Old 08-27-2014, 11:58 PM   #1
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Fuel light range
So the fuel tank is 50L, but when I drove to the point where the needle was *exactly* at E, and the fuel light had been on for about 45km, I only put 45L in at the pump. Has anyone run their car right down to the wire, and confirmed that there's really about 50L in the tank?
I ask because the range of the car is not so great and I have some ambitious road trips I am thinking of doing. Yes, I know what a gas can is, and yes, I intend to get at least one.
pushrod is offline   Reply With Quote
Old 08-28-2014, 12:37 AM   #2
dentalprodigy
dentalprodigy's Avatar
Drives: 00 Accord LX, 14 FRS
Not sure about metric conversion but I believe the total fuel capacity is 13.2 gallons. For my first tank I tried to use every last drop of fuel to gauge the cars fuel economy and still ended up only using 11.449 gallons. My range was 315.8 miles on the first tank (95% city driving- non spirited driving) In the last 4 fill ups, the most fuel I've used on a tank has been 11.749 gallons.
Sent from my HTC One_M8 using Tapatalk
dentalprodigy is offline   Reply With Quote
Old 08-28-2014, 12:55 AM   #3
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Found this, seems legit:
http://www.autoguide.com/auto-news/2...-on-empty.html
Demandred7 is offline   Reply With Quote
Old 08-28-2014, 11:13 AM   #4
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
The shape of the fuel tank and location of the pickup will more than likely preclude you from ever getting every drop out of the tank.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 08-28-2014, 11:24 AM   #5
VacantSky
The Angry Brit
VacantSky's Avatar
Drives: 1991 E30 318iS
It's really not good on the fuel pump to run the tank low. I normally fill up at the light (Which is normally 10-10.5 gallons -US), or the soonest gas station after the light comes on if I'm on a trip and I know the route. You're just encouraging premature wear/failure of components running it so low.
Just fill her up! You're going to have to anyways right? Just my opinion/advice.
Ken
VacantSky is offline   Reply With Quote
Old 08-28-2014, 11:50 AM   #6
kbye
kbye's Avatar
Drives: 2014 FR-S
Ken
This. The "E" doesn't stand for "enough".
There are plenty of gas stations positioned across highways. Just start hunting when you're a quarter full and you'll be fine. No need to carry a gas can.
kbye is offline   Reply With Quote
Old 08-28-2014, 11:55 AM   #7
Cope52
Drives: 2014 BRZ
I run down to the light on every tank of every car I've owned and have never had a failed or whiney pump. No harm.
I went 30-40 miles after the light came on and pumped in 12.3 gal.
When the light comes on I'm able to pump in about 11.4.
Originally Posted by LeeMaster View Post
I cannot stress this enough, when I changed my rear differential fluid with Motul 300, my clutch engagement point felt smoother.
Cope52 is offline   Reply With Quote
Old 08-28-2014, 12:09 PM   #8
jvincent
jvincent's Avatar
I think either @Slick or @Pbrown documented his adventure with the fuel gauge last year.
I don't remember how low he got, but it was a lot lower than I would have been comfortable with.
Old 08-28-2014, 02:08 PM   #9
Dake
Dake's Avatar
Ken
I really can't wait for this particular automotive myth to die - unfortunately I fear it never will.
We aren't knocking around in the old family Duesenberg or even something from the eighties. Modern car tanks are designed that the fuel pump will not cavitate unless you run the tank completely empty. The only exception might be if you are running at near empty on the track and the Gs slosh the tiny amount of gas out of the pocket.
Filling up when the light comes on will still have 2 to 2.5 gallons of gas left in the tank.
Dake is offline   Reply With Quote
The Following 2 Users Say Thank You to Dake For This Useful Post:
DAEMANO (09-04-2014), strat61caster (08-28-2014)
Old 08-28-2014, 02:35 PM   #10
VuDism
NASIOC: AzNSTiImpreza
VuDism's Avatar
one time when i was forced to, i took the car to a little bit below the E line...
Still had more than 1 gallon in the tank when i filled up
VuDism is offline   Reply With Quote
Old 08-28-2014, 02:36 PM   #11
jvincent
jvincent's Avatar
Found the thread/post. My memory isn't that bad.
http://www.ft86club.com/forums/showt...71#post1305071
The Following User Says Thank You to jvincent For This Useful Post:
Baldoak (04-03-2022)
Old 08-28-2014, 03:08 PM   #12
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Filled up yesterday, 31 miles after the light came on. 12.04 gallons.
The most I've ever filled up was 12.97 gallons. I don't know how far I went on the light, unfortunately.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-28-2014, 03:50 PM   #13
VacantSky
The Angry Brit
VacantSky's Avatar
It's not cavitation. The fuel cools, and in some cases lubricates the pump.
Old 08-28-2014, 04:08 PM   #14
TM
TM's Avatar
Drives: DGM BRZ 6MT
I ran 60 miles on the highway after the light turned on averaging an estimate of 30mpg. Switched to and filled up 12.65 gallons of E85.
When I switched back to 93, ran 35 miles after the light turned on average an estimate of 23mpg. Filled up 12.77 gallons of 93. It took another 5-10 miles before my fuel trims settled on my 93 tune, which aligns with the 13.2 gallon capacity pretty well.
TM is offline   Reply With Quote
Low Fuel Light. Draco-REX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 64 11-07-2015 09:33 PM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 09:19 PM
FYI: Mileage left after the re-fuel light shows up ... qqzj BRZ First-Gen (2012+) — General Topics 17 01-31-2014 07:13 PM
Odd Gremlin with Fuel Light ON sw20kosh Forced Induction 19 09-02-2013 10:34 PM
Premature low fuel light WolfpackS2k BRZ First-Gen (2012+) — General Topics 76 06-21-2013 10:45 AM
