#43 |
Drives: GT-86
Mine is 3,4,5,6 Gear if i drive from 3k-6k RPMS and gets lounder faster i go.. Sounds like Metal taping something really fast under engine load. coming from drivers side.. I put a intake in not to long ago and i thought that was the problem but when i Hold the clutch down and rev the engine all the way up to 6k i dont hear a thing.. its only under load.
| The Following User Says Thank You to J-Money For This Useful Post: | MrFisty (05-10-2016) |
#44 |
Drives: Scion FR-S
Mine has been doing this, does sound like something loose. I mainly notice it while in a drive-through.. you can really hear it echoing off the wall.
| The Following User Says Thank You to Realm For This Useful Post: | MrFisty (05-10-2016) |
#45 |
Drives: GT-86
fml
#46 |
DADA
Drives: 2013
Same issue for me, I only get it on idle or barely moving .. No vibrations under load .. Mine just started doing this
#47 |
Drives: Scion FR-S
^ exactly. I re-read the thread and most are hearing it under load. Like you said mine is doing it just while idling. I parked last night to get a red box movie and let the car run... sounded like crap, vibrating metal. By the time I got to work (20min) it was no longer there.
#48 |
Drives: Panda FR-S
I just started having this issue also. I hear rattling under load at almost all RPM ranges. It's a harmonic noise. Goes on and off depending on the exhaust vibration. I've been reading around and it seems the be heat shield rattling.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
#49 |
Drives: White BRZ
Mine only does it under heavy acceleration from take off and a bit in second but once car is warmed up after 15 minutes seams to disappear, would like to get a fix for it though.
#50 |
Drives: 2013 White-Out FRS
Any fix? Getting the same thing
I live my life one quarter-pounder at a time.
| The Following User Says Thank You to HachiRo For This Useful Post: | MrFisty (05-10-2016) |
#51 |
Drives: 2013 Pearl White 6MT
I don't listen to every noise the FRS makes. I figure any noise it makes will be amplified given the fact there's no insulation in the car. I've deduced that this car MAKES NOISE lots of noise. It's what sports cars do, they make noise. I had one irritating noise like a bump thump comming from the back and I could feel it under my seat. Checked everything and finally, the backseats were both lose from their latch. They are lose again but I just ignore it now. Windows down and rock blasting, makes it hard to hear much of anything else.
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I
at night and ate at sun rise |
#52 | |
The Fistiest
Drives: 2013 Argento FR-S
If it sounds unsettling, it is important, especially when its coming from the engine.
They said my last sig was too big.
#53 |
Drives: 2015 Scion FR-S Halo
For those who removed the sound tube and placed washers for the bolts on the underpanel, are you still getting this sound?
#54 |
Brett
Drives: ‘94 Supra
[ame="https://www.youtube.com/watch?v=g7C5jONDjgo"]https://www.youtube.com/watch?v=g7C5jONDjgo[/ame]
Does this sound familiar to anyone? My BRZ is in the shop for this. The tech is having a hell of a time trying to find it. |
#55 |
Is it an auto? If so check the vac pump.
| Strange Noise from rear of car while OFF | mike2100 | Issues | Warranty | Recalls / TSB | 23 | 12-17-2014 09:14 PM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 02:06 PM |
| Engine pinging (rattle noise) under acceleration | sho | AUSTRALIA | 95 | 08-10-2013 06:52 PM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) — General Topics | 49 | 07-02-2012 04:45 PM |
| Strange noise | Random_Art | Other Vehicles & General Automotive Discussions | 15 | 06-03-2011 04:31 PM |
