Old 08-24-2014, 02:18 PM   #1
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
options for solid rear subframe bushings?
so... if it is your suspension that is supposed to do the up/down work, technically your car would handle/ride better if the subframe didnt move at all correct? then, what are some options for solid rear subframe bushings? the only ones I found so far after searching are these from TAP auto parts:
whiteline is a hard polymer but still does a better job than the OEM one it looks like...
[ame="https://www.youtube.com/watch?v=IDfJ_zYFPcs#t=134"]BRZ / FT86 / FR-S Whiteline Subframe Lock Out Kit - YouTube[/ame]
mokinbird87 is offline   Reply With Quote
Old 08-24-2014, 02:40 PM   #2
mokinbird87
BOXER FR
more info on the solid bushings... interesting takeaways on the diff bushings:
http://www.partsshopmax.com/e107_plu...opic.php?19215
Old 08-24-2014, 11:35 PM   #3
puma
crew chief
puma's Avatar
Drives: Race car FR-S
These fit really good but taking the old bushings out is a real PITA. We ended up destroying them.
puma is offline   Reply With Quote
The Following User Says Thank You to puma For This Useful Post:
mokinbird87 (08-25-2014)
Old 08-24-2014, 11:57 PM   #4
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
For what its worth, the Whiteline Rear Subframe inserts do a really wonderful job of tightening up the rear end. They're very easy to install as well.
Just a word of warning though, with the rear diff inserts, these inserts cause a lot of NVH. Way too much for a DD in my humble opinion. They'd probably be fine on their own.
Bobblehead is offline   Reply With Quote
The Following User Says Thank You to Bobblehead For This Useful Post:
Old 08-25-2014, 02:26 PM   #5
mokinbird87
BOXER FR
I think I`ll pass on the diff inserts but still pursue the solid rear subframe bushings.
Old 08-25-2014, 02:26 PM   #6
mokinbird87
BOXER FR
if you`re talking about the solid subframe bushings and not the whitelines, can you tell me where you got them from?
Old 08-25-2014, 02:32 PM   #7
mokinbird87
BOXER FR
nvm... found the link...
http://www.partsshopmax.com/page.php?17
Old 08-26-2014, 11:30 PM   #8
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
If you care about NVH do this http://www.ft86club.com/forums/showthread.php?t=60623
o= FR-S =o
Mikepage is offline   Reply With Quote
100% Solid Press Fit Steering Rack Bushings Carolina Dyno Brakes, Suspension, Chassis 9 04-17-2015 05:44 PM
Whiteline subframe bushings Proof Brakes, Suspension, Chassis 1 03-18-2014 01:14 PM
Turn in Concepts Solid Steering Rack Bushings Proof Brakes, Suspension, Chassis 3 03-18-2014 10:42 AM
Solid Steering Rack Bushings (Press Fit) Carolina Dyno Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-03-2013 01:13 AM
WhiteLine Positive Shift and Rear Subframe Bushings Review @ Pure Automotive Pure Automotive Mid-Atlantic 5 01-16-2013 06:15 PM
