#71 |
Drives: none yet
After driving this for 3 days.
This mod made the whole car feel completely alive. this is definitely the best mod i've ever had. and i've done it all besides motor mounts. |
#72 | |||
aeiou
Drives: WRB BRZ
I could probably deal with a clunk, but I wouldn't be able to handle constant gear whine on the freeway.
#73 |
I don't notice any whine on the highway.
| The Following User Says Thank You to jvincent For This Useful Post: | Mikepage (07-27-2014) |
#74 |
Drives: Scion FR-S 2013 Raven
o= FR-S =o |
#75 |
Yep. Usually doing 120/125. I have Motul Gear 300 in my differential, so that may be a factor.
#76 | |
I hâve also changes my oil for Amsoil severe gear sae 75W-90 GL5 and i have gear sound. Maybe your oil is better? I don't think so... But maybe...
o= FR-S =o |
#77 |
Could be. Or I might just be deaf at that frequency now.
#78 |
Drives: GTS 86
i hear a hum, like is metal on metal type thing, in the 5th at about 60-70 km/h. Is that normal? It sounds like is coming from the diff, but i am not sure.
| The Following User Says Thank You to Hawk77FT For This Useful Post: | nickmerronesucks (06-01-2016) |
#79 |
Yes, If you have all bushings we have, then yes it's probably normal.
o= FR-S =o |
#80 |
Just installed this tonight. Anybody else notice a vibration from 4-5k that you can feel in the pedal? Its almost like the drive shaft is not balanced correctly.
| The Following User Says Thank You to Brinks For This Useful Post: | nickmerronesucks (06-01-2016) |
#81 |
Mmm i don't think i have vibration in the pedal.
You have only rear diff bushings?
o= FR-S =o |
#82 | |
Rear Diff, Rear subframe, ForcedFab/Whiteline transmission mount and shortshifter/polly bushings. Hopefully I didn't tweak something during the install. I did the rear sub frame at the same time, I had some issues with that install and was raising and lowering the rear subframe quit a bit. Its a weird vibration, Cant tell if its from the drive line or the engine itself. |
#83 |
#84 |
I can confirm from my morning ride, no vibration with my setup.
o= FR-S =o |
| DIY - Whiteline Rear Crossmember Mount Insert Bushings | F1point4 | DIY (Do-It-Yourself) Guides | 91 | 01-17-2021 03:23 AM |
| Whiteline crossmember bushing insert review | Mikepage | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 11-09-2016 04:30 PM |
| Rear Shifter/Transmission Mount Insert Bushings | TheseColorsDontRun | Mid-Atlantic | 7 | 08-30-2013 11:29 AM |
| Whiteline diff bushings and trans mount insert. | Simmons | Transmission and Driveline | 7 | 06-09-2013 09:45 PM |
| WhiteLine Positive Shift and Rear Subframe Bushings Review @ Pure Automotive | Pure Automotive | Mid-Atlantic | 5 | 01-16-2013 06:15 PM |
