Old 08-28-2014, 12:54 PM   #15
mike the snake
What about oil from a company called Klotz?
I remember when I raced model cars, the nitro fuel mixed with Klotz oil was always viewed as the best.
I know that's no comparison for our cars, but I was still curious about the company and the oil they make.
http://www.klotzlube.com/
Old 08-28-2014, 12:58 PM   #16
ZionsWrath
Thanks
ZionsWrath's Avatar
Hell no, no way I want my lube to klot!
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
flippy (09-04-2014), Sportsguy83 (08-28-2014)
Old 08-28-2014, 01:00 PM   #17
bluesubie
Drives: 2004 Subaru Forester 2.5XT
-Dennis
bluesubie is offline   Reply With Quote
Old 08-28-2014, 01:11 PM   #18
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
Originally Posted by surcy View Post
Does anyone know if the Montul gear lube eliminates or reduces the rear end chatter associated when accelerating from stop on sharp left or right turns?
I'm new to this car and driving a stick. I've been wondering lately if there was something wrong with the car. When I make a sharp right turn going from an uphill straight (the last block on my way home) I've noticed a noise even though the RPM's are at around 1500. Was worried I was lugging my engine. Does this sound like the same problem you speak of?
Would be great if swapping out the gear lube would eliminate this problem.
Frishkorn is offline   Reply With Quote
Old 09-02-2014, 10:45 AM   #19
sluflyer06
Drives: 2014 BRZ Ltd - DGM
My diff would grumble on the first turn after sitting overnight then made no noise, but after running the Motul I don't get the "first turn grumble" and more.
Motul in my trans fixed the 1st to 2nd grind that I had, especially when cold.
Swapping to Motul also eliminated that first turn "grumble" in mine as well, plus the heavier hot weight feels better in the trans.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
The Following User Says Thank You to sluflyer06 For This Useful Post:
flippy (09-04-2014)
Old 09-03-2014, 09:31 PM   #20
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Anyone else with constant low-speed-tight-radius (turning) chatter/groaning on Motul gear 300?
Kind of has me worried after discovering it. The fluid has about 3500 miles on it.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 09-03-2014, 09:35 PM   #21
stevo585
Drives: White 2014 BRZ
Yes I noticed this more than smoothing out the shifting (which fwiw it seemed close to the stock fluid, maybe a bit better when hot). The little rear end shutter of the LSD is nearly gone with the Motul when cold.
stevo585 is offline   Reply With Quote
The Following User Says Thank You to stevo585 For This Useful Post:
CSG Mike (09-03-2014)
Old 09-03-2014, 11:59 PM   #22
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
We've been using Motul for the past 12+ years. We've had oil analysis's from Blackstone over that time from not only us but also our customers. We also use Amsoil.
Motul 8100 is our "basic" oil change. We go through roughly (1) 55 Gal Drum of it every 3-4 weeks. We also use the Motul products in all our track cars and get Blackstone analysis on them with no bad reports.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following 3 Users Say Thank You to AZP Installs For This Useful Post:
CSG Mike (09-04-2014), flippy (09-04-2014), hmong337 (06-01-2015)
Old 09-04-2014, 12:55 PM   #23
GotMunchies?
Drives: '14 WRB BRZ 6MT Limited
-Mike Paisan
What intervals do you see with the 8100 for street use?
GotMunchies? is offline   Reply With Quote
Old 09-04-2014, 02:15 PM   #24
victorb
Drives: Black 86
If motul, go for 300v only. Had bad experience with the h-tech variant
victorb is offline   Reply With Quote
Old 09-04-2014, 04:21 PM   #25
GotMunchies?
Details?
Old 09-04-2014, 04:57 PM   #26
viscositosis.rex
Drives: Currently 2018 Taco
There can be no doubting that Motul is great product. They seem to have among the highest amount of esters in their base stocks. I remember Joey saying something along those lines. What about Red Line? What about group 3+ ? Are you finding that only 300V and Signature Series/Dominator stand up? I will search the UOA thread herein. It must make for some interesting reading. TY.
viscositosis.rex is offline   Reply With Quote
The Following User Says Thank You to viscositosis.rex For This Useful Post:
BRZ21 (09-04-2014)
Old 09-04-2014, 08:29 PM   #27
BRZ21
i kill cones.
BRZ21's Avatar
Drives: around cones in a parking lot
Originally Posted by DieselDog View Post
Why would a Torsen diff need oil with a limited slip additive/friction modifier?
Torsen T2 differentials are all gear driven.
Differentials that use it are usually Clutch type limited slip.
I changed the transmission and differential oil in my FRS a week after I bought it. The motul gear 300 did make a difference for cold driving. I never had any complaints when the transmission was at operating temp
I never had the chattering problem but I only had the factory oil in for a week.
You're right about how they work however the fluid that is associated with the clutches in differentials is separate. Which is why that style of diffs is not very popular among the used market... You can't change or replace it. Sucks. Otherwise I'd already have an na miata...
2013 SSM BRZ Limited 6MT
BRZ21 is offline   Reply With Quote
Old 09-04-2014, 09:11 PM   #28
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Here's my experience with Motul:
I compete in SCCA RallyCross and my last car was a 03 WRX with a swapped STI V7 6MT. I used both Subaru Extra S and Motul 300. The Extra S began to lose its heat resistance after about a year of competition. Once the oil got some good heat in it, shifting would begin to get a little notchy. The Motul lasted through two seasons before I started noticing a drop in smoothness.
motul 300 vs motul 300ls about to buy some need help. NickFRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 03-24-2016 11:51 PM
Where to get Motul Gear 300 in the GTA? automatic CANADA 5 04-09-2014 05:48 PM
motul Oil whitefrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 05-24-2013 11:12 AM
No Motul Gear 300?? markmatley Hawaii 14 04-17-2013 09:59 PM
Superior Shine - Opti-Guard - 86 SuperiorShine AUSTRALIA 11 07-22-2012 11:56 PM
