#1 | |
Drives: 2013 BRZ Limited WRB
Planning to drop my car on Prokit and wanted to gets some LCA's and camber bolts to adjust everything when it's done, might aswell go for it while everything is on the jack being worked on. After looking around, I've seen LCAs go for a huge range. SPC seems to be sold for a reasonnable 200$, Buddy Club look to be the next option at 400$ and then you have Agency Power that go for like 650$...
What's the real deal with all this. Is it the coating ? The brand ? The adjustability ? The JDMness ? What justify the 200$ upgrade for the Buddy Club in such a situation ? Because in my opinion, especially on a lowered car, lower control arms couldn't even be seen unless you're laying down on the pavement. ![]() Side question: Is there an advantage to Whiteline camber bolts over OEM crash bolts ?
#2 |
Drives: TRD Ultramarine '13
I just dropped my car on TRD springs, which are rebranded Prokits and no, you don't need LCA's for a 1 inch drop that these springs give. Just get an alignment and everything should be back to optimal specs without any camber bolts or LCA's.
| The Following User Says Thank You to kALMIGHTY For This Useful Post: | SkAsphalt (08-06-2014) |
#3 |
I remember seeing here some posts that questioned the durability of SPC stuff, especially if you are going to track it. We have the extra worry about winter.
Regarding camber bolts, unless you want to run bolts in both upper and lower holes to get more camber, then probably not. |
#4 | |||
#5 | |
Drives: 2020 BRZ PP
#6 | |
I agree with that, and I though buddy club were designing quality parta, hence why I wonder why they are priced so low compared to other brands..
#7 |
How are you adjusting camber back to factory spec without camber bolts or LCA's? There is no camber adjustment stock, at all.
#8 |
SPC LCAs are normally priced per arm, not as a pair.
The question you should be asking, is it worth going from a $400 SPC/Buddy Club set to a $600 Cusco/SPL set. Our opinion is that you're better off getting a high grade component for a rather critical component of your rear suspension. We've seen enough SPC and Buddy Club failures where we cannot recommend the brands as a whole. OEM Crash bolts are cheaper. Whiteline camber bolts are just SPC bolts in a Whiteline bag. |
#9 |
Drives: 2020 BRZ PP
I'd go with SPL myself personally. There are guys running those and a simple entry level coilover around here locally and they are putting down smoking times at the track.
#10 | ||
#11 | |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
#12 | |
SPL. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | funwheeldrive (02-28-2015) |
#13 | |
Drives: '13 UM86
#14 | |
Stock will not fail, but it also has no camber adjustment. SPL part next to a failed SPC part on one of our sponsored driver's cars.
| The Following User Says Thank You to CSG Mike For This Useful Post: | themajesticone (08-05-2014) |
| DME Lower Control Arms and DME Toe Arms - Review | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 02-24-2015 11:53 AM |
| Lower Control Arms | DriftEightSix | AUSTRALIA | 18 | 05-03-2014 10:56 PM |
| PSM Lower Control Arms | Khorne | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 04-26-2014 02:04 PM |
| Wtb: lower control arms | natesparxxx | Brakes, Suspension, Chassis | 3 | 04-07-2014 07:29 PM |
| WTB: SPC LCA (Lower Control Arms) | AG3NT_5CARFAC3 | Want-To-Buy Requests | 9 | 02-19-2014 01:30 PM |
