#85 |
#86 |
How much power were you pushing also?
#87 |
Drives: Whiteout 6Sp FR-S
No dyno numbers but it was between 12-15lbs of boost. Just make sure you have a good tune, boost control and other gauges to monitor the beast. It is worth it to pay for a good tune.
| The Following User Says Thank You to C130NAV For This Useful Post: | raven1231 (07-23-2014) |
#88 |
It's the Mad Cow
I was around 1.25Bar max but only running at maybe 6-7PSI when mine went as mentioned in the Opening post.
Tuned by Moto-East on E85
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
| The Following User Says Thank You to Cross For This Useful Post: | raven1231 (07-23-2014) |
#89 |
#90 |
Man I was debating going turbo but this is worrying me...
#91 |
I think the big thing is to respect the turbo. For a DD I would reccomend a supercharger of you want to boost power.
| The Following User Says Thank You to C130NAV For This Useful Post: | raven1231 (07-24-2014) |
#92 | |
It's the Mad Cow
My turbo was daily driven and I was not really in boost during my drive to work with the exception of the on ramp if I didn't have slow people in front of me that like to get on the interstate at 45-55. Turbos build to boost and many of the popular supercharger setups do as well. I failed due to a known and apparently unsolved issue that a tsb is out for. It can and has happened to others the difference seems to be I'm the second boosted one to experience it that I found. I chose to go v8 because putting in another motor that there is no fix for just seems to be asking for a problem.
#93 |
Drives: 08 STI|15 BRZ|95 L Coupe
Uhm remote mount turbo kits are available for this car... and in no way could a v8 possibly have a better cg than a boxer, it is literally impossible. That being said I am not dissing on the build and if that is what you want to do with your car and money then by all means... All I'm saying is that this is not something I would consider doing to my car.
#94 |
Did eveyone see the new superstreet. LS7 drift BRZ !!!
#95 | |
It's the Mad Cow
The weight upfront already disrupts that CG so the argument again becomes invalid. You may be able to sit a Boxter lower but this motor is not further back than you can get an LS so again the characteristics require looking into more than just one point. I actually just got an offer on the LS which is making me consider just putting another FA20 in as I am at the point I still could. But most likely I will not.
#96 | |
-Cheers |
#97 | |
It's the Mad Cow
Things may seem nice in theory but this idea that the lower it's mounted makes more difference than the weight that's added and where it is added is nothing more than foolish. A more forward mounted lower Boxter vs a more rear mounted 60lbs more LS has a lot more to consider than look one's lower! Look one's also slower, has less power and is harder to get parts for, was any of that valid in the argument?
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L Last edited by Cross; 07-29-2014 at 03:08 PM. |
| 'Sloane' - Cali first time build | Re~Mix | Member's Car Journals | 6 | 06-24-2015 09:22 PM |
| The time attack build by Rob | SavingManuals | Member's Car Journals | 8 | 04-27-2014 09:01 PM |
| Adventure Time! (E.Ts BRZ/86 Build) | E.T | Member's Car Journals | 4 | 01-20-2014 02:02 AM |
| Frs300 Fa20club built motor and turbo build | Frs300 | Member's Car Journals | 32 | 01-18-2014 06:27 AM |
| New FRS owner.. time for a build? | sero901 | Forced Induction | 5 | 10-24-2013 10:40 PM |
