Old 08-12-2014, 01:27 PM   #1569
qoncept
qoncept's Avatar
I just flashed my car back to stock last night for an autox. About a mile down the road I was slowing down to turn and the car stalled. I started it back up and drove the 10ish miles home without issue.
I assume it was just a throttle calibration issue and isn't a problem but if someone could agree I'd feel a bit better. Isn't there a post somewhere about how to calibrate the throttle quicker? I'm not finding it.
qoncept is offline   Reply With Quote
Old 08-12-2014, 01:43 PM   #1570
Malt
Drives: 2015 WRX
I could be wrong here, but most of the time when people complain about the dead pedal feel its because they didn't give the ECU time to adjust the VVT exhaust settings.
Did you flash the ECU and let it idle for ~1 minute without touching the accelerator pedal before setting off? As for the stall, what map were you on before the flash and what map did you flash to? Did you notice what your trims were at when you stalled?
Originally Posted by Chad86 View Post
I am under warranty still, like most. I would think this change would be nothing compared to supercharger, but still increased horses I take it??
They need to come up with a 94 tune.
The difference between a 93 octane tune and a 94 octane tune would be rather minimal considering the difference between the 91 and 93 is tiny. At that point if you are concerned with squeaking out every last bit of a tune to take advantage of the 1 octane point difference you'd probably be best with an E-Tune or dyno tune.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
qoncept (08-12-2014)
Old 08-12-2014, 02:26 PM   #1571
qoncept
qoncept's Avatar
I went from the e85 EL header map back to the original map. And I probably didn't let it idle. I'm pretty sure that's all it was. What probably concerned me more than anything was a light I hadn't seen (steering wheel with ! that the manual says is just a keyless ignition diagnostic light). No worries.
Old 08-12-2014, 02:43 PM   #1572
Malt
Drives: 2015 WRX
Probably some residual E85 in the tank caused the stall. I wouldn't be terribly concerned as long as you were not driving to aggressive after the flash and you got all the E85 worked out of the lines.
Old 08-30-2014, 11:30 AM   #1573
Lemar58
Drives: Scion FR-S
Can anyone help me. My car keeps throwing a check Engine. Everytime I flash it goes away for ~200 miles and then comes back on, even on original file. I noticed that when it does come on my car doesn't rev match properly for example, I'd downshift coming to a stop and the revs don't shoot up at all they stay low. Any help here would be greatly appreciated
Lemar58 is offline   Reply With Quote
Old 08-30-2014, 11:35 AM   #1574
s2d4
s2d4's Avatar
What code are you getting?
Old 09-02-2014, 09:26 PM   #1575
Lemar58
Drives: Scion FR-S
P2096 help
Old 09-02-2014, 09:41 PM   #1576
Turdinator
Señor Member
Turdinator's Avatar
P2096 help
Do you have a catless header? You may have to go into romraider and disable the code.
A five second google returned this:
http://www.ft86club.com/forums/showthread.php?p=1053678
1974 TA22 Celica
2013 86 GT
Old 09-02-2014, 10:45 PM   #1577
Lemar58
Drives: Scion FR-S
I can disable the code using oft I was just curious to see if anyone else using oft+ofh has received it
Old 09-02-2014, 10:47 PM   #1578
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Had it once. Cleared it, hasn't come back since.
Sent from my Nexus 7 using Tapatalk
Mad1723 is offline   Reply With Quote
Old 09-02-2014, 11:05 PM   #1579
troek
troek's Avatar
Drives: 2012 Toyota 86
It comes disabled in stage 2 tunes. If ur getting that code maybe u have an exhaust leak. Reused the header gaskets?
troek is offline   Reply With Quote
Old 09-02-2014, 11:19 PM   #1580
steve99
Drives: FT86
open your tune in romraider go to the cel/dtc tables check code P0420 cat efficiency is disabled, shiv misses it occasionally, set it to disabled only if you have catless header on stage2 tune else its telling you you have a leak then save rom and reflash with oft
Old 09-02-2014, 11:50 PM   #1581
aristo
aristo's Avatar
Drives: BRZ SWP 14
Was doing some research before buying. I downloaded the pre-made flash files and opened the folder (OFT OTS v1_59\BINs\ZA1J___C ROMS (US 6MT)\Stage 2 UEL) and saw this:
Do each of those files stand for something seperate? Are they to customize the tune further? Because I thought the selection seemed a little sparse and unspecific if it's just 'stage 2 UEL'
Is there a customization for example, for someone who has just a UEL, intake tube and catback? or does it not get that specific?
Thanks for any help!
aristo is offline   Reply With Quote
Old 09-02-2014, 11:51 PM   #1582
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Questions for the OpenFlash guys (@Shiv@Openflash):
1. I tried a right angle OBD extension cable and the tablet didn't power up at all. Is there a limit to the length of cable used, or can you not use any extension cable at all? I would like to run it to the other side of the dash for logging and also not have the cable pointing down from the port just above my right leg.
2. I have a OBD Bluetooth adapter that I was using with the Torque app. Since installing the OFT, it no longer connects to the ecu. Is that a common issue? Works fine in another FRS, non-OFT.
Slick is offline   Reply With Quote
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 04:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 04:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 09:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
