Old 09-08-2014, 08:49 PM   #2073
Sithspawn
Drives: '14 Hot Lava FR-S w/Flappy Paddles
Those are 22mm MO fittings (Metric O-Ring) and not designed for copper crush washers. Did they not supply a torque spec for those fittings? According to a manual I wrote a while back, the ORB fittings on a Setrab core should be torqued to 29.5 ft-lbs and you should be using a wrench on the Setrab core to prevent that torque from ripping the fitting off of the core. Furthermore, the o-rings need to be lubed prior to installing the fittings to prevent them from galling and/or bunching up. Also be sure to use a wrench to support the MO fitting when installing the AN fitting as well.
Sithspawn is offline   Reply With Quote
Old 09-09-2014, 01:08 AM   #2074
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Got it all installed.. Kit yesterday, injectors today.. Just waiting for a map to limp up to the dyno on Thursday..
Gixxersixxerman is offline   Reply With Quote
The Following 2 Users Say Thank You to Gixxersixxerman For This Useful Post:
CSG Mike (09-09-2014), KraftWerks (09-09-2014)
Old 09-09-2014, 01:39 AM   #2075
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Looks clean! Did you leave the blast shield off on the drivers side over the injectors or did you make it fit? Mine is still off and I can't tell if yours fit on or not.
nlowell is offline   Reply With Quote
The Following User Says Thank You to nlowell For This Useful Post:
Gixxersixxerman (09-09-2014)
Old 09-09-2014, 05:16 AM   #2076
Gixxersixxerman
I installed both.. I've done three kits now and have not had a problem installing any of the shields.. Though I will say that doing mine I couldn't get the bolt hole lined up, and being a auto there seems to be more wiring going over the tab making it harder when I realized the injector was holding it back, spun the injector around and it went right on. That was the passenger side but maybe something to look at.
I'm researching now the torque capacity and longevity of the automatics.. I see them holding 400+ hp and 350+ torque but can't find out if they are still running that.. Oil coolers are crazy expensive lol..
Old 09-09-2014, 11:35 AM   #2077
nlowell
nlowell's Avatar
I put my own tran cooler together and just installed it. I'm in it for ~$350 with the gauge. I didn't install a pump though - waiting to see if that's needed.
Old 09-09-2014, 11:39 AM   #2078
FR-S Matt
We still get the discount on the oil cooler if we bought the kit, right? I still need to pick one up.
Old 09-09-2014, 12:03 PM   #2079
SPCorBUST
SPCorBUST's Avatar
Planning a diy?
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 09-09-2014, 01:18 PM   #2080
Gixxersixxerman
Originally Posted by SPCorBUST View Post
Planning a diy?
Or at least a parts list?? Lol I'd be very interested.. What are your numbers and how long have you had your kit..
Old 09-09-2014, 05:11 PM   #2081
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Yes, your coupon code might be expired, just call them and they honor the 20% discount. Actually they gave me 3 coupon code. wink wink @KraftWerks.
BTW: We have another "Twisted Sister's Run" on 10-11. Hope you can make it this time w/ SC installed.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
The Following 2 Users Say Thank You to zoth For This Useful Post:
FR-S Matt (09-09-2014), KraftWerks (09-09-2014)
Old 09-09-2014, 05:26 PM   #2082
nlowell
nlowell's Avatar
Planning a diy?
@Sithspawn is rocking the install and data in much more detail. Follow this thread for some great upcoming information:
http://www.ft86club.com/forums/showthread.php?t=61498
Sithspawn (09-09-2014)
Old 09-09-2014, 06:04 PM   #2083
Sithspawn
I'm doing R&D on a transmission cooler right now. Full data logging and analysis before and after with discussion of results.
Old 09-09-2014, 07:29 PM   #2084
sw20kosh
Drives: 2013 Black FR-S
I put down 365hp at the wheels (automatic transmission).
E85 or race gas? Do you have a graph?
The Following User Says Thank You to sw20kosh For This Useful Post:
captain_jack (09-09-2014)
Old 09-09-2014, 07:34 PM   #2085
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Of course!
Just give us a call so we can either extend the code so you can order at your own convenience over the web or we can simply extend the same deal right then over the phone!
KraftWerks is offline   Reply With Quote
The Following User Says Thank You to KraftWerks For This Useful Post:
Old 09-09-2014, 08:30 PM   #2086
nlowell
nlowell's Avatar
E85
http://www.ft86club.com/forums/showpost.php?p=1922686
sw20kosh (09-09-2014)
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
