Old 07-27-2014, 10:52 PM   #5069
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by moto-mike View Post
Weird...I'm on 20k+ miles with the same belt, TONS of launch control, FFS...it really shouldn't cause it to shred. Worst case it may slip just a little. Maybe it was just weakened from an alignment issue. Check the alternator bolt that you put the extra pulley through. I've seen those out of alignment a couple of times now due to installation issues.
what motor mounts are you running? what about you @Dustin?
Old 07-27-2014, 11:39 PM   #5070
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
I feel like this is a stupid question but I did it wrong (and I am perfect btw). Was the belt installed correctly? It's pretty easy to put the belt on and unknowingly install it one tooth over on any of the ribbed pulleys. The car will run fine and you won't be able to tell by looking at how the belt is running. The tensioner will dance slightly more than if it is installed correctly.
I have 20,000 on the original belt. I took it off when I dropped to the 70mm pulley. I did the math and a 1/2 decrease in circumference is needed to keep the tensioner in the same place so that is what I got.
I don't mean to state the obvious. I made the mistake and have been working on cars my entire life. It's pretty easy to miss especially when it's the last thing you have to do before you can go have some fun!!
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
The Following User Says Thank You to calispec For This Useful Post:
Dustin (07-28-2014)
Old 07-28-2014, 12:18 AM   #5071
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I'll check that bolt like you suggested.
OEM. I'll probably upgrade to STi mounts later on down the road.
Yeah it would be easy to over look something like that but I'm about 99% positive the answer is no. I'm pretty meticulous when it comes to things like that. All the same I know with 100% certainty that this one is on like it is supposed to be.
I might go try to use LC a couple of times just to see what happens. I have a 1 year warranty on the belt I have now so if I trash this one, at least I can get it replaced for free.
Dustin is offline   Reply With Quote
Old 07-28-2014, 10:30 AM   #5072
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by Dustin View Post
Yeah 70mm. I'll try that one if his one fails.
How old is your 70mm pulley? I remember when they first hit the market one vendor (I forget which) let out a batch that weren't true. They were about 2mm out and the belt was chewing up the plastic covers and eventually shredding. I'd check the run out on your pulley.
Old 07-28-2014, 12:04 PM   #5073
Dustin
Twin Screw You
Dustin's Avatar
I purchased it earlier this year, February I believe, from @FT-86 SpeedFactory.
The Following User Says Thank You to Dustin For This Useful Post:
FT-86 SpeedFactory (07-28-2014)
Old 07-28-2014, 03:57 PM   #5074
Powersfrs
Drives: Frs
My belt shred while going 20mph in city traffic...no launch no high revving 75 pulley 5k on the gates belt..
Powersfrs is offline   Reply With Quote
Old 07-29-2014, 01:12 PM   #5075
wsites
Drives: 08 STI|15 BRZ|95 L Coupe
It definitely spun quite a bit there, I think it was mostly from the shift, but it certainly didn't do it to that extent on any of the previous tunes. I am running some sticky 245's (Yokohama AD08R's), too.
Oil cooler comes in today, going to make some kind of heat shield for the header, then it's dyno time.
What about 255's will they fit in the rear on 9.5 wheels??? Or do you need a wide body kit?
Originally Posted by cantholdanymore View Post
People wants moar pawar
Kit provides moar pawar
Kit needs engine build to support moar pawar.
People call it fault
wsites is offline   Reply With Quote
Old 07-29-2014, 01:15 PM   #5076
Draco-REX
Corner Junkie
Draco-REX's Avatar
Depends on the offset. I have 265/35s on 18x9.5+44 wheels with no rubbing. With very minor mods I could get 275s back there.
The Following User Says Thank You to Draco-REX For This Useful Post:
wsites (07-30-2014)
Old 07-29-2014, 02:44 PM   #5077
xxscaxx
Drives: 2013 SWP BRZ
I have a 10" wheel with 255's out back. Fits fine.
xxscaxx is offline   Reply With Quote
Old 07-30-2014, 12:16 PM   #5078
wsites
That's awesome! 265's would be great if the 335 blower hits the mythical 400 mark... Heck even if it only hits 350...
Old 07-30-2014, 12:25 PM   #5079
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
A guy on the FRS enthusiasts Facebook page just posted dyno numbers on his built engine with the 335 blower at slighty over 500hp to the wheels. Here's a screenshot I just took Name:  ImageUploadedByTapatalk1406733939.905970.jpg
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 07-30-2014, 02:15 PM   #5080
Jac
Drives: Fiat Abarth
Originally Posted by CK_Bladesmith View Post
A guy on the FRS enthusiasts Facebook page just posted dyno numbers on his built engine with the 335 blower at slighty over 500hp to the wheels. Here's a screenshot I just took Attachment 86526
I read that screenshot as saying the 335 is hitting 280whp and 290wtq. The turbo kit is at 500+whp.
EDIT: plus i think thats the same guy with motor issues and he's only running the 80mm pulley or something. Once he's sorted the tuning and thrown a smaller pulley on it it'll be a beast.
Phantom Supercharged BRZ | 205WHP / 185WTQ
Nameless FP/OP Combo
Jac is offline   Reply With Quote
Old 07-30-2014, 02:39 PM   #5081
sw20kosh
Drives: 2013 Black FR-S
A guy on the FRS enthusiasts Facebook page just posted dyno numbers on his built engine with the 335 blower at slighty over 500hp to the wheels. Attachment 86526
That's the turbo making 500 whp
Old 07-30-2014, 03:08 PM   #5082
CK_Bladesmith
Drives: Raven FR-S
That's my bad then. If the 335 is at only that much. I'll stick with my smaller blower.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
