go_a_way1
Old 08-28-2014, 12:53 PM   #841
Casey10s
Casey10s's Avatar
Drives: 2013 white limited BRZ
Originally Posted by Deadpool_25 View Post
@Casey10s
Thank you very much. I guess quite a few folks are installing themselves. Sounds like it's pretty easy. I also have a fully equiped shop available (base auto hobby shop).
I don't plan on removing the cat initially. As for tires, I'm on Nitto Motivos right now. Not sure how those rate as far as stickiness...
What other mods have you done? Thanks for your help.
I had the JR SC installed with custom tune. Tune was due to Invidia Q300 exhaust with elimination of one catalytic converter. Next on list will be engine oil cooler and at some point tires and wheels. I can't make up my mind on what to do about the tires.
Casey10s is offline   Reply With Quote
The Following User Says Thank You to Casey10s For This Useful Post:
CSG Mike (08-28-2014)
Old 08-28-2014, 01:42 PM   #842
Deadpool_25
Drives: BRZ Limited
Cool. Thanks for the info!
Deadpool_25 is offline   Reply With Quote
Old 08-28-2014, 04:53 PM   #843
CSG Mike
CSG Mike's Avatar
Originally Posted by DarkSunrise View Post
Damn, I was worried that would be the answer. Thanks Mike.
Remember, the Perrin cooler was made to work in free-flowing air without restriction. If you can relocate it in front of the FMIC, then it would be better, but it's still designed for an NA engine.
Old 08-28-2014, 08:27 PM   #844
Cheeseballs
Cheeseballs's Avatar
Drives: Really slow
For any CARB tune owners with a good amount of miles on the kit, have you felt the need to upgrade your clutch? I am thinking about getting an Exedy Stage 1 but not sure if I should do it now or wait for the oem to start slipping (if it ever does).
Cheeseballs is offline   Reply With Quote
Old 08-28-2014, 08:32 PM   #845
CSG David
CSG David's Avatar
No problems yet. If your clutch is slipping, it means you're pretty aggressive on the clutch. The CARB tune and kit was designed to work at the limit of all the associated components of the factory vehicle so it is an absolute plug-n-play unit without any need to upgrade anything.
If you want more power, then yes...clutch is a recommendation, but not an absolute.
The Following User Says Thank You to CSG David For This Useful Post:
Cheeseballs (08-28-2014)
Old 08-30-2014, 02:05 PM   #846
iLLDYNASTi
iLLDYNASTi's Avatar
Drives: 2013 DGM BRZ
Hey Guys,
I have a quick question before i head off to work. With the rotex is it possible to swap out the pulley for more boost? Ive looked around the internet a lot and havent seen anything saying yes or no and without seeing the kit in person i cant judge. The Jackson Racing is definitely the SC im going with but I want to know if down the road i can get more power from the same kit if i want it.
"Don't ask me...I just work here"
iLLDYNASTi is offline   Reply With Quote
Old 08-30-2014, 02:20 PM   #847
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Originally Posted by iLLDYNASTi View Post
Hey Guys,
You can. Nothing out by Jackson Racing "yet" ...but I'm hopeful there will be an upgrade soon
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 08-31-2014, 02:45 AM   #848
CSG Mike
CSG Mike's Avatar
Hey Guys,
It sure is!
Old 08-31-2014, 11:18 AM   #849
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
It seems like the KW kit and this one use the same centrifugal blower. If that's the case then what is the difference between the two kits?
TONYpepperon1 is offline   Reply With Quote
Old 08-31-2014, 11:54 AM   #850
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Well a key difference featured with the KW is that it runs on a independent drive system from the main engine belt. So if the belt breaks you can still drive it home and save yourself a tow truck ride. KW also offers a upgrade to the bigger C38 blower, i'm not sure if JR will be able to offer this due their layout.
JonAvalon is offline   Reply With Quote
Old 08-31-2014, 01:28 PM   #851
TONYpepperon1
Oh right. I thought the JR kit was the same independent belt system but I guess not. Other then that is there any cons over one another?
Old 08-31-2014, 02:37 PM   #852
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
KW has the independent belt, the C38 option, the cold air intake, and is not CARB exempted yet. Whoever handles packaging and shipping at KW is apparently the worst employee ever, sending out several kits with incorrect parts. KW always makes it right but it's an annoyance.
JR has an underhood intake that gives plenty of cool air once you're moving, no C38 option yet, no independent belt, and is CARB exempt already. Every kit includes some sort of unknown bonus that causes JR owners and sellers to derail every single thread in the FI section where someone is expressing interest in a KW system.
There are other slight differences in the kits that really don't mean much.
Sellout is offline   Reply With Quote
The Following 2 Users Say Thank You to Sellout For This Useful Post:
Calum (08-31-2014), Xero-Limit (08-31-2014)
Old 08-31-2014, 02:53 PM   #853
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
What the fuck? He's asking in the JR owners thread, ofc he's gonna get answers relating to the JRSC.
ScionOfHorus is offline   Reply With Quote
Old 08-31-2014, 03:03 PM   #854
Sellout
Mr. Cranky Pants
Sellout's Avatar
You're under the mistaken impression that I'm talking about this thread. Anyone who has ever read one of the threads where a member asks questions specifically pertaining to the KW kit would understand what I'm talking about.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
