Old 08-25-2014, 07:43 PM   #1
Jakecrow
Drives: '13 FR-S Raven Black
Slight smell when revving high
Hi guys,
New here, and new to the FR-S as well (only had mine for a few weeks now). It's really great to drive, despite the whole learning a manual but that's a different story...
So my car knowledge is abysmal, never drove anything besides a camry and an old minivan until I got this - commence laughter now!
The question: is it normal to have a slightly..."hot" (not what I would call "burning") smell if I'm being aggressive and shifting at ~7k rpm? It doesn't happen all the time and goes away in <10-15 seconds, but I don't know if it should cause any concern.
Nothing feels wrong with the car but again my knowledge is sorely lacking. We have to start somewhere right?! Thanks for any help.
Jakecrow is offline   Reply With Quote
Old 08-25-2014, 07:48 PM   #2
KDad2
KDad2's Avatar
Drives: 2013 Raven
Read the manual. Keep it below 4k for the first 1000 miles. Or if you prefer the other method… Search the forum. You will find lots of info on this.
KDad2 is offline   Reply With Quote
Old 08-25-2014, 07:54 PM   #3
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
does it smell like burning clutch, or burning oil?
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 08-25-2014, 08:03 PM   #4
samisons
Drives: 2013 Raven Fr-s, 2013 Versa Sedan
could have a leak from your cam plate. Check the rear pass side of the engine unless you're auto then disregard.
samisons is offline   Reply With Quote
Old 08-25-2014, 08:31 PM   #5
zimzim
Could be new engine burning shit off
zimzim is offline   Reply With Quote
The Following User Says Thank You to zimzim For This Useful Post:
veck (08-25-2014)
Old 08-25-2014, 08:33 PM   #6
Originally Posted by Jakecrow View Post
Hi guys,
New here, and new to the FR-S as well (only had mine for a few weeks now)......
Hi Jakecrow and welcome .....
As mentioned, hopefully you have over 4,000 miles on your machine before revving up that high.
The smell could just be the engine burning off the last of the "newness" while at high temperatures. However, you may wish to look around for any oil leaks.
litemup (08-26-2014)
Old 08-25-2014, 09:51 PM   #7
radroach
Drives: car
I got a strong burning smell during my first 5k miles. It's stuff near the exhaust burning off something.
Old 08-25-2014, 10:09 PM   #8
Jakecrow
Thanks for the replies! Sorry I should have mentioned - it's at almost 30k miles so it shouldn't be anything related to it being new I assume.
I've no idea what burning clutch smells like, but it's definitely not burning oil.
Old 08-25-2014, 10:36 PM   #9
Bigbadvoodooguru
Drives: 2014 asphalt FRS
Are you slipping the clutch? Meaning, is your left foot pushing on the clutch at all once you are fully engaged (in gear)? Are you feathering the clutch and holding it partially engaged while you rev the shit out of it (and is it immediately after you do this that you smell burning?)
Bigbadvoodooguru is offline   Reply With Quote
Old 08-25-2014, 11:04 PM   #10
Jakecrow
I may have to experiment a bit more and get a more accurate description, but I'm certainly not aiming to slip it. I probably am a little bit though as manual is still new to me.
It is immediately after a high rev, but again it doesn't happen all the time. It's possible I'm doing something different (slipping or not shifting quickly enough?) when this happens but I haven't noticed anything different when it happened, besides the smell obviously.
I should also point out that this is not at all how I drive around town, it's just something to do for fun once in a while when no one else is on the road and I want to push the car a bit.
Thanks again for the replies.
Old 08-26-2014, 01:09 AM   #11
Well, in that case, you might want to check that cam plate that @samisons spoke of, to make sure it's not leaking.
A burning clutch smells like ....... well, like a burning clutch ...... hmmmm, sorta like a burning leather belt after your Pop gave you a blistering ..... or a flat, leather drive belt on an old corn grinder that got jammed ..... sorry, I'm getting further away .....
litemup (08-26-2014), sklimo (08-29-2014)
Old 08-26-2014, 01:31 AM   #12
litemup
Drives: around
pepperoni
litemup is offline   Reply With Quote
Old 08-26-2014, 09:23 AM   #13
Luis_GT
Mine often gives a burning smell whenever I keep the revs high for a while, in fact just this morning I got it. I chuck it down to being normal, since my car has 15K+ miles already.
The Following User Says Thank You to Luis_GT For This Useful Post:
sklimo (08-29-2014)
Old 08-26-2014, 09:49 AM   #14
Jakecrow
Alright, thanks. I'll look into checking the cam plate and see if I can find any leak. Hopefully it's nothing serious though
high revving NA engine chuy21 Engine, Exhaust, Transmission 30 09-14-2014 07:33 AM
Slow Revving / Acceleration after TSB 0040-13 Hardway Issues | Warranty | Recalls / TSB 9 08-25-2014 10:14 AM
is it ok to drive without high revving? lionbacker54 BRZ First-Gen (2012+) — General Topics 48 08-07-2013 01:36 PM
Engine noise free revving or under load heeltoe86 Issues | Warranty | Recalls / TSB 4 04-29-2013 12:58 AM
Slow revving? Manual car. SprayedBigCube Engine, Exhaust, Transmission 40 07-10-2012 04:13 PM
