Old 09-03-2014, 03:13 PM   #71
ddeflyer
Originally Posted by mkivsoopra View Post
Water temperature update! (BETA)
I had to ZIP the original file that they sent (DB6.rar) so that it can be attached to the forum. You'll have to unzip, then unrar it.
I haven't tested this myself yet... been too busy putting my car back together . I also have their blessing to pass this along to the community.
So if there is a problem we should be able to revert by going to the old profile, right?
If that is the case then I will give this a try this weekend.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 09-03-2014, 03:17 PM   #72
mkivsoopra
Hm, good question.. let me ask them.
mkivsoopra is offline   Reply With Quote
Old 09-03-2014, 05:33 PM   #73
mkivsoopra
To revert:
Originally Posted by AiM Tech Support
If, for whatever reason there's an issue, simply re-install RaceStudio 2 and it will replace the beta ECU driver pack with the standard version.
... then create new configuration and transfer to the device.
Old 09-03-2014, 05:49 PM   #74
ddeflyer
To revert:
Ok, I will give this a try sometime this weekend.
The Following User Says Thank You to ddeflyer For This Useful Post:
mkivsoopra (09-03-2014)
Old 09-03-2014, 08:40 PM   #75
puma
crew chief
puma's Avatar
Drives: Race car FR-S
Are your AAT accurate, mine seemd to show like 10 degC less that was it really was.
puma is offline   Reply With Quote
Old 09-22-2014, 12:40 PM   #76
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
So I finally got some usable data on my Solo DL yesterday.
One thing I noticed is that when I push on the brake pedal more than a light squeeze, the Clutch Switch indicates that the clutch is being pushed.
I'm guessing that there is some adjustment that can be made here, but has anyone else seen this?
Cheers,
bimmer635csi is offline   Reply With Quote
Old 09-22-2014, 01:23 PM   #77
CSG Mike
CSG Mike's Avatar
Cheers,
I don't usually monitor the clutch pedal... can you email me a log? mike @ counter space garage dot com
Old 09-22-2014, 01:35 PM   #78
ddeflyer
Cheers,
I've noticed that value triggering on my car randomly (when I am not using it). I suspect that it is just a hair triggered microswitch meant mostly to keep people from using their starter to bump into a wall. I could be wrong of course...
CSG Mike (09-22-2014)
Old 09-22-2014, 11:01 PM   #79
bimmer635csi
Cheers,
Here's the proof that I'm not mental. Watch how many times the "CLUTCH" light flashes. I only used it once on course to shift to 2nd.
[ame="http://www.youtube.com/watch?v=6ABbzlhAm08"]Spokes SASCA Event 9 on 2014 Sep 21 - YouTube[/ame]
Check out my Formula 1 style data display too.
Old 01-14-2015, 02:47 AM   #80
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
No idea... let's test it at the next 86 CUP
Originally Posted by RehabJeff86 View Post
I have heard it won't work with splitter
so I finally got a splitter myself and tested it.
Won't work. :P
-alex
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
CSG Mike (01-14-2015), juliog (01-14-2015), RehabJeff86 (01-14-2015)
Old 01-14-2015, 08:56 AM   #81
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
are you 100% sure your foot isn't slightly resting on the clutch pedal during those times?
my clutch reading is also rather random, but I figure that's what Is happening. but since the reading is a 1/0 I've since turned the sampling for it off.
Old 01-14-2015, 09:05 AM   #82
bimmer635csi
I'm 1000% sure.
I've since started working on a Toyota for ChumpCar / LeMons racing. It works very similarly, except with vacuum switches. The clutch pedal and brake pedal both have a vacuum switch. These are connected together with a T fitting, which then goes into the firewall to connect to the engine vacuum.
Knowing what I know about Toyota and their tendency to not change things, they are probably using the same electrical circuit on our cars to detect either brake or clutch, much like the above vacuum circuit.
I'm probably just going to turn it off also. Thanks for looking though.
The Following User Says Thank You to bimmer635csi For This Useful Post:
7thgear (01-14-2015)
Old 08-17-2015, 10:13 AM   #83
frssfo
frssfo's Avatar
Drives: 2015 FR-S
I was going to use the beta file. However, when I installed the new release of Race Studio 2 it already appears to have the update. After loading a new FR-S config to the Solo the ETC reading is higher than it was before. So there doesn't appear to be a reason to load the beta files any more to fix the ECT reading.
frssfo is offline   Reply With Quote
The Following User Says Thank You to frssfo For This Useful Post:
mkivsoopra (08-17-2015)
Old 08-22-2015, 03:34 PM   #84
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Just got the Aim SmartyCam HD v2 and all is working fine except I don't see a data file on the SD card and I don't see a setting to enable/disable saving the data to the card.
Anyone know the trick to get the Solo DL data to be stored on the SmartyCam's SD card?
Thx
Sleepless is offline   Reply With Quote
Solo 1 kombatlion SOUTH AMERICA / CARRIBEANS 6 03-20-2015 05:01 AM
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 12:34 PM
N.J. Pro Solo Simmons Tracking / Autocross / HPDE / Drifting 20 03-11-2013 06:32 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
