#141 | |
I Love custom Turbo kits
Drives: Limited BRZ
#142 |
Drives: Hydra EMS Powered FRS Raven Black
Ha ha. I so wanted to turn up the boost even higher but when my logs showed 100% injector duty and even at this boost level it was too lean for maximum power.
I think for now we'll hold the power level we're at and get back racing in TT3 or TT2 to finish out the year. Hopefully the transmission will hold up but I do have a spare we bring to the races just in case. |
| The Following User Says Thank You to Element Tuning For This Useful Post: | Sportsguy83 (08-20-2014) |
#143 | |
Assuming it holds up and is somewhat reliable you guys may have the most legit race ready 86 setup. Thanks for sharing details about pressures and other things for those of us who double duty the car.
| The Following 3 Users Say Thank You to Dezoris For This Useful Post: |
#144 |
Dismember
Drives: 2013 Red Scion FR-S
If I remember correctly, when you first did the Hydra, you were only on port injection. Is that still the case?
#145 |
The Mechanic
Drives: Civic Turbo,FR-S
Wonder if na would make power with just the head port, springs and valve angle job..
#146 |
In another thread about lightened flywheels and pulleys, I read that some have found that running lightened parts on both ends of the engine (lightened flywheel AND pulleys) caused failures of bearings.
I wonder if there's something to be taken from that on a high rpm race engine. Maybe a harmonic balancer? |
#147 | |
noob and expert
Drives: None :(
Of course it will, but the gains would be much larger if it had FI. Doing that always helps though (assuming the porting is done right). For me, there is no glide in pulse and glide :p |
#148 |
Looks like they're getting 240-250 hp with higher compression, ITB's and other mods.
http://www.ft86club.com/forums/showt...t=71092&page=2 |
#149 | |
Now the Hydra EMS runs both the direct injection and the port injection along with quad variable cam timing, and full CAN support. So your ABS, stability control, all dash functions etc remain but the biggest asset is the fact that you can fully turn off the "stability control" and have a fully programmable traction control! The direct injection and port injection strategy is also different from OEM and really allows me the freedom to change very specific ratios of "port" to "direct" injection at any boost or RPM level. The flex fuel support is also very awesome because it switches fuel, timing, boost, starting, closed loop fuel tables, and more when running full E85 but when you taper off the ethanol it automatically alters the maps until it finally fully switches to the pump fuel mapping. Very cool! Phil Grabow |
| The Following 2 Users Say Thank You to Element Tuning For This Useful Post: | blackfireball5 (08-20-2014), EAGLE5 (08-21-2014) |
#150 | |
![]() Yes there would be significant gains with the head mods even NA. Probably NA would benefit more with some cam grinding also where the cams are pretty aggressive already for boosted applications. |
#151 | |
I'll be moving onto our external oil pump shortly and then the dry sump. We already have it all and just need to start making brackets etc. Thanks, Phil Grabow |
| The Following User Says Thank You to Element Tuning For This Useful Post: | SkAsphalt (08-21-2014) |
#152 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
#153 |
Junior
Drives: a car
Looking at a built FA20 block, this quickly becomes a very very expensive build. Can this be a sticky?
#154 | |
Junior
Drives: a car
| The Following User Says Thank You to cdrazic93 For This Useful Post: | Captain Snooze (08-21-2014) |
| FA20 Engine component photos | Crawford | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 89 | 02-22-2016 03:31 AM |
| FA20 Engine component photos | Crawford | Engine, Exhaust, Transmission | 46 | 01-26-2015 06:19 AM |
| Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. | FRSport.com | Engine, Exhaust, Bolt-Ons | 0 | 01-10-2014 01:33 PM |
| FA20 Le Mans Race Engine | SilverSkyline210 | Engine, Exhaust, Transmission | 11 | 11-18-2013 12:24 AM |
