| CANADA Canada |
#15 |
Drives: '14 Subaru BRZ
What mileage does the chirping start?
I've had my car a month and a half, 5700km Shell 91. No chirping I don't think
Life's too short to drive a boring car
#16 |
Canadian FR-S Member
Drives: FR-S '10 Series'
Car built May 2013. Only Shell 91 since Day-1, and mine has chirping. started around 2000km, now at 20,000. My Toyota dealer has been hesitant to do the TSB cause the mechanic knows it's not gonna change anything. I haven't heard any 100% positive feedback from those with newer or replaced ones.
#17 |
Sarcastic SOB
My car built April 2012 and it STILL only chirps if I don't use Shell VPower. In fact I think I was the first to post that observation on these forums while everybody was starting to complain about how to stop it.
Using the OFT and therefore only Ultra 94. No biggie, its not like you are bleeding from your ears at a stoplight. Other makes with DI have the same sound.
#18 |
Drives: 2013 FRS mt
Chirping started around 8,000km - dealer preformed TSB, chirping returned very shortly afterwards.
Gas doesn't seem to matter Ultra 94, Shell 91, etc. Its really only noticeable/annoying when I pull in/out of the garage with the windows down at idle. Just rolled over 40,000km's with zero issues apart from the slightly annoying chirp, I've accepted it. ~swin |
#19 | |
i'm sorry, what?
Drives: Canada
no noises out of the engine anyway, and I find the car runs a tiny bit smoother too.
#20 |
Drives: 2012 WRX, 2003 RSX Type S
I have found the cure to the the crickets. Like real life crickets, if you get near it, it stops chirping. But the second you step away, it starts again.
#21 |
head of infinite swagger
Drives: 2013 FR-S 6MT
My car still chirps and I've had the HPFP replaced already.
Mostly Shell gas, always 91 (never 94)
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
#22 |
BRZ Built around Aug 2012. I've had chirps develop after a few thousand miles. Now at 12k miles, I tried Lucas Fuel Injector Cleaner/Upper Cylinder Lubricant (because I had it laying around) and it immediately reduced the crickets by at least 80%, adding about 2oz per tank. Once it runs out I'll try something else to see if there's any more improvement. If I don't run the Lucas, crickets are more noticeable but don't seem as loud as they used to be...
And I also understand it to only be an annoyance. |
#23 |
Drives: GT-86
What chirping. I may have to listen again. I don't notice it after 2 yrs 20k
#24 |
Drives: 2013 Subaru BRZ Limited (CBS)
I recently bought my BRZ. A 2014 model. At around 1500 miles i started hearing the cricket noise.
2016 Scion FR-S
1991 Acura NSX 2012 Mazda Miata (Track) 2019 Triumph Bonneville Bobber 2007 Suzuki SV650 (Track) |
#25 |
Drives: 2013 Scion FRS
At 27k and not a single chirp yet! I've only ever filled up with Shell 91.
![]() 2013 Firestorm Scion FRS 2005 Civic SI Sedan- Sold 2004 Impreza WRX - Sold 1992 Civic Hatchback - Parted, RIP |
#26 |
Drives: BRZ Sport tech
Mine as well, 35k, and I use 91 gas from whatever station I'm close to at the time. I've never heard anything.
#27 |
*****istrator
Drives: 2013 Scion FR-S 10-Series M/T
get gas from a place that doesn't contain any ethanol
/crickets /thread
SC10N FR-S #435 of 2500
#28 |
Drives: '13 Whiteout FR-S (M/T)
I've mentioned this before but going to say it again...IMO, crickets are not detrimental to the operation of your car. However, running 91 octane on spirited driving (maybe even regular driving) will lower your IAM from knock. I've logged my IAM with Shell 91 before and it can get as low as .50. Now with Ultra94 it rarely goes below .9 on the street (has gone down to .7 at the track).
You're leaving a lot of timing on the table by running sub optimal gas.
| Changing fuel stops the chirp | wbradley | Issues | Warranty | Recalls / TSB | 101 | 07-07-2014 04:46 PM |
| Dealer says power steering pump responsible for chirp | joelg | Issues | Warranty | Recalls / TSB | 10 | 11-03-2013 08:54 AM |
| Fuel Pump high pitch chirp noise | lucius | AFRICA | 9 | 10-24-2013 02:40 PM |
| i hope the look of the frs doesn't change too much throughout the years... | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 11-07-2012 01:21 AM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 04:53 PM |
