#15 |
Drives: '13 BRZ Ltd
FYI that's 260 lb/in Front and 294 lb/in Rear.
| The Following 2 Users Say Thank You to Wepeel For This Useful Post: | BigFatFlip (02-07-2014), rallysrt (02-06-2014) |
#16 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
#17 |
Drives: Slowly
I may have said elsewhere you can buy Golds for $5k, but there is no way $5k will buy you the kind of setup that car has.
Sent from my Nexus 4 using Tapatalk |
#18 | |
Because compromise ®
Drives: Red Herring
#19 |
Drives: Slowly
#20 |
Drives: Red Herring
:o
#21 | ||
I guess the point I was trying to make is that these TRDs may be a good cheap alternative. Now say I was interested in purchasing these, where would I get them? |
#22 |
*****istrator
Drives: 2013 Scion FR-S 10-Series M/T
i'd like to see a shock dyno performed between these and the stock ones.
i might consider these for my 'winter' setup.
SC10N FR-S #435 of 2500
| The Following User Says Thank You to azian_advanced For This Useful Post: | JohnJuan (08-08-2014) |
#23 |
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Anyone know where this suspension kit can be purchased?? Out where I am there are a lot of dirt roads, I need some more clearance or this car is not going to survive!
Thanks |
| The Following User Says Thank You to Rossman For This Useful Post: | Muaddib (09-02-2014) |
#24 | |
When In Doubt...
Drives: Slowww
You seem rally interested. I'll show myself out.
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
| The Following 7 Users Say Thank You to Laika For This Useful Post: | forwallblakmail (09-02-2014), gramicci101 (09-06-2014), JohnJuan (08-08-2014), NWFRS (09-29-2015), solidONE (10-28-2015), Turdinator (08-07-2014), YMAA (08-08-2014) |
#25 |
Drives: FRS
i thought stock was already rally set up? shit is like 6 inch gap lol
#26 |
Veteran RallyCrosser
Drives: 10 Series FR-S, 95 Escort Rally Car
Has anyone been able to procure a set of these?
Everything should be attempted twice. Once to satisfy curiosity, and the second time to see if you like it.
My Journal 2016 SCCA RallyCross National Champion - Prepared Rear Wheel Drive |
#27 |
Drives: GT86
Nobody?
It seems that the TRD rally dampers have significantly lower damping force at high damper speeds than the OEM dampers, despite spring rates being double in front and 60% higher in the rear. Numbers (OEM converted and interpolated from BRZ damper shock dyno results by racecomp): Damping force at (high) 0,3m/s damper speed OEM vs TRD Rally Front Compression ~560 540 Rebound ~1690 1250 Rear Compression ~735 400 Rebound ~1620 1120 Spring rates (kg/mm) OEM GT86(EU) vs TRD Rally Front 2,3 4,6 Rear 3,3 5,2 So it will definitely want to sit higher in it's springs and extend quicker, possibly a bit underdamped/more comfy? Intrigued... might wanna try them if I can get a hold of them... Last edited by Trettiosjuan; 10-28-2015 at 07:09 AM. |
#28 |
Drives: FR-S Whiteout
That's a real knee-slapper, right there.
Intent > Content
cowardice is the mother of cruelty. |
| Nameless Rally Car | ducks | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 11-20-2013 04:09 AM |
| Who is up for a Rally? | Thongpocket | Southeast | 12 | 11-04-2013 09:27 AM |
| rally? autox? | paraguin | Tracking / Autocross / HPDE / Drifting | 6 | 08-13-2012 08:20 PM |
| Bullrun Rally? | trackmagic | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-28-2012 01:51 PM |
| Cusco FRS/BRZ Rally Car | vividracing | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 06-04-2012 11:42 PM |
