Old 07-19-2014, 05:06 AM   #15
Aaron_blatherwick
Close this thread
There is just a bunch of trolls responding so might as well close it
Aaron_blatherwick is offline   Reply With Quote
Old 07-19-2014, 04:44 PM   #16
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
I hear the same thing, a whine. I was worried on my way back from formula d.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 07-19-2014, 07:19 PM   #17
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
I hear the noise in mine as well. Approx. 72 mph it makes a harmonic frequency that resonates. changes with throttle. No idea what causes it but I've heard it for about a month now. I always thought "Whine" described it. Heard it could be the diff before, but never thought anything of it. just got used to it since my g/f Toyota does the same thing.
Old 07-19-2014, 07:51 PM   #18
mike the snake
Probably the rear diff. Sometimes at certain speeds and light throttle loads the sound can be induced.
Unless it gets worse really quickly, I wouldn't worry too much.
The Following User Says Thank You to mike the snake For This Useful Post:
Celadrielas (07-20-2014)
Old 07-19-2014, 11:50 PM   #19
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
I've noticed something in my car as well. Usually at any cruising speed not under load or acceleration. But I feel like i hear it towards the front, around the transmission area.
Solution: turn my music back on and stop listening for noises.
lickitysplit is offline   Reply With Quote
Old 07-20-2014, 11:04 AM   #20
Cliu91
Cliuless
Cliu91's Avatar
Drives: Whiteout Scion FRS 2014
You guys can all start a band together!
Cliu91 is offline   Reply With Quote
Old 07-20-2014, 11:17 AM   #21
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Perhaps a sound clip would have produced more useful replies.
Demandred7 is offline   Reply With Quote
Old 09-09-2014, 05:55 AM   #22
TonyTDT
Drives: brz limited
To those who have this "singing" noise, do you have a trd intake as well? I've had this noise for a while now and it gets annoying sometimes. It's a high-pitched noise that appears under light throttle at highway speeds even on cruise control.
TonyTDT is offline   Reply With Quote
Old 09-09-2014, 09:39 AM   #23
aLaFleur
Mine does it as well although I feel like it's more toward the trans... Oh well, power train warranty.
@ashtonlafleur
aLaFleur is offline   Reply With Quote
Old 09-11-2014, 02:38 AM   #24
TonyTDT
Drives: brz limited
I uploaded a video in hopes someone can identify the cause and a fix.
[ame="https://www.youtube.com/watch?v=JRJZx4xRSkE"]"Singing Noise" in BRZ - YouTube[/ame]
I let off the throttle here and there to turn it off and on.
Old 09-13-2014, 06:28 AM   #25
TonyTDT
Drives: brz limited
Does anyone have this whining and not have a trd intake??
What about a non-stock tran/rear diff fluid?
I'm wondering if it might be the hpfp. It's pretty noticeable once you hear it, comes on around 70mph light throttle.
Old 09-13-2014, 06:49 AM   #26
FirestormFRS
This noise is aggravating but not an issue. I know mine has done it since day one and I now have 37k miles and it's still doing it. I chalked it up to the car not liking 70mph so I run 72. Easiest fix EVER!!! You can hear it at 35mph as well if you listen close, leads me to believe it would blow your eardrums at 140mph
FirestormFRS is offline   Reply With Quote
Old 09-13-2014, 10:03 PM   #27
yaguphire
Drives: white-out FR-S
i can't seem to hear anything where in the video am i suppose to listen closely?
yaguphire is offline   Reply With Quote
Old 09-14-2014, 05:48 PM   #28
TonyTDT
Drives: brz limited
You might need to raise the volume a bit you can hear it throughout the entire video. It turns off at times when I let off the throttle.
Road noise? Tread Noise? zERoTu Issues | Warranty | Recalls / TSB 21 10-07-2020 11:21 PM
Odd noise after car has been off for a while Eurasianman Issues | Warranty | Recalls / TSB 2 10-25-2013 10:19 AM
Fan noise? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 3 07-30-2012 06:22 PM
LSD noise wheeladdict CANADA 2 07-09-2012 04:21 PM
