Drivers window switch flashing - does nothing?
Hi all,
Got car back from dealer yesterday. The windows worked fine at first... then I noticed the passenger diddnt work. Figured I needed to do the learn procedure when I got home. Well then I tried to roll the drivers side window up... and it would only raise an inch each time then stop. Now the drivers switch does nothing for either side (or lock) and just flashes. If I hit auto down, all the buttons turn off their lighting until I hit up again. The passengers side switch works fine, and has been relearned. But I cannot get the drivers master switch to control either window, even an inch up or down. I pulled the battery, same thing. Suggestions? |
#2 |
hmmmm.......check the fuse ..??
Try the re-learn proceedure again (some folks have had it work after several attempts). Let the dealer sort it out. I hope you get er fixed. humfrz |
#3 |
Hold both switches full down for 5 seconds then full up for 10 seconds.
Just had to do this 2 days ago.
#4 | |
Tried that as well, I think the switch grounds out when the down button is pressed or something. |
#5 |
Drives: 2013 asphalt scion FRS
Back to the dealership. Worked before they had it. Now it doesn't.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
| Window Switch accent review from 86_zn6 | BlackyRose | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 09-10-2013 12:13 PM |
| Anyone have this window switch accent? | BlackyRose | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 08-20-2013 05:29 PM |
| Window switch lights? | Narcoden | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 05-01-2013 08:17 PM |
| Passenger elec window faulty with flashing switch | GavinAnt | Issues | Warranty | Recalls / TSB | 4 | 04-04-2013 03:38 PM |
| Window scroll button flashing | mashal | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 02-07-2013 11:26 PM |
