| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
APEXHNTR
Drives: 10 Series FR-S #1867
Is Motul just a fad? Or is it chemically superior?
Society today is plagued with buzz words and trends. Things that say "Organic" fly off the shelves regardless of their actual ingredients. All of a sudden "gluten" comes seemingly out of nowhere and now half the worlds population is allergic to it. Crossfit, apparently just a competition to see who's the best at working out, is covered night and day by ESPN.
So my question is; Is Motul chemically superior to Mobil 1 or any other Full Synthetic? What about Amsoil or the other "race" oils? Or are we all just the protein powder meatheads dropping barbells at the gym? Please calculate your responses. I'm not looking for "I know it's better because some guy I know who races cars uses it" or "Everyone on the Subaru forums uses it so it's gotta be good". Real data. Oil analysis.
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#2 |
Drives: 2014 BRZ Ltd - DGM
Well its definitely not fad if you were a long time Subaru driver like some of us on here, people have been super into Motul for the gearbox and rear end at least since I first got my WRX back in late 2005 and it still just as popular.
So that's at least 9 years that I know of personally. I've seen posts dating back 14 years on NASIOC talking about Motul fluids.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car E46 323ci vert |
#3 |
Drives: (formerly) 2013 Raven FR-S
Real data, oil analysis? I can't provide those. Only my in-car feels after using different brands. I wouldn't say they are way in above superior to everything else on the market. I'm mind of the mind that certain formulations work better in certain set-ups, for whatever reason. Motul Gear 300 works excellent in the twins' manual gearbox and diff. I've driven one with Amsoil in the box, and it was definitely better than stock, and pretty on par with Motul 300. I tend to use Motul in my motorcycle too, because of good experiences with it. On the contrary, I haven't always had the best of experience with Redline, for whatever reason. So for that, I stick with Amsoil/Motul for my vehicle fluids. My Camaro was Mobil1 for engine oil and Amsoil for gears, because that worked well there. I don't have any numbers or anything, just how the car felt with different fluids.
#4 |
StreetKart
Drives: 2014 Scion FR-S Monogram
Its currently the "in" oil... it'll change in a few years again. it was Royal Purple and then Redline and then AMSOIL and now everyone is jerking it to motul. They do make some really good brake fluid and I plan to use their gear oil in my transmission but thats because it just happens to meet my needs for now. Royal Purple went in my mustang diffs because it had friction modifier in it already and was cheaper than buying everything seperate.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#5 |
Motorsports
Drives: 19BRZ PP, 16 M4
Motul is the real deal... It has tested higher then any other "conventional oil blends" IE: no snake oil additives.
here is the article and list of all oils at the bottom. http://540ratblog.wordpress.com/
Douglas W.
#6 |
Drives: 2014 BRZ Limited
Does anyone know if the Montul gear lube eliminates or reduces the rear end chatter associated when accelerating from stop on sharp left or right turns?
#7 | |
Drives: Taking the bus
I've never tried the regular Gear 300 in the rear diff, but I heard it might still chatter. Gear 300LS is what you should use. |
#8 |
Thanks. Ordered the regular Montul 300. If this does not eliminate chatter, will try the LS.
#9 |
We used Blackstone Used Oil Analysis on multiple vehicle platforms over the past 8 years to validate our findings and experiences. We'll stick to Motul because it works for our application. Everybody has their own preferences for different reasons.
| The Following 2 Users Say Thank You to CSG David For This Useful Post: | AZP Installs (09-03-2014), flippy (09-04-2014) |
#10 | |
Shift it or lose it
Drives: 2014 FRS, 2003 Celica GT
Why would a Torsen diff need oil with a limited slip additive/friction modifier? Torsen T2 differentials are all gear driven. Differentials that use it are usually Clutch type limited slip. I changed the transmission and differential oil in my FRS a week after I bought it. The motul gear 300 did make a difference for cold driving. I never had any complaints when the transmission was at operating temp I never had the chattering problem but I only had the factory oil in for a week. |
#11 |
My diff would grumble on the first turn after sitting overnight then made no noise, but after running the Motul I don't get the "first turn grumble" and more.
Motul in my trans fixed the 1st to 2nd grind that I had, especially when cold. |
| The Following User Says Thank You to mike the snake For This Useful Post: | flippy (09-04-2014) |
#12 | |
#13 | |
http://www.ft86club.com/forums/showp...6&postcount=12 ^ These are just a few. The 300 will be fine in the rear diff, but the 300LS might be better. |
#14 | |||
Drives: 2004 Subaru Forester 2.5XT
Motul is no fad though. Quote:
Founded in 1899 in New York, the Swan & Finch company started its activity in the sector of high quality lubricants. As from 1920, it turns to the international markets by exporting some of its portfolio brands like Aerul, Textul, Motul http://en.wikipedia.org/wiki/Motul_(company) Quote:
-Dennis Last edited by bluesubie; 08-28-2014 at 12:41 PM. |
| motul 300 vs motul 300ls about to buy some need help. | NickFRS | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 03-24-2016 11:51 PM |
| Where to get Motul Gear 300 in the GTA? | automatic | CANADA | 5 | 04-09-2014 05:48 PM |
| motul Oil | whitefrs | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 05-24-2013 11:12 AM |
| No Motul Gear 300?? | markmatley | Hawaii | 14 | 04-17-2013 09:59 PM |
| Superior Shine - Opti-Guard - 86 | SuperiorShine | AUSTRALIA | 11 | 07-22-2012 11:56 PM |
