#127 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
http://books.sae.org/r-146/; [ame="http://www.amazon.com/Race-Vehicle-Dynamics-R146-Publisher/dp/B004XEA3E2"]Race Car Vehicle Dynamics (R146) Publisher: Society of Automotive Engineers Inc: William F. Milliken: Amazon.com: Books[/ame] The author's page on the book with links to further information, including a separate 300-page companion workbook, software, etc.: http://www.millikenresearch.com/rcvd.html. Last edited by dradernh; 05-18-2014 at 07:12 AM. |
#128 |
Drives: FR-S Whiteout
How do we figure out how much change in toe dude to ride height change with the numbers that shankenstine gathered for this car? I ask this because I have been measuring strange changes in rear toe dude to adding and removing weight of the factory muffler assembly and fuel levels.
#129 | |
Frosty Carrot
Drives: The Atomic Carrot
The thought is with an open-source spot for the information, the Google Doc will evolve as people discover more and more accurate data. With the car being so new, there aren't many "grassroots" projects yet... but I have no doubt there will be plenty of people to over-analyze this car. One potential twist for the thread that I've been scheming would be to use 3D scanners to generate full CAD models for each component. Assemble and constrain the system in Solidworks or Pro/E. Go as nuts with the simulations as you'd like. Design lighter/stronger/better components, 3D print your ideas, and pass your idea straight to a machine shop. ![]() Anybody have access to a 3D scanner? Makerbot Digitizers are only good for 8" (diameter) x 8" (height). Not sure it would get the job done.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
| The Following User Says Thank You to Shankenstein For This Useful Post: | solidONE (05-20-2014) |
#130 |
I'm just curious about how much toe change within plus minus 1/2" from static height, so I can determine whether the toe change is designed in the suspension or due to the toe links not holding the alignment. I've gotten as much as 1/8" ~ 3/16" change in toe by just replacing the stock exhaust with a track pipe and a bit more than half tank less gas in the tank versus a full tank and stock muffler. That cant be more than 1/4" of change in rear ride height...
#131 | |
Here's the alignment specs with stock muffler replaced with a track pipe, all the stuff in the trunk removed and about 1/4 tank of gas. ![]() Here's the alignment after I replaced the stuff in the trunk, factory muffler and filled up to about 3/4 tank of gas. (disregard the front alignment, I believe the front adjusters were not torqued down sufficiently causing it to shift) ![]() A total of 0.26 degrees of difference between the rear toe with the weight added back on. According to this calculator/converter that's more than 3/16" of change in toe with only a quesstimated 50~60lbs difference in the rear. http://robrobinette.com/ConvertToeDegreesToInches.htm That's is a lot of bumpsteer, no? Something wrong with this picture?? @Shankenstein @Wepeel Last edited by solidONE; 07-29-2014 at 12:32 AM. Reason: New info |
#132 | |
Frosty Carrot
For 60 lbs, that's 30 lbs/side. Rear springs are 211 lbs/in, so that's ~1/8 in. of compression. I love extrapolating in public. If we have 2+ inches of travel, one could (wrongly) assume that the toe curve is a line... and your toe at full compression would be 1" toe in per side. Such stability, wow.
| The Following User Says Thank You to Shankenstein For This Useful Post: | solidONE (07-29-2014) |
#133 |
Drives: '13 BRZ Ltd
I remember from the earlier posts the rear toe change you were seeing seemed really dramatic. That seems like a HUGE change in rear toe for just a few pounds of weight... imagine if you are in the car or have a passenger or are carrying groceries, that would mean the toe would be changing. If I did the math right you are seeing a change of more than 1.5mm per wheel due to a weight delta of ~60 lbs. That just seems nuts to me...
I know you said to disregard the fronts... what did you think was loose between readings for the front? I didn't do the experiment of measuring toe while adding weight to the trunk, but I know when I installed my coilovers, dropped the ride height by 1" in the rear, that the toe change was minimal enough for me not to have to reset the toe in the rear. |
| The Following User Says Thank You to Wepeel For This Useful Post: | solidONE (07-29-2014) |
#134 | |
Drives: Subaru
#135 |
Drives: '13 BRZ Ltd
#136 | ||
The front camber was added using camber bolts. I'm quite sure they were not torqued down sufficiently by the alignment guy who did it the first time. I actually felt the front alignment shifting while driving. The car would steer more or less in the middle of a turn without additional steering input. Pretty scary. I took it back in only a few days after the first alignment to get this fixed and got the printouts on my previous post. Funny thing is I actually did a trackday before getting it fixed and put down a personal best lap that day. Lol |
#137 |
Drives: '13 BRZ Ltd
| The Following 2 Users Say Thank You to Wepeel For This Useful Post: | Shankenstein (08-06-2014), solidONE (08-06-2014) |
#138 |
Frosty Carrot
#139 |
This thread is awesome! Great work so far gathering information.
No one wants to measure the suspension points of the car?? ![]() I used to work at OptimumG and have used OptimumK quite a bit. I've been very tempted to put the car up on jack stands and measure the points the old fashioned way so that I could have a good baseline to start with before I start doing suspension modifications. But it's a lot of time consuming work. I contacted Bob Simmons over at Morse Measurements (http://www.morsemeasurements.com/), who has actually done some K&C testing on a BRZ, and has all of the suspension data, but he was reluctant to give any sort of deal (he wanted ~$1,600 for the data). EDIT: Also very happy to see so many people saying "Damping" as opposed to "DampENing".... drives me crazy
| The Following 2 Users Say Thank You to fika84 For This Useful Post: | Shankenstein (08-20-2014), Wepeel (08-27-2014) |
#140 |
Fat on Corn Syrup
But, I doooooo need dampeners though.
Because it's hot and dry as hell in Phoenix. |
| The Following User Says Thank You to kavanagh For This Useful Post: | wparsons (08-20-2014) |
| New Rumor: Subaru Developing Turbo 4 2.0T for BRZ | Hachiroku | BRZ First-Gen (2012+) — General Topics | 350 | 02-02-2013 01:52 PM |
| Need opinions on two new items we're developing! | yospeed | Cosmetic Modification (Interior/Exterior/Lighting) | 56 | 12-03-2012 02:13 AM |
| Chances of Someone Developing 5x114.3 HUBS (not spacers)? | Entropy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 08-04-2012 03:35 PM |
| Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) | switchlanez | BRZ First-Gen (2012+) — General Topics | 68 | 02-14-2012 07:16 AM |
