Old 09-04-2014, 05:34 PM   #379
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
This thing is still supposedly a full year from release. I actually may look into them in a year when they come out though. Looks like baby Jag F-Type to me and there's nothing wrong with that in my opinion.
Old 09-04-2014, 07:26 PM   #380
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
They are supposed to be available in spring 2015. 6-8 months away.
I am sure in the meantime there will be lots of information coming on drive train and other specs. Theu said early on that the car could not produce less power so I am expecting around 170HP. With 220 less pounds and the same HP it will be considerably faster than a NC. Good news for any enthusiast.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 09-05-2014, 01:28 AM   #381
Poodles
Drives: 2015 Series.Blue
Originally Posted by serialk11r View Post
That is not a smidge faster. It is much faster. You just described a 2ZZ swapped MR2 Spyder, which is as fast as a base 981 Boxster, which I guarantee is a lot faster than an FRS.
The Miata will come with 150hp at best, IMO. They wouldn't give it the 2L engine.
Why would you think they wouldn't use the 2.0 engine when they already use a 2.0 engine in the current model? It also already makes 170HP, so we need to be aiming higher here...
I don't see them downsizing the motor and power from the current model when they have competition to compete with.
Old 09-05-2014, 02:32 AM   #382
Kilika
Drives: 1992 Toyota MR2
It'll only take ~160 HP to get the same power-to-weight ratio as the twins. The rumored coupe version which should be lighter would only increase Mazda's lead in numbers for every circuit in America.
Kilika is offline   Reply With Quote
Old 09-05-2014, 02:34 AM   #383
serialk11r
Drives: '06 AM V8V Coupe
My bad, I always thought it was a 1.8L in the NC.
I could see a downsize. It only has to be a little faster than the current car, so they may very well downsize. I guess it depends on how much weight they really lost.
Old 09-05-2014, 03:55 AM   #384
Allch Chcar
Drives: N/A
There are people that still believe it will have more power? Ha. The famous creator wanted to downsize the engine with less power! I believe they were talking about a 1.3 turbocharged engine. The 2.0L was the biggest engine it's ever had or will have. Note that a 1.3L was throw around because they do not have a Skyactiv 1.5L, they only have the 1.3L Skyactiv used in the Mazda Demio(Mazda2 in the US). Which is also why the Mazda2 is still using the 1.5L MZR. Which is nothing like the bigger MZR, BTW. IMHO, they need to design a high output version of the 2.0L MZR for the US. But that is assuming they want to sell it to Americans. Hell, even if they made a 2.5L turbocharged version for the USDM, Americans would still want more power.
That said, I'm not impressed with the new body at all.
@Cerealk11er, a 1.8L version of the MZR is available in Europe.
Originally Posted by n2oinferno View Post
Converted to Imperial I get:
Wheelbase (in) 91.1" (change of -0.6")
Length (in) 154.1" (change of -3.17")
Width (in) 68.1" (change of +0.4")
Height (in) 48.6" (change of -0.8")
The NC:
Originally Posted by Mazdausa
Wheelbase (in) 91.7
Length (in) 157.3
Width (in) 67.7
Height (in) 49.4
But then those were just development targets. :/
While often thrown around 2200lb curb weight is a nice low number, it's overly optimistic and highly unlikely to be the final result. The current NC weighs ~2593lbs with a PRHT and 6 speed standard, ~2619lbs for the 6 speed automatic with PRHT. The 2500(actually 2480)lb curb weight you hear quoted all the time is for a base NC with soft top and the 5 speed. It's more likely that the ND with a 6spd and PRHT weighs ~2370lbs.
Obviously, I can't account for the difference a lower weight will have on the subjective "fun" factor. Therefore I won't try to.
Sources:http://www.mazdausa.com/MusaWeb/disp...e=MX5&trim=MXR
and
http://www.mazdausa.com/MusaWeb/disp...ehicleCode=MX5
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 09-05-2014, 04:22 AM   #385
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Thanks - heard that and like it - but there was one of those " number of angels on the head of a pin" debates over at miata.net about whether the engine sound was faked (certain miata netters are even more OCD than some around here ).
Sport-Tech is offline   Reply With Quote
Old 09-05-2014, 09:03 AM   #386
DarkSunrise
DarkSunrise's Avatar
Losing 220 lbs. overall and shifting weight distribution rearward to 50/50, while keeping the current heavier 2.0L engine up front would be quite difficult.
Not saying it's not possible, but I would definitely tip my hat to Mazda if they could pull that feat off.
2022 BRZ Build
2013 FR-S Build
Old 09-05-2014, 09:03 AM   #387
Entroper
Entroper's Avatar
Drives: 2019 MX-5 RF GT-S, 2002 Miata LS
What I described was 13.53 lb/hp. The FR-S is 13.75 lb/hp. That's a difference of 1.6%, which I think can be safely referred to as a "smidge". I would also accept "hair".
Entroper is offline   Reply With Quote
Old 09-05-2014, 09:22 AM   #388
wbradley
Sarcastic SOB
wbradley's Avatar
I'm sure it will be a decent car but I don't care for the smiley face front grille any more than the BRZ's. Also, I see some styling rip offs. The taillights appear to be a vague rendition of the Jaguar type F. That's expected considering the original Miata styling was a ripoff of the Lotus Elise.
Too bad there's no points for originality/creativity.
At least with the twins, styling cues were taken from previous Toyotas.
Old 09-05-2014, 11:02 AM   #389
MarbleGT
Drives: 2008 MX5
The Elise came out 7 years after the original Miata.
This is conflicting. The ND is completely new, nothing taken or re-imagined from previous models. It's all original.
MarbleGT is offline   Reply With Quote
Old 09-05-2014, 11:09 AM   #390
wbradley
Sarcastic SOB
wbradley's Avatar
If you're thinking Elan, that falls into the classic British Roadster category from which it was built to modernize. It wasn't in any way styled after one though.
Correction, might have been Lotus Elan. Even taillight design copied on original Miata. I guess it was Mazda's marketing strategy. Who cares anyway, the Miata is not a vehicle I'd buy. Don't like Mazda.
Old 09-05-2014, 11:09 AM   #391
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Pretty sure you meant to say Lotus Elan, the super lightweight British roadster from the 60s.
Old 09-05-2014, 11:13 AM   #392
WolfpackS2k
The power seats that most people opt for don't help, they are heavy as s***. I didn't notice a single person with a totally base car, but I remember thinking based on reading a thread that a realistic weight for a totally base Cayman MT with 18" wheels and 2 way seats is 2950-3000, not 2890. I recall some people had 3200+ lbs Caymans thanks to their 20" wheels, 18-way heated vented seats, PASM, PDK etc.
I can't speak for the Boxster, but the base Cayman seats still have electric adjustability for the seatback, and manual adjustment for height and fore/aft movement. My Cayman S is about as light as you can get from the factory. Only option my car has is Sport Chrono. However I've yet to have it weighed, though I would imagine it's under 3000.
WTB [FL]: Mazda Miata MX-5 03-05 and 06-08, manual transmission SteelReign Cars for Sale/Trade 5 06-22-2015 03:01 PM
2016 mazda miata (MX5) reveal 9 PM EST Ernie L Off-Topic Lounge [WARNING: NO POLITICS] 1 09-03-2014 09:41 PM
FS: Supercharged 1992 Mazda Miata *$4000 OBO* BRZZZZZZZZZZ Canada Classifieds 5 08-18-2014 05:44 PM
The Mazda 2 trully the FWD Miata NA! Tbomb 25 Other Vehicles & General Automotive Discussions 24 01-14-2013 10:30 AM
