Drives: 2008 GSX-R600
How strong is tranny?
Is it going to be anything like the STI's 6 speed? Thanks for the info.
#2 |
Site Moderator
Drives: Stuff
The az6 is capable of being plenty strong but it depends on what they specified for its internals. Not enough info yet to provide a solid answer.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#3 |
OCD
We don't know for sure yet but from what we know so far, it should be a decent transmission. You can see what other cars use the AZ6, they all hold power and abuse well.
#4 |
Reverse Burnouts
Drives: 2013 Argento FRS
the az6 is 80% different than the s2000's az6, so really its up in the air, we can only believe its stronger
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#5 |
FT86 News Addict
Drives: Toyota FJ
Not sure but she used to be a man...
| The Following 3 Users Say Thank You to KaliKev For This Useful Post: |
#6 | |
Reverse Burnouts
look up is250 automatic transmissions, the A960E automatic is pretty reliable at stock power levels, not sure on what they can withstand, usually they can be reliable up to double the stock tq for the manual (i keep seeing this transmission code pop up in the last few days ra62 and AZ6 transmission codes) the RA62 was designed to be put in the tacoma and the fj cruiser(rwd versions), also it was designed around the supercharged versions of both cars, so its good to over 330lb-ft so both transmissions should hold about 400 hp reliably for a while at least, as the car progresses we will see people break stuff and we will learn what exactly broke and what needed to be replaced to increase the maximum load of the transmissions ![]() manual should be pretty bullet proof designed for a 330lb-ft engine on a 2 ton fj cruiser that same transmission is going to be in a 2700lb car, so i could imagine higher torque capabilities
#7 |
tranny strong...hulk no smash
#8 |
Señor Member
Drives: 2013 SSM DZE BRZ
This is somewhat of an aside, but pertinent enough if we're going to start looking at how much power each transmission can handle. Kaizen Factor says that the transmission in the 86 coupes is not the RA62, but in fact the TL70, sharing a resemblance to the Aisin AZ6. The AZ6 should serve as a starting point for determining how much the 86's transmission can handle, but even then, it's assuredly been modified to the point that we won't be able to know anything with certainty until either someone more knowledgeable chimes in or someone breaks one.
| The Following User Says Thank You to Subie For This Useful Post: | jruhi4 (04-27-2012) |
#9 |
Drives: '06 AM V8V Coupe
Interesting article, I hadn't seen that before. However the article failed to point out that the ratios appear to be exactly the same as on the S15... which I think is an important bit.
#10 | |
Reverse Burnouts
Transmission Type TL70 Engine Type FA20 Gear Ratio 1st 3.626 2nd 2.188 3rd 1.541 4th 1.213 5th 1.000 6th 0.767 Reverse 3.437 Oil Capacity Liters (US qts, Imp.qts) 2.2 (2.3, 1.9) Oil Viscosity SAE 75W-90 Oil Grade API GL-3 Weight (Reference)* kg (lb) 42.9 (94.58) but at the same time ![]() and also read this
| The Following User Says Thank You to carbonBLUE For This Useful Post: | jruhi4 (04-27-2012) |
#11 |
Drives: e30 150 deville etc etc
HKS offers a "6 speed Transmission upgrade from the Silvia S15"....The silvia S15's transmission was notoriously fragile....There's your indication..
#12 | |
Drives: 2012 WRX Sedan
^ This is crazy. I mean I wouldn't have thought it would have taken that much effort to create good shift feel. You'd think they'd start with an AZ6, but it sounds like they started with a J160 went to replacing 80% of an RA62 to make it feel like an AZ6. Which should be called a TL70. LOL. |
#13 |
Drives: slow
we won't know how strong the tranny is until we get our hands on one and use it, that goes for transmissions too.
#14 |
I usually post drunk
| Australia - Confirmed Details & Strong Rumours | Netrosis | AUSTRALIA | 81 | 05-22-2012 10:22 PM |
| MT vs AT tranny... better MPG, 0-60? | subatoy | BRZ First-Gen (2012+) — General Topics | 163 | 03-26-2012 06:08 PM |
| Manual tranny takes another step into oblivion | madfast | Other Vehicles & General Automotive Discussions | 76 | 03-06-2012 09:40 PM |
| name that tranny! (updated: AZ6 transmission from FR-S/BRZ/GT86) | carbonBLUE | Engine, Exhaust, Transmission | 14 | 12-19-2011 04:00 AM |
