Old 07-25-2014, 11:57 PM   #617
hksuperstar
Drives: 2014 Black Limited Subaru BRZ
Originally Posted by ScionOfHorus View Post
Anybody in Houston have one installed? I'd like to ride shotgun and see how it feels
I call next
hksuperstar is offline   Reply With Quote
Old 07-25-2014, 11:58 PM   #618
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Originally Posted by hksuperstar View Post
I call next
You can ride in the backseat
ScionOfHorus is offline   Reply With Quote
The Following User Says Thank You to ScionOfHorus For This Useful Post:
CSG Mike (07-26-2014)
Old 07-28-2014, 03:23 PM   #619
Sirsimon
Sirsimon's Avatar
Drives: 2021 GR Supra A91 Edition
Forgive me if I missed this (I did search the thread), but what kind of install times are you guy seeing with this kit?
Sirsimon is offline   Reply With Quote
Old 07-28-2014, 03:50 PM   #620
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
You missed it... JKJK
It took me (I was a noob at installing an SC kit) about a day and a half. I started Saturday morning (8AM)... stopped around 7PM... finished up Sunday starting around 7AM... and I turned the key to start the engine around 10AM. Keep in mind, I also did an oil change, added the JR Oil Cooler Kit, and installed DSS aluminum driveshaft... And a Raceseng pulley kit...
If it was just the SC kit... Shouldn't take longer than a day...
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
The Following 2 Users Say Thank You to *LongFella For This Useful Post:
boarder1995 (07-28-2014), Sirsimon (07-28-2014)
Old 07-28-2014, 10:06 PM   #621
Sirsimon
Sirsimon's Avatar
^ Thanks. That's a lot to tackle in one go. Are you pleased with your choice?
Old 07-28-2014, 10:10 PM   #622
*LongFella
*LongFella's Avatar
Another silly question... JKJK 😁
Absolutely positively THE BEST thing I've done to my FRS. Worth every penny. No issues in over 6500 miles. I got the CARB kit (live in CA) and it's enough power. Do I want more power? OF COURSE! But you get to the point where too much power is useless on the 405 freeway and stop/go traffic... Some may argue that point, but I like to stay safe (as much as possible &#128540. And...more power pushes the reliability of the boxer...
CSG Mike (07-29-2014), OICU812 (07-28-2014)
Old 07-28-2014, 11:06 PM   #623
Sirsimon
Sirsimon's Avatar
Thanks again. Do you feel any noticeable reduction in power down low (say <3k RPM), or is it not really detectable?
And yes, I'm the king of silly questions! ;-)
DJ
Old 07-29-2014, 04:29 AM   #624
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
While it has not happened to many seems with any SC even if an aftermarket header does not provide much for gains with SC, seems wise to get "something" diff to avoid cooking up or cracking OEM header. Agree or disagree JR owners?
Old 07-29-2014, 10:17 AM   #625
*LongFella
*LongFella's Avatar
DJ
It's noticeable power all around. Our cars stock don't have much power to begin with... so a little goes a long way...
The Following User Says Thank You to *LongFella For This Useful Post:
Sirsimon (07-29-2014)
Old 07-29-2014, 10:49 AM   #626
enivid
enivid's Avatar
Drives: WRB JR BRZED
It took me two weeks to install :-) It was winter so I would only do an hour at a time after work.
enivid is offline   Reply With Quote
The Following User Says Thank You to enivid For This Useful Post:
Old 07-29-2014, 04:19 PM   #627
CSG Mike
CSG Mike's Avatar
With the CARB tune, no need.
Remember, a lot of tuners will richen the AFR to cool the intake charge, but when you run overly rich, that extra fuel is now being combusted by your catalytic converter, which makes the cat overheat and eventually fail.
The JR CARB tune is designed with this in mind; I don't believe *ANY* tuner on this board has ever mentioned something like this before.
We've melted the OEM cats with a 100% stock engine due to the very early OEM tunes being.... less than steller.
Our demo BRZ has had plenty of WOT/track/spirited driving time, and the CAT is still solid. The Jackson Racing test mules also still have their cats intact.
In the harshest conditions, we see a max cat temp of about 1415F (track, 115+ ambient). Under normal conditions, it's usually fluctuating between 1100-1200, and occasionally will get up to about 1300 if you're doing a long uphill drive.
For reference, the 2015 WRX sees a cat temp of about 1400 when driven on track in stock form.
MINOCIN (07-29-2014), OICU812 (07-29-2014)
Old 07-29-2014, 08:15 PM   #628
OICU812
Just a dude
OICU812's Avatar
Ok good points, just clarifying for all up costs thoughts purpose. Being my car has aftermarket exhaust etc already and would not be carb tune was concerned with the question "buy (x) brand aftermarket header now when getting kit or don't bother...
Old 07-29-2014, 08:31 PM   #629
CSG Mike
CSG Mike's Avatar
Aftermarket header = will probably a tune
Old 07-29-2014, 09:28 PM   #630
puma
crew chief
puma's Avatar
Drives: Race car FR-S
Mike, can you guys sell the kit with a special tune from a tuner like Delicious tuning or something if we want to buy the kit but need a tune for a full exhaust?
I would like to buy a package so that there is almost no final adjustment to make.
puma is offline   Reply With Quote
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 04:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
