| Engine Swaps Discussion of engine swaps. |
Drives: .
Toyota V6 & V8 motor swap info
Wasted my time
#2 |
Drives: 2013 AT Firestorm FRS
I'm confused. But Welcome.
#3 |
Drives: 2017 Camaro 1SS
Ok
#4 |
Drives: I own an FR-S. . . whatelse!
Someone has to do a 1UZ swap into this car! Someone who is both brave and stupid! It would be awesome to see and hear.
#5 |
Mentat
Drives: 2013 Scion FRS 6MT
I was thinking about 7mgte swap due to my past experience with them. The motor is solid long as you replace the oem headgasket with a mhg.
#6 |
Drives: 2013 BRZ Limited
Nice thread. Keep the info coming.
#7 |
Señor Member
I don't think I have heard of many reliable 7M engines. Whether boosted or NA they blew head gaskets.
1974 TA22 Celica
2013 86 GT |
#8 | |||
Drives: 2015 Series.Blue
Not enough power for the amount of hassle. I also don't agree with it being the best for forced induction (it's still only a 4.0 and it never saw a factory supercharger upgrade) Quote:
True, but why? If you're going that route, the 2JZ is the better option because of availability. They're both heavy as hell being they're iron blocks. Quote:
The headbolt torque spec was too low from the factory, but I've never seen a 7M in stock form blow a headgasket that was under 100K miles. 2JZ and 7M headbolts are nearly identical in metallurgy so that's not the issue. If one properly resurfaces the block and head and installs a metal head gasket with properly torqued hardware (like the 2JZ-GTE came fromt he factory) they're a fine engine. I'll end the hijack here as I could write several books on the MKIII Supra... |
#9 |
Off Topic
You could do a twin turbo vh45.
#10 |
Stig's dark passenger
#11 | |
[ame]http://youtu.be/D1TDNOo_1Pw[/ame] I think the big problem with the 1UZ is the parts you can get for them. . . there isn't much. Hopefully there will be more though in the coming years! |
#12 |
Drives: Toyota 86
I took some drifting lessons two weeks ago, and the cars we used were S15 Silvias. One had the typical turbocharged SR20 and another had a naturally aspirated Toyota 1UZ. After trying both, no doubt the 1UZ powered Silvia was way better. No lag, instant response and gobs of torque. Good luck on your build!
#13 | |
They've been saying parts are coming for years now. It's an old and effectively dead engine. Now the 3UR... |
#14 |
Drives: 2013 Subaru BRZ
the 7mgte is a huge pile of fuck, they're not solid with a headgasket or with anything else, and you're smoking crack if you put one back into a mk3 supra after you pull it out let alone put it into another car let alone an FT86
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
| 1995 Nissan 240sx Track Car (V8 Swap done no motor) | Krimlin | Cars for Sale/Trade | 3 | 03-22-2013 08:19 AM |
| Best Motor TV - Toyota 86 / Subaru BRZ | zAnSh1n | BRZ Photos, Videos, Wallpapers, Gallery Forum | 0 | 07-03-2012 02:05 AM |
| Toyota reference has the FR-S with a 2.5L motor | Toyota fr-s | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 09-24-2011 05:42 PM |
| Toyota MR2 motor swap | Abflug | Other Vehicles & General Automotive Discussions | 18 | 01-12-2011 06:12 PM |
