#1821 |
Thanks
My set of tires has like 2 - 2.5 hours of track time on them. I have to replace one of the tires due to an accident. Will this have any ill effects? If it would make a difference is there anything I can do like shave 1mm of tread to fix it? I'm no pro so I'm probably overthinking it and won't make a difference for me.
#1822 | |
i'm sorry, what?
Drives: Canada
can you extrapolate this a bit further I'm trying to grasph how to read the gyro readings and apply them in self analysis. I assume a lower number means faster rotation? I suppose this needs to be correlated with throttle and brake application to rule out oversteer? in essense, what is the general idea to keep in mind when analysis the gyro reading?
#1823 | |
That said a higher number is a faster rotation over the measured time frame. If you take the area under the curve of the gyro reading, you get the amount of rotation (change in cars direction) that occurred. Like so many channels, you can only really tell what is going on by looking at other channels in conjunction with it and seeing what is happening to the car along with what the driver wants to achieve. For example, a rapid excursion of the gyro value could mean that the driver almost lost it, or they could be popping the car into a four wheel slide to get a thrust angle towards corner exit (ie. diamonding the corner).
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
#1824 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
#1825 |
Drives: WR blue
What kind of lap timer do u guys use?
#1826 |
#1827 |
AIM Solo DL is awesome. I tried a bunch of things with my phone and such, nothing really gave me the quality of data that I wanted until I got the Solo DL.
#1828 |
Because compromise ®
Drives: Red Herring
because
#1829 |
Drives: WR blue
#1830 |
i'm sorry, what?
Drives: Canada
the DL is more than that, but mike can get you a good price, its worth the money long term and you could use it across different platforms.
#1831 |
Lacking brains
Drives: frz
[ame="https://www.youtube.com/watch?v=sdPWnQXdMJE&list"]spin thompson - YouTube[/ame]
this was fun, lol an unsettled car, takeoffs that were driving terrible and lift off oversteer |
#1832 | |
driving smoother faster
Drives: Sold
It looks like you stayed tight and your left wheels ran right over that nasty dip in the pavement at the very end of the white line...very easy to unsettle the car by running over it. I discovered the hole during my first time on track, first warm up lap, and stayed away from it since
#1833 | |
Lacking brains
Drives: frz
have done a handful of days there, ended up behind an ariel atom the previous lap through that section, took it tight like his line, not to self: you are not driving an atom, nor are you on slicks
#1834 |
For a moment I got scared watching that wall get closer!
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
