Koji_Online
Old 08-06-2014, 01:12 PM   #505
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
So, I did this and was careful about following all the warnings about having enough play. The car has 7700 miles on it. I also have rear diff reenforecement bushings. When the car is fully warmed up and i accelerate (sometimes more up hill) I get this metalic sound from the rear of the car as the drivetrain flexes.
It is like a squeak, not a grind, not a shudder (I know what a shuddering clutch feels like). There is no bump, no front end noise. Could this be a contributor, or am I just experiencing increased NVH from the bushings?
robot is offline   Reply With Quote
Old 08-06-2014, 05:04 PM   #506
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Increase the clutch to the crazy high stock height and see if it makes any difference. If not, it's unrelated to this!
xxBrun0xx is offline   Reply With Quote
The Following User Says Thank You to xxBrun0xx For This Useful Post:
aristo (08-09-2014)
Old 08-09-2014, 10:10 PM   #507
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Originally Posted by protpibe View Post
I did the clutch adjustment a month ago and loved the new engagement point. I just replaced my clutch with an Exedy Stage 1 and now it feels like the grab point is too low. Has anyone else had this experience? I think I'll need to readjust it outwards
I had to back the adjustment off a bit and it's good again. After swapping out clutches, it moved the bite point down farther than stock
Today I installed my Exedy Stage 2 and I am experience the same.
Did you do the adjustment? I might try it tomorrow
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 08-09-2014, 10:12 PM   #508
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Yeah, I had to back the adjustment off to where it was from the factory. The upgraded Exedy clutch with no grab adjustment and removal of the helper spring feels fantastic. It's just the right weight and it bites at just the right distance off the floor. HIGHLY recommended with the Exedy
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
Draco_PR23 (08-09-2014)
Old 08-09-2014, 10:16 PM   #509
Draco_PR23
Fiebru
Draco_PR23's Avatar
I will try to back off the adjustment ....
The clutch feels great and and I recommend it also
Current Cars:
Old 08-11-2014, 10:44 PM   #510
JDis3
JDis3's Avatar
Drives: is300 / Fr-s
Can someone clarify exactly how the sensor is supposed to be after adjustment. When I made the adjustment the threading from the sensor did more adjusting of the height than the spinning rod. Also if the clutch is not supposed to be pressing on the threading much, I have no Idea how to get the threading to lock.
Daily Driver:2002 Lexus is300 Graphite Gray Pearl
Garage Queen:2014 Monogram Fr-s Asphalt 6MT
my.is: iJAYDM Clublexus: JDis3 IG:@j0nathandiaz
JDis3 is offline   Reply With Quote
Old 08-12-2014, 12:35 AM   #511
JDis3
JDis3's Avatar
Originally Posted by PMPB View Post
I can't take a picture right now, because I don't have my car. So I made a small paint stick drawing to illustrate.
Can we clarify if there should be a little nib of the sensor showing or if its supposed to have the threading pushed up against the clutch pad. is the picture above correct
Old 08-12-2014, 12:49 AM   #512
benlaz88
Drives: 2013 Asphalt FRS
Here are website for the written portion with pictures on how to adjust the clutch. http://howtune.com/articles/68-adjus...n-a-scion-fr-s
Hope this will help
benlaz88 is offline   Reply With Quote
Old 08-12-2014, 11:24 AM   #513
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Little nib is what you want. the pedal shouldn't rest on the switch, this may cause the clutch to not fully disengage
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 08-12-2014, 11:30 AM   #514
JDis3
JDis3's Avatar
.ck
But the pedal is ok to rest on the threading around the switch? it would be great if someone could take a picture of what their threading looks like on the clutch master rod and their sensor.
Old 08-12-2014, 01:53 PM   #515
ck-GT86
ck-GT86's Avatar
No, don't let it rest on the threads. I'll grab a pic later today
.ck
|| My Build Thread ||
Old 08-12-2014, 02:10 PM   #516
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
.ck
For whatever it's worth, I did find this post which includes a nice MSPaint illustration of how the switch should be.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 08-12-2014, 02:22 PM   #517
JDis3
JDis3's Avatar
yeah i reposted it a few posts above. to see if thats the correct position for the sensor.
The Following User Says Thank You to JDis3 For This Useful Post:
codesplice (08-12-2014)
Old 08-12-2014, 02:34 PM   #518
codesplice
codesplice's Avatar
Doh! You did, my bad.
But yes, it is correct. There should just be a tiny bit of the white plastic switch sticking up beyond the metal threads. You don't want the pedal arm to actually touch those threads, just the plastic bit. In general, if you can still lift the clutch with your hand slightly above where it rests you're probably good.
G+
The Following User Says Thank You to codesplice For This Useful Post:
JDis3 (08-12-2014)
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
