Old 08-13-2014, 10:38 AM   #1289
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Originally Posted by Deathalo View Post
Yeah I tried looking for car skins, even went on their forums, the only skins I could find just change the color and look of buttons, they don't change sizes or layouts of anything.
The one I'm using changes the layout a bit. I think this is it: https://play.google.com/store/apps/d...kins.ics&hl=en
You won't find anything drastic (I've looked), but that one is easier for me.
Prog is offline   Reply With Quote
Old 08-13-2014, 07:18 PM   #1290
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by Foobar View Post
Just an update for anyone curious about their current order to ship lead time - I ordered on the 5th (Wednesday) and received tracking info on the 11th (Monday). Anyone know how long DHL takes to get from Hong Kong to NY? I'm assuming I'll have it by the end of this week.
Showed up today, damn that's fast.
Old 08-13-2014, 10:00 PM   #1291
DriftEm
DriftEm's Avatar
Originally Posted by DriftEm View Post
Yes, I have USB selected for the connection type. I do plug in the USB device with the Torque off, the torque starts as soon as USB device is plugged in, but when i go to choose the USB device from under setup option, it says "no recognized device detected" I have already rebooted the Dashlinq and still no luck. I'll try the baud rate, I have it setup on "auto", I'll change it to 38400 see if that helps. thanks
Originally Posted by Orisai View Post
In the Torque options, make sure you have USB selected in "Connection Type". Also, you may need to restart Torque and manually choose the USB device if you plugged your SX after you opened the app.
In case it gets recognized, you may need to set the USB baud rate to 38400 in your Torque settings for it to work properly. Some OBDLink devices are set to 115200, which is way too high for them to work properly withot losing connection or data to framing errors.
38400 rate didn't help, @xjohnx any suggestions?
DriftEm is offline   Reply With Quote
Old 08-13-2014, 10:02 PM   #1292
Taro
You call him Dr. Jones!
Taro's Avatar
Drives: 2013 Twin Mish-Mash
Does anyone else constantly get the prompt asking if they want to accept Google location services? It never "keeps" the preference, even if you go into the settings menu and uncheck it.
[IMG][/IMG]
Taro is offline   Reply With Quote
Old 08-13-2014, 10:12 PM   #1293
DC2R
Drives: 2014 Scion FR-S
$50 shipping.
You can probably get a Chinese human here for less
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 08-13-2014, 10:13 PM   #1294
DC2R
No
The Following User Says Thank You to DC2R For This Useful Post:
Deathalo (08-14-2014)
Old 08-14-2014, 12:04 AM   #1295
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Originally Posted by DC2R View Post
No
Also no
Deathalo is offline   Reply With Quote
Old 08-14-2014, 12:37 AM   #1296
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Please correct me if I'm wrong. I'm looking into purchasing this head unit but a few questions as it was semi-discussed in the thread.
To use the radio, I would need to get the Antenna Adapter ([ame="http://www.amazon.com/gp/product/B004W34BBK/"]Amazon.com : Scosche LSAAB Antenna Adapter for 2002-Up Dual Lexus : Vehicle Wiring Harnesses : Car Electronics[/ame]).
To use the USB port at the bottom of the center console, I would need the Metra AXTOY([ame="http://www.amazon.com/Axxess-AX-TOYUSB-Adaptor-Retain-Vehicles/dp/B00EAYYQDO/"]Amazon.com : Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles : Vehicle Audio Video Power Adapters : Car Electronics[/ame]).
To use the aux in port at the bottom of the center console, I would need the Metra Steering wheel control adapters, or create my own harness. Is there any other brand that can supply this harness/adapter rather than me having to buy a whole set a other harnesses/adapters just to use one.
Other than that(and the oem mic), everything else is plug n play right?
Bach415 is offline   Reply With Quote
Old 08-14-2014, 06:15 AM   #1297
Foobar
SLO NO MO
Foobar's Avatar
You have to connect the amp remote turn on wire from the HU to pin 9 of the 10 pin harness (I cut off the SWC wire from the HU's 10 pin harness, connected it to the AMP wire, and moved the pin to 9) and you have to Repin the aux wires on the swc harness you linked (I haven't done this one yet).
If you have a reverse cam, you have to wire the reverse wire to pin 2 of the 28 pin harness, and get power to your camera from another source than the stock HU (can apparently use the same pin 2 to do that as well according to one member in this thread). EDIT: Confirmed, I just hooked up my reverse cam. I tapped the BACK wire from the HU to pin 2 of the 28 pin harness (Orange/White) and I went ahead and tapped the power to my camera to the same lead so that it was only getting power when reverse was engaged. Works a treat.
That ought to make it all plug n play.
The Following User Says Thank You to Foobar For This Useful Post:
Bach415 (08-17-2014)
Old 08-14-2014, 10:30 AM   #1298
Foobar
SLO NO MO
Foobar's Avatar
So I think I have one of the incorrect USB harnesses as well.
This is the one I've got:
Based on what folks are saying here, I should have the one with the grey hood and not the brown one. Right?
EDIT: Just found this thread on the Taco forums: http://www.tacomaworld.com/forum/aud...w-connect.html apparently the two harnesses out there are AX-TOYUSB and AX-TOYUSB2. The first one is what we want and that goes right into the head unit. The AX-TOYUSB-2 is designed to plug into a Toyota vehicle that has a Multimedia Interface ECU, which I don't think includes our cars.
So for anyone looking to purchase this USB harness - I guess you want to get AX-TOYUSB and not AX-TOYUSB2 - could those of you with the correct harness confirm this?
Old 08-14-2014, 11:39 AM   #1299
DC2R
Post Amazon link to the one that you bought
Old 08-14-2014, 01:13 PM   #1300
Foobar
SLO NO MO
Foobar's Avatar
Its the same one recommended early on in the thread. Problem is that multiple vendors sell from that link, and at least one vendor is doing it wrong.
Old 08-14-2014, 10:41 PM   #1301
DC2R
Here you go bud: [ame="http://www.amazon.com/gp/aw/d/B00EAYYQDO/ref=redir_mdp_mobile?redirect=true&ref_=ox_ya_os_p roduct_refresh_T1"]Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles:Amazon:Car Electronics[/ame]
Sold by SonicElectronix
Old 08-14-2014, 11:01 PM   #1302
Foobar
SLO NO MO
Foobar's Avatar
Here you go bud: Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles:Amazon:Car Electronics
Yep, that's what I ordered. The vendor that shows up as the default, car audio distributors, apologized and asked me to mail it back to them and they'll send me the right one.
Silly thing is that the picture shown is the wrong one, the brown one is AX-TOYUSB2.
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
