| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
What about oil from a company called Klotz?
I remember when I raced model cars, the nitro fuel mixed with Klotz oil was always viewed as the best. I know that's no comparison for our cars, but I was still curious about the company and the oil they make. http://www.klotzlube.com/ |
#16 | |
Thanks
| The Following 2 Users Say Thank You to ZionsWrath For This Useful Post: | flippy (09-04-2014), Sportsguy83 (08-28-2014) |
#17 |
Drives: 2004 Subaru Forester 2.5XT
#18 | |
Hi everybody!
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
Would be great if swapping out the gear lube would eliminate this problem. |
#19 |
Drives: 2014 BRZ Ltd - DGM
Swapping to Motul also eliminated that first turn "grumble" in mine as well, plus the heavier hot weight feels better in the trans.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car E46 323ci vert |
| The Following User Says Thank You to sluflyer06 For This Useful Post: | flippy (09-04-2014) |
#20 |
When In Doubt...
Drives: Slowww
Anyone else with constant low-speed-tight-radius (turning) chatter/groaning on Motul gear 300?
Kind of has me worried after discovering it. The fluid has about 3500 miles on it.
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#21 | |
Drives: White 2014 BRZ
Yes I noticed this more than smoothing out the shifting (which fwiw it seemed close to the stock fluid, maybe a bit better when hot). The little rear end shutter of the LSD is nearly gone with the Motul when cold. |
| The Following User Says Thank You to stevo585 For This Useful Post: | CSG Mike (09-03-2014) |
#22 |
We've been using Motul for the past 12+ years. We've had oil analysis's from Blackstone over that time from not only us but also our customers. We also use Amsoil.
Motul 8100 is our "basic" oil change. We go through roughly (1) 55 Gal Drum of it every 3-4 weeks. We also use the Motul products in all our track cars and get Blackstone analysis on them with no bad reports. -Mike Paisan ![]() Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
#23 | |
Drives: '14 WRB BRZ 6MT Limited
What intervals do you see with the 8100 for street use? |
#24 |
Drives: Black 86
If motul, go for 300v only. Had bad experience with the h-tech variant
#25 |
#26 |
Drives: Currently 2018 Taco
There can be no doubting that Motul is great product. They seem to have among the highest amount of esters in their base stocks. I remember Joey saying something along those lines. What about Red Line? What about group 3+ ? Are you finding that only 300V and Signature Series/Dominator stand up? I will search the UOA thread herein. It must make for some interesting reading. TY.
| The Following User Says Thank You to viscositosis.rex For This Useful Post: | BRZ21 (09-04-2014) |
#27 | |
i kill cones.
Drives: around cones in a parking lot
2013 SSM BRZ Limited 6MT
#28 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Here's my experience with Motul:
I compete in SCCA RallyCross and my last car was a 03 WRX with a swapped STI V7 6MT. I used both Subaru Extra S and Motul 300. The Extra S began to lose its heat resistance after about a year of competition. Once the oil got some good heat in it, shifting would begin to get a little notchy. The Motul lasted through two seasons before I started noticing a drop in smoothness. |
| motul 300 vs motul 300ls about to buy some need help. | NickFRS | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 03-24-2016 10:51 PM |
| Where to get Motul Gear 300 in the GTA? | automatic | CANADA | 5 | 04-09-2014 04:48 PM |
| motul Oil | whitefrs | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 05-24-2013 10:12 AM |
| No Motul Gear 300?? | markmatley | Hawaii | 14 | 04-17-2013 08:59 PM |
| Superior Shine - Opti-Guard - 86 | SuperiorShine | AUSTRALIA | 11 | 07-22-2012 10:56 PM |
