE10 View Post
Why did you chose NS over MT-90 or even MT-85 & how exactly is it going to cause any damage?
Have you guys seen the
I've had MT-90 in my Altezza for @ 50K km & it still shifts as smooth as the day I put it in. Seems to me like this thread is turning into Motul vs Redline with lots of hatters, hearsay & a surprising lack of knowledge about the oil industry & only a few people talking any sense. But I guess that sums up most car forums
hatters gonna hat
Originally Posted by bdanisi View Post
Can we close this thread it wasn't intended to become vaginal pun fodder
flippy is offline   Reply With Quote
The Following User Says Thank You to flippy For This Useful Post:
ddevl_86 (03-26-2021)
Old 01-16-2013, 04:15 PM   #64
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by Nardi330 View Post
on further thoughts, would fitting Whiteline rear subframe bush inserts transfer more diff vibration?
i changed oil and installed the bush inserts at the same time. does that make the diff feel more rough while standing start and turning at the same time? once the car rolls over at speed (2nd gear +) i don't really feel any harshness.
I didn't see an answer to your question.
Yes. Those gaps in the bushings are specifily to reduce noise and vibration. By filling those gaps, and using a material with a higher durometer you are making it easier for vibrations from the diff to transfer to the body. As you add more and more hardened/poly bushings, you'll get more Noise, Vibration, Harshness (NVH) in the cabin.
The Following User Says Thank You to Draco-REX For This Useful Post:
Old 09-11-2014, 10:23 AM   #65
KslayFRZ
KslayFRZ's Avatar
Drives: 2013 Frs asphalt
I had motul put on my trans at 36k... now it grinds to high Hell when d shifting into 5th
Sent from my SPH-L900 using Tapatalk
KslayFRZ is offline   Reply With Quote
Old 09-20-2014, 05:34 PM   #66
KslayFRZ
KslayFRZ's Avatar
Switched to amsoil.... f ing amazing
Old 03-06-2016, 12:18 AM   #67
IronDuke
Drives: 2016 FRS
I known this is a dead thread, but I just hit 1000 miles and put Red line MT90 in my MT, just because I've always changed out fluids on all my vehicles after the break in period. I used to own a Jeep Wrangler and Redline works very well with them, so I figured why not. Well gears 1-3 are very grindy now. I've ordered Motul and will post the results. The MT90 was very thin and after reading the label it states it can be used as engine oil 10w- 40, wtf?
Update: I put the Motul in yesterday, and it's much easier to shift now compared to OEM and Redline.
IronDuke is offline   Reply With Quote
Old 03-07-2016, 11:14 AM   #68
mhughett
Drives: 2015 Crystal White BRZ Limited
The viscosity ratings on gear oil aren't the same as those for engine motor oil. You are correct that the 75w-90 wt for gear oil is roughly equivalent to 10w40 motor oil. I used MT90 on my son's Mazda3 and it works great. I tried Motul on this car and found it to be pretty notchy, especially in the mornings. I've since tried a 50/50 blend of Motul and Royal Purple Synchromax and this is the best formula so far. I've gone through the winter and also gotten it up to track temperatures and overall, it is the best. YMMV.
mhughett is offline   Reply With Quote
Old 09-19-2016, 08:35 PM   #69
sato
sato's Avatar
Drives: Dodge Patitas
They put Valvoline on my transmission at the dealership and it did the exact same thing...
sato is offline   Reply With Quote
Old 11-30-2016, 03:20 PM   #70
MikeyBatz
MikeyBatz's Avatar
Drives: Scion FR-S
I have about 10,000 miles on my frs and looking to change the transmission fluid. Would you guys recommend doing a full flush or just a simple drain and fill?
MikeyBatz is offline   Reply With Quote
redline kendalldwhite Scion FR-S / Toyota 86 GT86 General Forum 5 08-26-2012 03:12 PM
Reaching redline. erom Engine, Exhaust, Transmission 27 07-23-2012 07:46 PM
Fr-s vs. Saturn Sky Redline - would your rather Gabriel FR-S / BRZ vs.... 7 06-07-2012 01:57 AM
Engine 7500rpm redline KiingDavid Engine, Exhaust, Transmission 20 03-13-2011 08:04 PM
