CSG Mike, gramicci101, grant86, GrimmSpeed, JDLAutoDesign, JRitt, KCMachine, King Tut, MillersOilsUS, PERRIN, phastafrican, Racecomp Engineering, Raceseng, Roadcone, Sportsguy83, UltramarineLuck, VerusEric, Wonderbar, Xero-Limit
Old 07-21-2014, 05:28 PM   #1065
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I'm switching to Carbotech XP12 for track pads in the rear to most evenly match the CL RC6's in front.
Thanks @CSG Mike!
ATL BRZ is online now   Reply With Quote
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
chanomatik (07-21-2014), CSG Mike (07-22-2014)
Old 07-22-2014, 04:54 AM   #1066
CSG Mike
CSG Mike's Avatar
Originally Posted by ATL BRZ View Post
It's past time for a parts manufacturer to release some decent high performance coils with heat sinks on them.
Whats bullshit is the car ran fine and continues to run fine, no misfires or anything wrong. It didn't throw the CEL yesterday when I was beating on it when bedding in the race pads, and it threw it almost immediately on my first lap of my first session on a cool, overcast morning under very light load. Came in, cleared it, went out again and the CEL persisted. I'm not going to risk tracking the car with a CEL knowing other shit could compound as a result and really ruin my day, so I parked it and got home fine. FFFFFUUUUUUUUUUUUU
Here's the weird part.
If you swap coils with another cylinder, the code will go away (for a while), but it wil lnever appear in the other cylinder...
Old 07-22-2014, 02:25 PM   #1067
ATL BRZ
ATL BRZ's Avatar
If you swap coils with another cylinder, the code will go away (for a while), but it will never appear in the other cylinder...
Mind blown. Have you guys experienced coil failure in the current CSG BRZ yet?
Old 07-22-2014, 02:41 PM   #1068
CSG Mike
CSG Mike's Avatar
Negative, but we've seen it fairly often on customers that track their cars. Swapping the coil is enough to alleviate the problem, and the code is always for cylinder 2 (front passenger side).
Old 07-22-2014, 02:54 PM   #1069
ATL BRZ
ATL BRZ's Avatar
Please correct me if I'm wrong, but I've searched and understand that #2 is actually the rear driver's side.
Looking straight at the engine it's 1 (PF), 3 (PR), 2 (DR) , 4 (DF)
For the Check Engine Lights, respectively:
P0351 = Cyl/Coil #1 or "A" = Passenger's side front (Most common failure)
P0352 = Cyl/Coil #2 or "B" = Driver's side front
P0353 = Cyl/Coil #3 or "C" = Passenger's side rear (Second most common failure)
P0354 = Cyl/Coil #4 or "D" = Driver's side rear
Old 07-22-2014, 03:47 PM   #1070
CSG Mike
CSG Mike's Avatar
P0352 = Cyl/Coil #2 or "B" = Driver's side rear
P0354 = Cyl/Coil #4 or "D" = Driver's side front
Oh oops.
You are correct, I usually see P0351. Brain fart moment.
ATL BRZ (07-22-2014)
Old 07-25-2014, 10:55 PM   #1071
ATL BRZ
ATL BRZ's Avatar
Finally received two new coils and replaced the #3 in the nick of time this afternoon.
Ready for some banked Nascar turns tomorrow at AMS!
Old 07-26-2014, 08:25 AM   #1072
ATL BRZ
ATL BRZ's Avatar
Shacked up in the Nascar garages.
Dis gun b gud
The Following User Says Thank You to ATL BRZ For This Useful Post:
gramicci101 (07-26-2014)
Old 07-28-2014, 10:52 AM   #1073
Lawn_Mower
Lawn_Mower's Avatar
Drives: GTI, BRZ
I got a code for coil number 1 at the track this weekend, didn't notice any lack of power or anything, went away on the drive home.
Lawn_Mower is offline   Reply With Quote
Old 07-28-2014, 10:57 AM   #1074
ATL BRZ
ATL BRZ's Avatar
P0351 may still be stored in the ECU's memory if you want to take it to your dealer and have them pull it.
It's a $91 part so you'll want to have them replace it if you can.
Lawn_Mower (07-28-2014)
Old 07-28-2014, 11:07 AM   #1075
Lawn_Mower
Lawn_Mower's Avatar
Drives: GTI, BRZ
Yeah I come from the VW world, so I'm familiar with phantom fault codes
I'll hit up my dealer and see what they'll do, the engine is stock so I don't really think it should be too much of a problem. I should probably pull the numbers off before Taking it in though lol
Old 07-28-2014, 12:05 PM   #1076
ATL BRZ
ATL BRZ's Avatar
weekend recap
Very eventful weekend full of new experiences coupled with the hottest air we've had all summer. Saturday I was at AMS and Sunday I went white water rafting down the Ocoee river and had a blast.
Atlanta Motor Speedway was amazing. I loved the facility and being able to use the Nascar garages. The track was a ton of fun. The infield road course was a little bumpy but the new pavement is good at promoting grip. The Nascar oval was just incredible when I got the car up on the high banks and redlining 5th gear at 125mph and taking 6th around Nascar 3 and flooring the throttle and white knuckling the steering wheel.
The new suspension and braking gear worked perfectly. The BBK is amazing and the race pads are loud as hell after bedding with any amount of pedal besides threshold braking. The brakes are now so damn thermally efficient that I couldn't keep heat in them going around the oval and into turn 1. After a few laps I noticed significantly less bite into turn 1 than anywhere else around the course since they cooled off too much around the oval, so I started braking extra early there.
My RCE T2 coilovers and Raceseng shock tops are providing a tremendous amount of mechanical grip at speed and I'm now able to say they are absolutely worth it. The car felt more nimble and capable than ever out there.
I wasn't able to get as much track time as I had hoped for since there were some delays due to a couple fluid spills and one incident on track, but I was still able to have lots of fun in both my car and my student's. I will definitely be back at the next AMS event. It's a great track for spectators as well, probably the best around Atlanta since you can see so much of the track right outside the garages in the infield.
My GoPro footage is uploading now and probably wont be edited together and ready until tomorrow, but I did receive some pretty good photos today so I'll start off with the first 10:
Marchy (07-29-2014), Wonderbar (07-28-2014)
Old 07-28-2014, 12:17 PM   #1077
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Pics look good. I still keep hoping NASA will run an event at AMP or AMS one of these years. Might have to take my soon to be track car there to add those tracks to my list.
ATL BRZ (07-28-2014)
Old 07-28-2014, 12:20 PM   #1078
ATL BRZ
ATL BRZ's Avatar
Second set of photos from AMS 7/26/14
Sportsguy83 (07-28-2014)
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 04:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 01:46 PM
