#1975 |
#1976 |
Drives: 2013 BRZ Premium Dark Gray Metallic
Still Borla, if that is a POS as well I'll just ask for a refund and most likely get a Tomie EL. Million Mile Warranty $hit. BTW: this will be the 3rd under warranty. Your working late aren't you?
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
#1977 | |
#1978 |
The work never ends when you're actually r&d'ing
#1979 | |
Drives: 2022 BRZ Limited
How did you install the replacement belt? I am thinking I can install it without removing the brackets or the Supercharger from the gap between pulleys and the engine
#1980 | |
Professional Smartass
Drives: White Out FRS
#1981 | |
If its not too bad i wpuld gladly take it from you until i receive my replacement in case of emergency our cars wil work without the belt
#1982 |
The crank pulley bolt started to come out. It's chewed up on the side, I wouldn't run it longer than I'd have to, and definitely not on the track. I keep it in my trunk should the one I have snap.
#1983 |
as a general informational point....the pic of the belt and how it broke indicates a sudden change in load (ie missed downshift)
#1984 | |
#1985 | |
if that's bad I wouldn't even bother try installing it since the car runs without the belt with no problem and it takes some effort to put it back in ..
#1986 | |
Drives: Kraftwerks BRZ
#1987 | |
Isn't a sudden change in load what happens every time you shift hard, whether it's a down or up shift? |
#1988 | |
.. and I am a very unlucky guy if there is a 2% failure rate it almost guaranteed that I am always in that 2 percentile
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
