Old 07-21-2014, 02:52 PM   #71
Cross
It's the Mad Cow
Cross's Avatar
Well considering I am one of the handfull of Rear Mount Turbos I kept the car closer to factory distribution then anyone else. I still have no problem with an Extra 60 up front. I have no doubt the car will change a little but not enough to worry over all the fun I will be having knowing there are not issues that TSB's exist for with no real fixes that can just happen over and over.
To each their own, mine is already under the knife the parts are being sold off, it's a done deal.
The Following User Says Thank You to Cross For This Useful Post:
raven1231 (07-23-2014)
Old 07-21-2014, 03:44 PM   #72
C130NAV
C130NAV's Avatar
Drives: Whiteout 6Sp FR-S
Size:  88.7 KBName:  uploadfromtaptalk1405968248985.jpg
Done deal for me as well one way ticket to WGP tonight for this baby.
C130NAV is offline   Reply With Quote
Old 07-21-2014, 11:10 PM   #73
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Vs a car with a turbo and the same wheels tires etc.
Old 07-22-2014, 12:32 AM   #74
mike the snake
I think there's 60lbs difference between the two engines, and people aren't taking into consideration all the rest of the stuff.
The Following User Says Thank You to mike the snake For This Useful Post:
Sellout (07-22-2014)
Old 07-22-2014, 10:11 AM   #75
xwd
Yeah the transmission makes up a bit of the weight. That car I think has a T56 which is around 135lbs. The stock 86 transmission is maybe half that at best? It seriously doesn't weigh anything.
Old 07-22-2014, 10:50 AM   #76
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
his car has 17x9.5 2 piece wheels with good sized drag radials in the rear, plus it had a full blown kit previously. so from what it was before the swap it is roughly 60lbs more now.
Old 07-22-2014, 11:23 AM   #77
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Originally Posted by Manji View Post
It must be more than that.
Because as you can see above, there is 250lbs difference...
Or the LS1 car is also full of fuel? The manufacturer lists the curb weight of this car at ~2760. Using that curb weight you get a 160lb difference, which seems a little more in-line with what people have been saying.
Edit: I'm talking about a US spec car. The Toyota GT86 you get may be lighter
Sellout is offline   Reply With Quote
Old 07-22-2014, 12:01 PM   #78
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Very interesting thread and get's an itch going for another project! =) I blew my engine (hole from a piston rod) a while back and had FullBlown build a new block w/ a flex fuel kit.
(Referring to LS swap) First off, that's pretty sick. I would think the total weight shouldn't be too much of an issue when doing a large swap project. I honestly think the weight would be beneficial to the car's performance/handling, especially for being light and not AWD. But I don't race; I'd rather have a fun and challenging project than the fame and glory of a win.
Can't wait to see what choices you make and how your projects goes, Cross. Best of luck!! Oh, and if you need some FA20 parts instead let me know. I still have an engine wiring harness, cams (6K miles), two stock clutches (looking new), and various engine parts from my rebuild.
shiro is offline   Reply With Quote
The Following User Says Thank You to shiro For This Useful Post:
Cross (07-22-2014)
Old 07-22-2014, 12:24 PM   #79
C130NAV
C130NAV's Avatar
How much did your rebuild cost if you dont mind me asking. Not that I can go back now. Lol. Just got my WGP estimate today 21k for everything including them picking up the car from my house. Thats for an LS2. Not for those with small pockets or faint of heart.
The Following User Says Thank You to C130NAV For This Useful Post:
shiro (07-23-2014)
Old 07-23-2014, 10:44 AM   #80
shiro
shiro's Avatar
Nah, I don't mind. I'd have to look at my receipts to give you a spot on but off the top of my head these are the figures below... I still have a nice little loan to pay off LOL.
-Replacement engine (stock damaged): ~$2500
-Arias Pistons (10:1), FBM 1000hp Rods, labor and blue printing: ~$3500
-FBM Turbo Kit (GTX2867R): ~$4800
-1K cc injectors & fuel pump: ~$600
-FBM Fan shroud, radiator & tubes: ~$700
-FMB Fuel rails: ~$300
-FMB Flex Fuel Kit w/ECU harness: ~$750 (it might be more)
-Random AN lines and fittings (for catch cans): ~$180
-Radium catch cans: ~$300
-Greddy Evo 3 Exhaust: ~$900
-Clutchmaster clutch FX350: ~$900
-FBM custom E85 Flex Fuel tune: ~$xyz (can't remember)
-ECUtek license: ~$350
-4 bar map sensor: ~$120
-Mishimoto Coolant Reservoir ~$100
Total: $16000
Extras to help build
-Greddy Profic boost controller: ~$500
-AEM failsafe wideband: ~$250
-Greddy oil pressure gauge: ~$150
-Cartboy short shifter: ~$220
-Vacuum distro block: ~$70
-Custom vacuum lines: ~$50
Total: $1240
Total for all above: ~$17240
This also doesn't include any labor other than the engine build. I did all the physical tear down and rebuild myself...many fun and frustrating man hours LOL. And don't forget other additions you might want to add such as tires, rims, sway bars, strut bars, and many other awesome upgrades. :P Hope this helps
The Following 2 Users Say Thank You to shiro For This Useful Post:
C130NAV (07-23-2014), CSG Mike (07-23-2014)
Old 07-23-2014, 10:51 AM   #81
C130NAV
C130NAV's Avatar
Makes me feel much better knowing I only spent 4k more. I bet she is a beast ! I just maid the intial payment of 16k for engine and kit the rest for labor and car pickup will be paid on delivery. I also did my own engine and tranny removal.
shiro (07-24-2014)
Old 07-23-2014, 11:08 AM   #82
xwd
There is a reason people have been putting LS engines in all kinds of FR import cars for years. FC/FD RX7s, 2nd/3rd gen Supras, Miatas. They make a lot of torque/HP, are fairly reliable, and parts for them are plentiful and cheap since there are so many around. In a few years the 86 is probably going to be one of the most popular LS swap cars IMHO. There will be almost PnP kits to do it I'm sure.
I think it would be cool to stick one of the new Mustang EcoBoost 2.3L engines in an 86, but it's an inline 4 and looks too tall. That engine has forged everything inside and is going to make a ton of power when tuned.
Old 07-23-2014, 05:31 PM   #83
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
Old 07-23-2014, 06:02 PM   #84
raven1231
Attachment 85673
This is what happens when you push to far. So id rather start at 400 base and go up :-)
what were you pushing if you don't mind me asking?
'Sloane' - Cali first time build Re~Mix Member's Car Journals 6 06-24-2015 09:22 PM
The time attack build by Rob SavingManuals Member's Car Journals 8 04-27-2014 09:01 PM
Adventure Time! (E.Ts BRZ/86 Build) E.T Member's Car Journals 4 01-20-2014 02:02 AM
Frs300 Fa20club built motor and turbo build Frs300 Member's Car Journals 32 01-18-2014 06:27 AM
New FRS owner.. time for a build? sero901 Forced Induction 5 10-24-2013 10:40 PM
