Old 07-20-2014, 10:34 AM   #169
shif7i7down
Erected Member
Drives: frs
The e85 tune was good. Did 13.899 on the gtech. Once the ofh gets here and the 4.67 fd gets installed it should be a bit better.
Virtual dyno is showing 220whp with the e85 tune,while the 2.0v tune was showing. 200whp
That's a20whp gain with stock header and cbe
shif7i7down is offline   Reply With Quote
The Following 2 Users Say Thank You to shif7i7down For This Useful Post:
DAEMANO (07-20-2014), enwave (07-20-2014)
Old 07-20-2014, 10:59 AM   #170
raven1231
Reflashing now
Old 07-20-2014, 11:41 AM   #171
WNDSRFR
Drives: FR-S,GTI
Anybody know if this thing has a gas tank drain? If it doesn't, it should.
Old 07-20-2014, 11:50 AM   #172
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Tell me about it. I really want some corn juice right now. Going to drive around a lot today.
Installed Mods:
Old 07-20-2014, 12:10 PM   #173
raven1231
That's what took me so long last night. I literally drove for almost 2 hours trying to drain my tank, by the time I flashed the tune and got E85 it was 11pm.
On another note I re-flashed the tune and let it idle for 6 minutes just to be sure. It definitely seems more responsive and powerful throughout the band. I think I will actually be more than satisfied with my car for a few more years until I go full on FI
I will be heading to the track in a week or two as well to see what she pulls on the 1/4. Just curious more than anything
THANKS ROB AND SHIV FOR EVERYTHING !!!!!
Old 07-20-2014, 01:23 PM   #174
jflogerzi
jflogerzi's Avatar
Awesome news from everyone!
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
raven1231 (07-20-2014)
Old 07-20-2014, 02:02 PM   #175
Sojhinn
Sojhinn's Avatar
That reminded me of this:
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
DAEMANO (07-20-2014), raven1231 (07-20-2014)
Old 07-20-2014, 02:08 PM   #176
Jac
Drives: Fiat Abarth
Originally Posted by Shiv@Openflash View Post
Interesting to see how the E85 ESC tune compares to the OFT Vortech tune. The torque curve is basically reversed, hitting the same peak wtq but at opposite ends.
Looks like the ESC with E85 might actually feel faster than the Vortech, given that the torque comes on so soon.
Phantom Supercharged BRZ | 205WHP / 185WTQ
Nameless FP/OP Combo
Jac is offline   Reply With Quote
The Following User Says Thank You to Jac For This Useful Post:
Old 07-20-2014, 02:19 PM   #177
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta]
The ESC will certainly feel more torque-y sooner, but it still doesn't quite compare to building up boost in a traditional turbo/supercharger setup if you're into that. The best comparison in my opinion is a strong shot of nitrous if you've ever experienced that, only unlimited. For less than 1/3 of the cost, however, ESC is a steal and very unique. I couldn't be happier so far. It'll probably even stop me from pursuing traditional chargers for a long, long time. I've really enjoyed the more "on-demand" power.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
The Following 2 Users Say Thank You to enwave For This Useful Post:
DAEMANO (07-20-2014), jflogerzi (07-21-2014)
Old 07-21-2014, 12:05 PM   #178
fenton
Looks like the torque crossover is at 5500rpm ~. Phantom would feel quicker from 2000-5500 and vortech faster from 5500-7400.
When shifting at WOT i think the rev's drop to about 5000rpm if im not mistaken so Vortech would drop to 175hp and phantom to 185hp.
I think the race would be closer than some think especially through the first 3 gears. I dont doubt that vortech would start pulling in 4th and 5th.
Well shiv looks like you have some work to do, time to do "comparison" video with both cars either from a dig or a 3k rpm rolling start
fenton is offline   Reply With Quote
The Following 2 Users Say Thank You to fenton For This Useful Post:
DAEMANO (07-21-2014), jflogerzi (07-21-2014)
Old 07-21-2014, 12:08 PM   #179
fenton
Originally Posted by bfrank1972 View Post
Wow great boost numbers, can somebody explain to me how a tune changes what boost this system produces? I'm just wondering if these variances are differences based on other factors (battery performance, temperature, etc). Or perhaps if the tune does affect measured boost, could it be actually due to changes in restriction downstream from where boost is measured (ie changes in vvt)?
The tune cannot change the boost numbers unless very weird things are done with the intake cams if im not mistaken.
What is most likely happening is it is just a better day for ESC boost...Better temp in the battery, cooler air can sway the amount of boost you create by about .5psi.
DAEMANO (07-21-2014), enwave (07-21-2014)
Old 07-21-2014, 12:55 PM   #180
fenton
Did a quick area under the curve comparison:
The Following 3 Users Say Thank You to fenton For This Useful Post:
DAEMANO (07-21-2014), jflogerzi (07-21-2014), raven1231 (07-21-2014)
Old 07-21-2014, 01:03 PM   #181
WNDSRFR
Drives: FR-S,GTI
Well, this is about as low as I dare to go. I went about 47 miles after the fuel light came on. What a nerve wracking drive. Time to try the E. I hope the rain holds off.
The Following 2 Users Say Thank You to WNDSRFR For This Useful Post:
raven1231 (07-21-2014), Sojhinn (07-21-2014)
Old 07-21-2014, 01:10 PM   #182
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
You really should read Steve's instructions on how to flash to e85 and back to petrol. Let it run low then fill up ( not so low your freaking out) then watch your st and Lt fuel trims on the tablet. Once they start going out of whack (15-20) then you can flash. This indicates the e85 is in the fuel lines.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Phantom TQ250 Dyno FBO (Dual Battery Pack) Shiv@Openflash Forced Induction 23 04-29-2014 01:40 AM
Clutch dump at 5000 RPM? fasteddy BRZ First-Gen (2012+) — General Topics 20 08-22-2013 12:55 PM
External dump and under tray? mrk1 Forced Induction 5 07-30-2013 08:43 AM
Photo dump. CanibeatNoel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 07-17-2013 01:47 AM
Ricepuddin Picture Dump Ricepuddin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 12-02-2012 11:18 PM
