View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 08-25-2014, 10:58 PM   #4439
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
It's strange but the tempreture thing is kind true. I noticed crickets disappear during early morning or late at night (basically only when it's cool)
Sent from my SGH-T989 using Tapatalk
Old 08-25-2014, 11:39 PM   #4440
Bigbadvoodooguru
Drives: 2014 asphalt FRS
So is a worn pump with 10k+ miles on with no crickets going to be the next hot FS item? Should coin a new term... post metamorphosis fuel pump for sale, crickets evolved into silent butterflies.
Bigbadvoodooguru is offline   Reply With Quote
The Following User Says Thank You to Bigbadvoodooguru For This Useful Post:
pushrod (08-26-2014)
Old 08-26-2014, 03:51 AM   #4441
Ryguystye
Drives: 2014 BRZ Premium
Has anyone tried using sound insulation in the engine compartment or on the high pressure fuel pump itself? I just got my new BRZ and don't have crickets yet, but want to make it less noticeable when I do get them.
Ryguystye is offline   Reply With Quote
Old 08-26-2014, 09:31 AM   #4442
FR-S Matt
Toyota already tried it with me. Doesn't work. Just makes the pump hotter probably. I tore it all out about 5 months ago and didn't change a thing.
Old 08-26-2014, 10:35 AM   #4443
rinnamon
Drives: Toyo
I used a bottle of Mag cleaner. Found this stuff at the shell station. [ame="http://www.amazon.com/gp/aw/d/B0051ZHBII?pc_redir=1408634403&robot_redir=1"]Mag 1 142 Carburetor and Fuel Injector Cleaner - 12 oz., (Pack of 12):Amazon:Automotive[/ame]
Filled up w 93 and after a bit of spirited driving (heavy on the accelerator), the sound disappeared. We shall see if that lasts.
rinnamon is offline   Reply With Quote
Old 08-26-2014, 11:14 AM   #4444
Luis_GT
I tried E10 for the first time last week cause I was low on gas and was the first thing I found.
Instant crickets after 15K miles... going back to my 93 E0 even if its 5 cents more a liter.
Old 08-26-2014, 12:15 PM   #4445
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
My crickets went away in and around 6 to 7k miles. I have 10k on the fuel pump now and it has also become a silent butterfly
GotBRZ1691 is offline   Reply With Quote
Old 08-26-2014, 01:36 PM   #4446
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Would be interesting to start a poll of people >10k miles to see who still has crickets. Mine started at 1k miles, continued non-stop until 10k, at which point, they became intermittent. Still thinking it has more to do with pump temperature than anything else.
xxBrun0xx is offline   Reply With Quote
Old 08-26-2014, 02:30 PM   #4447
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
I just noticed on my new TSB pump that when I filled an empty tank with 100% gasoline, they immediately stopped. Immediately started when I filled that empty tank with Costco gas, which has <10% ethanol.
DoomsdayJesus is offline   Reply With Quote
Old 08-26-2014, 02:49 PM   #4448
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I've been fillling up at Costco exclusively, only chirps when it's pass half tank or extremely hot.
N1rve
Old 08-26-2014, 04:05 PM   #4449
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I'm at just over 15k miles and the crickets are still in full force when using E10. As soon as I fill up with E0 though, they completely go away. I've tested this several times and it's always the same.
smg1138 is offline   Reply With Quote
Old 08-26-2014, 04:16 PM   #4450
rinnamon
Drives: Toyo
Engine idle chirping (cricket) noise poll.
Does this mean that the ECU isn't quite set up correctly for E10? If people use E90 or whatever (with the OFT tune) and don't get chirps and if people use the stock "tune" with E0 and get no chirps, then simple logic suggests that something in between (e.g. E10) needs its own tune (which could produce quieter results somehow).
What is it about the OFT tune that causes the change? Is the pump flow rate, timing, etc changed?
Old 08-26-2014, 04:22 PM   #4451
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
While I would love this to be true , from what I've heard e85 has a bunch of additives and lubricants that help eliminate the noise. I ran the OFT stage 1 tune for about six months and still had chirping the entire time.
However to be honest I'm not educated enough on the matter to know what is actually correct. I'm Just passing on what I've heard
Kronos is offline   Reply With Quote
The Following User Says Thank You to Kronos For This Useful Post:
rinnamon (08-26-2014)
Old 08-26-2014, 04:45 PM   #4452
tonyfrs86
tonyfrs86's Avatar
Drives: 2013 raven frs
so im at 30,000 miles about and i still have crickets. they only completley go away when i fill up with ethanol free and i noticed they are way way way more quite when i use lucas upper cylinder lube when i use regular gas.
i am turbo'd and i run 5w-30 in my engine, i dont know if that important to you guys or not.
tonyfrs86 is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 04:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
