#15 |
Drives: 2013 Scion FRS
Yea, I had same issue. Forum search kinda sucks but this was my post a few months back... http://www.ft86club.com/forums/showthread.php?t=64048
FA500 Coils/Swift/Radial Upgd, Cusco R.LCA, SPC R.Toe Arms, TqSol. R.SubFrame Bushings, MTEC Shift Springs, Perrin Shift Bushing/Trans Mount, Greddy SP Exhaust & Intake, RPF1 18x9.5 +38, 255/35-18 SDrives, Raceseng Ashiko Knob/Lockout |
| The Following 2 Users Say Thank You to MyEvilMonkeys For This Useful Post: | MINOCIN (09-07-2014), Superhatch (09-12-2014) |
#16 |
Thanks!
#17 |
Drives: Asphalt 2013 FR-S
My car occasionally makes the same noise too, so I decided to check the strut nuts as well. I tried to wiggle the bar and it felt tight. I then checked the nuts with my fingers and they were not crazy loose. Finally, I set my torque wrench to 12 ft/lb and started with the driver side nuts and sure enough they were loose. Unfortunately, one of the bolts snapped on the third quarter turn
![]() I checked the rest of the bolts and they all felt similarly loose, but I didn't perform more than one quarter turn on each because I was afraid of snapping another bolt. Now that I'm missing one bolt I wonder if the noise will occur more often? In the mean time, I need to look for stronger bolts.
| The Following User Says Thank You to MINOCIN For This Useful Post: | Superhatch (09-12-2014) |
#18 | |
AIM4APX
Drives: 2013 WRB BRZ Limited
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#19 |
The fix to your issue seems strange to me. IIRC, those bolts were on very fit from factory when I loosened them
#20 |
AIM4APX
My only thought was that lowering the car might have caused the bars to work a little harder, or interact with the frame in a different way which might have actually taken some stress off them? I'm not 100% sure about the root cause of why they loosened up, but I am 100% sure that tightening the nuts solved my issue.
#21 |
Drives: '13 Firestorm FRS
Thank you so much for the write up!
#22 |
Drives: '23 CWP BRZ
bringing it back from the dead. my car just started producing this same noise. I tightened those bolts..noise is still there.
| Suspension clunk/thump going over bumps | SloS14 | Issues | Warranty | Recalls / TSB | 31 | 11-19-2015 07:05 PM |
| rear suspension clunk | Gen | Issues | Warranty | Recalls / TSB | 67 | 04-03-2015 08:52 PM |
| STI Pillowball Trailing and Lateral Links For Rear Suspension Do They Clunk? | krayzie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-06-2014 12:47 PM |
| Sonoma Trackday Video (spinout included) | orthojoe | Tracking / Autocross / HPDE / Drifting | 47 | 06-08-2013 12:29 AM |
| Clunk sound from rear suspension. | j-tan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 02-05-2013 12:39 PM |
