Old 08-30-2014, 08:33 PM   #169
JM9ISM
Drives: 2014 BRZ WRB LTD
Originally Posted by Scuba86 View Post
So if I were to run all 7.5 and 225/40/18 with no lowering springs it would still be good?
I'm pretty sure you will be fine.
Originally Posted by LALFAN View Post
Thanks for the information.
Correct me if I'm wrong, but you're on 18x7.5 square, but you had to go from 225/40R18 in the front to 215/40R18 in the front because you noticed rubbing?
Toyota recommended...
Front
Wheel: 18"x7.0"
Tire: 215/40R18
Rear
Wheel: 18"x7.5"
Tire: 225/40R18
Speeeddemon99 has...
Front
Wheel: 18"x7.5"
Tire: 215/40R18
Rear
Wheel: 18"x7.5"
Tire: 225/40R18
JM9ISM has...
Front
Wheel: 18"x7.5"
Tire: 225/40R18
Rear
Wheel: 18"x7.5"
Tire: 225/40R18
Does this look right everyone?
I wonder why it rubs for one car but not another car? Anyone have any additional information or insight to help us all out?
I know! I was surprised it didn't rub on my car, so I decided to snap some pics for you guys.
Originally Posted by dchan8 View Post
possibly the brand of tire installed. each manufacturer varies a bit even though the tire size is the same "size"
It might be. I'm running on Hankook V12 Evo2 K120
Here some pics for u guys
Wheel was turning all the way to right and you have about 1.5 cm left for the clearance on passenger side
Here is on driver side. Pretty much same clearance as passenger side.
JM9ISM is offline   Reply With Quote
The Following User Says Thank You to JM9ISM For This Useful Post:
LALFAN (08-31-2014)
Old 08-30-2014, 08:34 PM   #170
JM9ISM
Originally Posted by trinxified View Post
Are you also pretty flush to the fender? No spacers right?
kind of.. and no spacers but I do need it for the rear though
Old 09-01-2014, 03:42 PM   #171
RAYSSPL
Drives: bicycle
would anyone happen to know the type of manufacturing process that's used for the TRD wheels?
RAYSSPL is offline   Reply With Quote
Old 09-06-2014, 02:54 AM   #172
LALFAN
Drives: FR-S RS 1.0
For those of you planning to use the Toyota recommended specs for these wheels what tires are you considering? There aren't too many choices for the front 215/40R18, even less when you narrow it down to all season tires. I live in SoCal so we don't get much rain, but this would be a daily driven so I'd rather go with an all season tire versus a purely summer tire.
http://www.tirerack.com/tires/TireSe...erformance=ALL
Michelin Pilot Sport A/S 3 seems like a logical choice but it only has a rating of 85Y, the stock tires are 87W. I was under the impression that the weight rating must be equal or higher? Is that correct?
That leaves the Continental ExtremeContact DWS or the Yokohama AVID W4S. Opinions?
Or is everyone just planning to run summer tires?
LALFAN is offline   Reply With Quote
Old 09-06-2014, 03:34 AM   #173
LALFAN
Drives: FR-S RS 1.0
This really would be much easier if we were 100% certain that 225/40R18 on 18x7.5 fit in the front without rubbing as the Michelin Pilot Sport A/S 3 in that size has a load rating of 92. That would be my preferred setup. Easier to buy tires that size and the ability to rotate too.
Old 09-06-2014, 10:48 AM   #174
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
I almost feel like I should order just two of the 7.5" P/N wheels and get two 225/40R18 tires and see if they fit on the front. If they don't, and rub, I could just put them on the back and pickup the two 7" for the front.
Thoughts?
FyeaFRS is offline   Reply With Quote
Old 09-06-2014, 11:05 AM   #175
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
TRD USA Wheels
If these are same offset as stock, you should have no problem fitting a 225 wide tire on a 7.5" wide wheel. I have 225/45-17 (1% larger diameter than stock) on an 8" with a 45 offset (3mm more aggressive than stock).
Sent from Tandy 400
Quentin is offline   Reply With Quote
Old 09-06-2014, 11:19 AM   #176
Quentin
225/40-18 should be very close to that. Considering the 9" wide wheels and such I see under a lot of these vehicles, I'd think that if you are rubbing at all on the strut, 5mm spacers should sort you out. Stock studs are long enough for that long of spacer.
Sent from Tandy 400
Old 10-03-2014, 06:18 PM   #177
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Would stock lug nuts work on the trd wheels ? or it requires aftermarket ones ?
botbs is offline   Reply With Quote
Old 10-04-2014, 04:28 AM   #178
86Toyobaru
Drives: 86 & GRB
Front
Wheel: 18"x7.0"
Tire: 215/40R18
Rear
Wheel: 18"x7.5"
Tire: 225/40R18
Front
Wheel: 18"x7.5"
Tire: 215/40R18
Rear
Wheel: 18"x7.5"
Tire: 225/40R18
JM9ISM has...
Front
Wheel: 18"x7.5"
Tire: 225/40R18
Rear
Wheel: 18"x7.5"
Tire: 225/40R18
18x7.5 +35 wheels with 225/40R18 in front should NOT rub at all.
7.5J+35 is like adding 19mm(48-35+6) spacer from OEM wheels (7J+48). I think something wrong with Speeeddemon99 setup that cause rubbing not the wheels itself. Sway bar proper install?
86Toyobaru is offline   Reply With Quote
Old 10-05-2014, 04:21 PM   #179
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
anyone have pics of the TRD USA wheels on a white FRS?
Thanks
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 10-10-2014, 09:16 AM   #180
86Toyobaru
Drives: 86 & GRB
I found these ABT ER wheels..........
The Following 4 Users Say Thank You to 86Toyobaru For This Useful Post:
brandonblt2 (10-10-2014), charged86 (10-11-2014), Lonewolf (02-15-2016), tahdizzle (10-10-2014)
Old 10-10-2014, 08:03 PM   #181
FyeaFRS
Sorta similar
Old 10-10-2014, 09:37 PM   #182
86Toyobaru
Drives: 86 & GRB
I think there are two difference if you take a close look. One is the bolt location and the other is lip pattern. Other than that they almost look the same. Size 18X8J +35/+45.
Some pics
Forgestar F14 wheels and Enkei wheels: <<RPF1 18x9.5/NT03+M 18x9.5 In Stock>> b2autodesigns Wheels and Tires 850 09-10-2017 09:29 AM
Team Dynamics Pro Race 1.3 Wheels (Track wheels) CHEAP!!!! Evasive Motorsports Wheels and Tires 4 07-29-2013 09:46 PM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 03:21 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 11:08 PM
