#2003 |
Drives: A bunch of 'em...
I'll use my Gtech.
That's a touch more accurate. Also, instead of doing the hokey dyno thing, I just do a 1/4 pull and calculate it out of the trap speed. |
#2004 | |
Drives: 2013 Scion FRS
Yeah, they physically inspected my car and said everything was tight and the movement is "normal" with a cogged belt system. It's just odd that others aren't seeing this. I ordered a new crank pulley and crank pulley bolt and will try that next.
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
#2005 | |||
Drives: Kraftwerks BRZ
In the mean time, his new belt should arrive Monday. =D Quote:
#2006 | |
Drives: 2022 BRZ Limited
| The Following User Says Thank You to glamcem For This Useful Post: | KraftWerks (08-25-2014) |
#2007 | |
Drives: 2013 BRZ Premium Dark Gray Metallic
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler Last edited by zoth; 08-23-2014 at 01:32 AM. |
#2008 |
Drives: Subaru BRZ-SWP
Just an update on my brz: we just installed DW 700cc injectors and DW fuel pump, stage 3 competition clutch, mtec shift springs, motul tranny oil and the 12 psi small pulley on e85, we did a base map with little timing and drove around the neighborhood and the car felt awesome then after we got the afr dial in we started adding timing and Jesus Christ !! The combination of a fresh clutch and the smaller pulley really changed the way this cars behaves, I'm a drag racer so I'll be posting my time slips pretty soon we should be in the low 12s or maybe better. Looking to get around 350 hp on this set up ... Maybe more, I'll keep you guys posted.
| The Following 2 Users Say Thank You to Taino-BRZ For This Useful Post: | 86SPEED (08-25-2014), KraftWerks (08-26-2014) |
#2009 |
Drives: 2013 Ultramarine FR-S
All you people and your E85.... I'm jealous
| The Following User Says Thank You to Freeman For This Useful Post: | 86SPEED (08-25-2014) |
#2010 | |
Drives: The silvertrooper 10 series
| The Following User Says Thank You to 86SPEED For This Useful Post: | KraftWerks (08-26-2014) |
#2011 |
Kraftwerks Supercharger Owners Thread
We did 301 hp on e85 with the previous pulley, best time was 13.8 when the clutch gave up. I'm confident we are going to be in the 12s,car feels way faster now with all the new upgrades.
| The Following User Says Thank You to Taino-BRZ For This Useful Post: | 86SPEED (08-25-2014) |
#2012 |
Yeah a 14.5 isnt great at all. Im at about 3200 ft here and with a just a safe tune i ran a 14,7 @97mph. Car came alive when it was finished being tuned, oh and that is on a c30 on 91 pump gas.
#2013 |
I just dropped my car off at Infamous for upgraded Grams 550cc fuel injectors and then it's going next door for Bill @DeliciousTuning to do his tuning magic on the dyno. He's going to load the flash-n-go tune scaled for the new injectors then do some fine tuning on the dyno. Should have results by Friday. Looking forward to seeing the results on e85 with the fuel limitations removed!
| The Following 2 Users Say Thank You to nlowell For This Useful Post: | KraftWerks (08-26-2014), Taino-BRZ (08-26-2014) |
#2014 | |
#2015 | |
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#2016 |
Just a heads up to all of your as well I'm selling my kit with engine oil cooler and flex fuel kit. I decided to go another route asking 4k for all of it, blower is new as is filter and rotrex oil. Kraftwerks will xfer warranty as well since blower is new. I posted it up in the az thread as I'd prefer to not ship it.
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
