| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 |
SPACESHIP
Drives: BRZ Ltd 6MT WRB
It's the difference between engine and road speed that's causing the first to second lurch. You have to wait quite a significant amount of time for the revs to drop with stock spinny bits, especially first to second.
| The Following 2 Users Say Thank You to Tgionet For This Useful Post: | aristo (09-07-2014), Ganthrithor (09-08-2014) |
#30 | |
Drives: WRB BRZ Series.Blue
Also don't shove, let the syncros do it's thing. |
| The Following User Says Thank You to cookiesowns For This Useful Post: | aristo (09-07-2014) |
#31 |
Drives: BRZ SWP 14
Thanks for the input! Theoretically, if you are trying to go as fast as physically possible would the above still apply? (waiting for RPMs to drop)
Is this why people change to lighter weight flywheels? |
#32 | |
Drives: Subaru BRZ
Why is it that I see people going to redline, clutch in, shift, clutch out so smoothly and quickly with no delay? |
| The Following User Says Thank You to n0thing For This Useful Post: | x1UP (09-08-2014) |
#33 |
Drives: '13 BRZ, '06 997, Other Things(TM)
Yes. Although I'm not sure how much a lightweight flywheel would help with RPM drop in a drive-by-wire car (the only cars with lightweights that I've driven have been older, cable throttle cars). Certainly in cars that pre-date drive-by-wire, the time you spend waiting for blips and RPM drop when shifting is slashed dramatically by a lightweight flywheel.
| The Following User Says Thank You to Ganthrithor For This Useful Post: | aristo (09-08-2014) |
#34 |
Drives: BRZ SWP 14
So what for example would be a good RPM to wait til shifting second if assuming we went to redline on 1st gear? Sorry these questions are getting dumb and the best answer is almost always go outside and test it yourself, but I can't use the car again until tomorrow :d
#35 |
SPACESHIP
7400 rpm in first gear is equal to 4457 rpm in second
| The Following User Says Thank You to Tgionet For This Useful Post: | strat61caster (09-08-2014) |
#36 | |
#37 | |
aeiou
Drives: WRB BRZ
For the 1-2 shift, let the clutch out more slowly than in other upshifts. If you're comfortable with it, lower the clutch pedal height and remove the pedal helper spring. This makes the clutch pedal feel much more natural and the travel more linear. Side effect is that these *free* mods are so good, it makes driving a stock twin infuriating.
What helps me upshift smoothly is increasing the speed at which I lift the clutch pedal once I get to the bite point. Around that area, I raise my clutch foot 20-30% faster.
| The Following User Says Thank You to unsurety For This Useful Post: | aristo (09-08-2014) |
#38 | |
Correct. I would say the only other way to shift faster ( possibly wearing the clutch more ) is to let go of the clutch out quicker, but getting on the gas quicker too. Seesaw action. That might be quicker. Tt could just be the gearing for 1-2. Again though, if you're WOT, and at high revs, and you shift, to shift smoothly, you need to get back on the gas quicker, and more gas to maintain your velocity. |
| The Following User Says Thank You to cookiesowns For This Useful Post: | aristo (09-08-2014) |
#39 |
Drives: 2013 BRZ Limited
The real key to getting going as fast as possible is making all three motions at about the same time. I use two or three fingers when pulling the shifter towards me and my palm when pushing the shifter. One thing this prevents is putting a lot of force on the shifter. One reason I have yet to adjust the clutch pedal is because I use the delay in disengagement. As you are letting off the gas the clutch pedal should be going down. When the clutch pedal is on it's way down you should be taking it out of the gear it's in and putting it into the next as soon as the pedal hits the floorboard. Lift off the clutch pedal quickly while getting on the gas. It takes a while to get good, I'm still perfecting it in the BRZ but I could shift my impreza very quick(very handy in the snow).
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears 1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust 1993 Honda CB750 Nighthawk |
| The Following User Says Thank You to CoupedUpSubie For This Useful Post: | aristo (09-08-2014) |
#40 | |
Lightweight flywheel also helps with blipping the throttle for rev matching since you don't need to hit the gas pedal as hard to get the RPM's to jump. I also never leisurely heel toe. I personally find it much much easier to heel toe when it's needed, IE - really hard braking coming into a corner at high RPM. I do find myself rev matching for downshifting if I'm trying not to use the engine to slow myself down. |
| The Following 2 Users Say Thank You to fika84 For This Useful Post: | aristo (09-08-2014), Ganthrithor (09-08-2014) |
#41 |
Drives: Subaru BRZ
#42 |
Drives: BMW 120d
From experience it's only when the clutch is slipping & under load that you kill the thrust bearing. I assume this it because it's heat that kills it off & lot of heat is generate when riding the clutch. Also the wait for the revs to drop shouldn't be long at all.
| The Following User Says Thank You to stonenewt For This Useful Post: | aristo (09-08-2014) |
| New to manual driving, shifting isn't that smooth | Vincenttam | Other Vehicles & General Automotive Discussions | 11 | 07-23-2014 02:58 AM |
| Shifting with a manual... | Jen | Scion FR-S / Toyota 86 GT86 General Forum | 110 | 04-22-2014 10:46 PM |
| A Week of A/T Manual Shifting Mode | Ocala FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 98 | 05-15-2013 02:35 AM |
| driving manual questions | cantaloupe | BRZ First-Gen (2012+) — General Topics | 25 | 11-08-2012 04:27 PM |
| shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 05:09 PM |
