#15 |
Drives: 2013 FR-S, raven
悪魔のハチロク
2013 Scion FR-S, Raven Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite |
#16 | |
Drives: '13 Firestorm Base AT
Can I note- The wiring diagram says 6.3" for OEM doors ;P not that it matters. Also, in the diagram, I'm noting that basically, (off the amp at least,) the front speakers are all wired together, so if I do a 4 CH amp I'm good right? |
#17 |
Drives: Scion FR-S 10 #853
Somewhere is a post where someone removed the stock speakers and took pictures of the specs on back. Can anyone find that post and add it to this list? So far I am unsuccessful.
#18 |
Audio & Bacon Junkie
Drives: 2013 WRB BRZ Ltd
My stock speakers are somewhere since I have done my install. I can look tonight for them and see if I can get any good information off of them.
#19 |
Thanks. I'm actually happy with the stock system and will just be adding a powered subwoofer. I'm interested to see what frequencies might be best left to the stock system and where I should cross over the sub. I think the stock 6.5 subs actually do decent mid-bass already.
Also if I decide to replace stock speakers, knowing what their specs are will make it easier to buy better ones. |
#20 |
Drives: 2013 Toyota 86 GTS
Custom sound in 86
Hi all
First post on here so i hope it goes into the right place! OK so how about the Australian 86 doesn't have a spare wheel (Bit odd I thought!) but it all made sense when I custom molded a fibreglass sub enclosure into it - including a 700rms JL Audio 5 channel amp with Morel 200rms front splits on custom spacers in the front and a single din Alpine head unit Leads for power and speakers are Stinger and cabled on opposite sides of the car to reduce/eliminate interference Some photos to follow - but sound is incredible and sub though only a 8 inch proves more than enough thump Cheers Scott |
#21 | |
#22 |
Drives: Toyota GT86
oh ... please also add my Thread in Audio Builds
http://www.ft86club.com/forums/showthread.php?t=47487
#23 | |
#24 |
Drives: 2003 Camry Blue | 2013 FR-S White
I'm getting my system upgraded =) stay tuned for another build thread.
#25 |
Drives: 2013 FR-S 10 Series #1186
Suggest adding these android HU threads?
Another Android Head Unit Another Android radio (KGL/Klyde/RoadMaster/GS/JY/MD) - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB
#26 |
Has anyone installed one of the small Focal FD amps yet?
#27 |
Drives: 2016 FR-S
6 pin harness
I've read somewhere in these posts about the unused 6 pin harness behind the stereo. It had constant 12 volt, an accessory 12v, a ground and a couple CAN signals. I can't seem to find the pin out. Anyone remember what thread this was in?
Edit: got the info needed. Pin 3 is 12V switched and pin 2 is ground. Powers an Alpine KPT amp pretty good. Last edited by kenrickv; 08-27-2016 at 08:46 PM. |
#28 |
Drives: Toyota 86 2017 Black
| FR-S / BRZ DIY Directory | WingsofWar | DIY (Do-It-Yourself) Guides | 77 | 02-02-2019 11:58 PM |
| Directory 86 | Tanuki | Site Announcements / Questions / Issues | 17 | 10-10-2013 04:55 PM |
| FR-S Audio Build - SQ (Illusion Audio/Mosconi) | DekaMori | Electronics | Audio | NAV | Infotainment | 28 | 04-17-2013 04:34 AM |
| 'Noobish' questions as I look to upgrade my car audio audio. | DkY in Vcr | Electronics | Audio | NAV | Infotainment | 0 | 09-22-2012 09:45 PM |
