Old 07-17-2014, 11:38 PM   #29
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Our base kit is is $3995
comes with fuel pump and injectors, Garrett and tial parts. Powder coated piping at additional cost.
Ecutek license $350
Clutch $600
Total is a little under 5k and is enough to get from 300 TO 450HP.
FullBlown is offline   Reply With Quote
The Following 3 Users Say Thank You to FullBlown For This Useful Post:
Ammonia (07-18-2014), Createddeleted (07-18-2014), Sportsguy83 (07-18-2014)
Old 07-18-2014, 12:58 AM   #30
sw20kosh
Drives: 2013 Black FR-S
Clutch will slip at 230 ft lbs.
Stock fuel system will run out somewhere in the 300's whp range.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
CSG Mike (07-18-2014), rb6freak (07-18-2014)
Old 07-18-2014, 01:18 AM   #31
MagicBobert
MagicBobert's Avatar
Drives: 2014 WRB BRZ Limited
Originally Posted by ravenrx7 View Post
well 1400 + 200.00 in shipping took two months to show up, Sounds like a beast though! Quicksilver Sport, heard of it?
You spent $1600 on a catback?
MagicBobert is offline   Reply With Quote
Old 07-18-2014, 04:53 AM   #32
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Hahah oh snap, as soon as people started bring up base kit specs vendors be jumpin in. For OP i would reccomend a S/C so you dont have to deal with turbo heat and engine bay cooling after you install it on your car, that being said I woukd suggest the Jackson Racing S/C. Its been said before, its not a cheap venture, then again changing the asperation on any car is inherantly expensive. gotta pay to play
( why would someone leave the IC cost seperate from a kit...I thought all turbo kits and some S/C kits came with them )
Old 07-18-2014, 08:54 AM   #33
Shady195
Drives: '13 10 Series FRS #1203
Looking at other cars over the years, the amount of aftermarket for this car is amazing. Competing vendors have competitive pricing because of all the competition. Their are not many cars where you can get a complete drop in and go kit that can be done on a weekend in your driveway for under 5 grand thats of the quality that most of these kits are.
Shady195 is offline   Reply With Quote
Old 07-18-2014, 09:54 AM   #34
Ken@PTuning
Drives: '92 Nissan 240sx KA-T
Send a message via AIM to Ken@PTuning
PM Sent
Ken@PTuning is offline   Reply With Quote
Old 07-18-2014, 10:07 AM   #35
MAPerformance
Drives: Asphalt FRS
Our kit comes with an intercooler, so that won't be needed in your price quote And we also have full done kits starting much cheaper than that price depending on the turbo as well.
Originally Posted by Createddeleted View Post
Since he cross posted here's the skinny
Let's take into perspective a few things just from a quick search:
MAP's full done kit with 1100cc injectors is $6700
Clutch $1100
Intercooler $1000 (maybe a little high)
Tuning license and dyno time $1200
Exhaust $1000 (catted)
That's $11,000...
Then labor
MAPerformance is offline   Reply With Quote
The Following User Says Thank You to MAPerformance For This Useful Post:
Old 07-18-2014, 11:00 AM   #36
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Full Blown kit is $4000
ACT Clutch/Flywheel $600
Tuning license and dyno time $1400
That's $6,000...
fixt. Install the kit yourself.
Old 07-18-2014, 11:00 AM   #37
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Ecutek license $350
Clutch $600
Worked for me.
Old 07-18-2014, 12:46 PM   #38
FR-S Matt
Kraftwerks SC kit -$3500
Radium Dual Catch Cans - $280
Mishimoto Radiator w/ Hoses - $375
Kraftwerks Oil Cooler - $493
P3Cars Vent Gauge - $389
Self installing everything. Tuning being done by a contact I have.
$5037
Old 07-18-2014, 02:10 PM   #39
Robftss
Drives: VW
is dropping 12k---right?
If that is a 'turn key' quote including: Tax, shipping component costs, shop supplies, labour rate, fluid changes, custom tune/dyno time and they warranty their work...sounds about right. It's all the little bits that add up on top of an advertised base price. I bet the end result would be spectacular!
Robftss is offline   Reply With Quote
Old 07-18-2014, 05:37 PM   #40
AVOturboworld
12k I was quoted for a custom- tuned turbo kit. That's crazy! I just want a kit that will fit my current setup and if I blow a clutch later down the road , I'll slap in a nice one.
What is missing here is what power goals did you have in mind, especially when you asked for the quote?
It's already been touched on here and in other threads, but if you are looking for 250-300whp on pump gas, then you don't injector upgrades or fuel pump upgrades. In general, if you are planning to run 92-93 octane pump gas you won't be looking at more than 300whp for safety sake.
As general rule of thumb:
1) 220-260whp, 190-215 ft/lbs of torque - you really don't need anything besides the FI kit of your choice. The clutch should be fine, the standard fuelling will be fine, even the stock exhaust will be fine.
2) 270-300whp, 220-260ft/lbs of torque - you will be at the limit of the standard fueling and standard 92-93 octane pump gas. You may be able to push the power further, but that is a choice to make between you and your tuner. You *will* need a clutch, as once you get to 220+ ft/lbs of torque, your clutch will give way. If not right away, it will be soon. Exhaust upgrades are highly recommended. So is an upgrade to better rubber.
3) 330+ whp, 260+ ft/lbs of torque - for safety sake, you better be running e85, race gas, meth, or similar. Running e85 guarantees you'll need larger injectors, plus a fuel pump. Stock clutch left the building a long time ago. Exhaust is necessary. Brake, suspension, and tire upgrades should also be considered mandatory. Some gauges to monitor the situation is also A Very Good Idea.
Choice no.3 can easily push you into the 10k+ range, not because of the FI kit itself, but all the supporting modifications that go with it.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
ericmpena (07-19-2014), Sportsguy83 (07-18-2014)
Old 07-18-2014, 07:38 PM   #41
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Originally Posted by Robftss View Post
*snip* I bet the end result would be spectacular!
...or complete crap for the price.
Old 07-18-2014, 08:32 PM   #42
steve99
Drives: FT86
keep you existing exhaust
add
http://openflashtablet.com/products/OFT300/index.html
Crazy Quote ravenrx7 Forced Induction 19 07-20-2014 10:12 AM
Insurance quote FT86FRS CANADA 158 01-27-2014 01:08 PM
Favorite Quote Monogram Off-Topic Lounge [WARNING: NO POLITICS] 24 01-17-2014 05:50 AM
Insurance Quote tmigo27 Other Vehicles & General Automotive Discussions 22 03-19-2012 01:35 PM
Moto-P 4ag quote on engine CyberFormula Engine, Exhaust, Transmission 18 09-19-2011 12:07 PM
