Old 09-02-2014, 09:04 PM   #1
2_slo
2_slo's Avatar
Drives: 2013 Crystal Black BRZ Limited
Re-wire Power outlets
Has anyone done a diy on how to rewire the power outlets so they always have power? It pisses me off that I cant just throw my phone in the car and let it charge when Im not in it. I did a quick search on it and didn't come up with any threads about it. I am going to do it soon. Any interest in a diy out there?
2_slo is offline   Reply With Quote
Old 09-02-2014, 09:11 PM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Yeah. Just run wires directly from the battery. Make sure you add a fuse though.
BTW, is glove box outlet also switched? I never checked before.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-02-2014, 09:35 PM   #3
2_slo
2_slo's Avatar
Both are switched, yes. I was more thinking switching the power source to the current fuses in the fuse box, and retaining all original wiring just removing the current switched source and adopting a constant power source from the same fuse block. I will try to delve into this sometime this week and shall create a diy upon completion.
Old 09-03-2014, 08:44 AM   #4
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
I have a portable battery pack in line between the outlet and my phone so it charges from the battery pack when the car is off and when the car is running, the battery pack is recharged.
ntron1 is offline   Reply With Quote
Old 09-05-2014, 02:53 AM   #5
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Same setup but for my DashCam.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 09-05-2014, 09:54 AM   #6
2_slo
2_slo's Avatar
I was able to modify my fuse block yesterday so that power outlet 1 is always powered. The one on the glove box would require much added effort so ill settle for just the one.
Old 09-29-2014, 12:43 AM   #7
greencounty
greencounty's Avatar
I was trying to do this too. I gave up and just bought a kit to add an additional unswitched cigarette lighter port(tapped off of the radio harness). This is much simpler.
I fiddled with trying to get to the connections for the port in the console(which you can get to by pulling the E-brake veil) but I just didn't want to pull the entire thing apart to run wires.
Garage:
2013 BRZ Limited 6MT - Galaxy Blue
1994 Ford Probe GT 5MT - Red(some would argue pink)
1969 Mustang Fastback 4MT - Royal Maroon
greencounty is offline   Reply With Quote
Old 09-29-2014, 12:52 AM   #8
Poodles
Drives: 2015 Series.Blue
This is a common feature in import cars. While you guys apparently don't like it, at least you're not at my store telling me your battery is bad when it's just discharged because your wife left her GPS plugged in all week while on vacation because you have a Chevy that doesn't turn the outlet off
Old 09-29-2014, 01:07 AM   #9
greencounty
Well I just want to be able to charge my phone in my car, while i'm at work.
Garage:
Old 09-29-2014, 01:34 PM   #10
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
I have one of these:
http://www.amazon.com/EasyAcc%C2%AE-...dp/B008YRG5JQ/
Which charges via USB. I plug it into the car when it gets halfway discharged, otherwise it just sits in the cupholder area to charge things.
It's got enough juice to charge my Lumia 1020 about 3 times over, so you don't really need to keep it plugged in but you can.
It also doesn't heat up much due to its size, which is a must for me in the hot CA summers. With a window visor I don't have to worry at all about leaving it in the car to charge things.
Old 10-03-2014, 09:44 PM   #11
vividracing
vividracing's Avatar
Feel so stupid! Didnt even know that I had a second outlet in the glove box until now!
vividracing is offline   Reply With Quote
Old 10-04-2014, 10:05 AM   #12
mid_life_crisis
Drives: FR-S 10 #103 AT
So share. The point of a DIY section is to figure stuff out and share the knowledge.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Solved: Running 4-gauge power wire to trunk B-R-Z Electronics | Audio | NAV | Infotainment 3 11-08-2017 05:47 PM
Where to find ignition wire? One that gets power at key position 2 HRTROB Electronics | Audio | NAV | Infotainment 1 04-13-2014 01:44 AM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 10:40 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 11:22 AM
